Hydraulic leak
/ Hydraulic leak #1
Rattrapper
Swanzey,NH, ,
Mahindra Max 26xl, JCB 3D series III Loader/backhoe
I have a Mahindra Max 26XL with 103hrs (Warranty) it developed a crack on the High Pressure tube at the Pump flange. This tractor is currently at the dealer being repaired. Has anyone had this happen to them? Is this a common Problem? I have had no problems with machine otherwise.
/ Hydraulic leak #2
I read your entry with interest as I have purchased a 2017 Max 26XL Shuttle with 26L FEL at Gary's just down the road from you during the latter portion of this past August. I have 64 hours on it at the present time with no mechanical or electrical issues as of yet. Was the pipe that cracked listed as Pipe B part number 19582580000 attaching to the bottom of the rear Pump Number 1? The reason that I inquire is having the same tractor model I am trying to learn what other owners of this model are experiencing with their tractors and build up a list of areas to keep an eye on based on the overall experience of members of this forum. Thanks for your time.
/ Hydraulic leak
That is the pipe, and Gary's is where my tractor is now. I have had no other problems with this unit. I will tell you this if you are going to use this machine for snow removal/ Plowing you will need chains on the rear tires as well as either loaded tires or a counter weight. DO NOT put chains on the front tires you will damage the front drive unit. Also if you did not get a cab for that unit get at least a soft cab for it, You be glad you did when the weather gets lousy.
/ Hydraulic leak #4
Thanks for the information. I look forward to hearing your experience with the Max as you put more hours on it.
/ Hydraulic leak
My tractor is to be brought back to me today. I spoke with the Mechanic at the dealership and was told that the new pipe is an up grade, so it appears that this maybe a recurring problem. The dealer (Gary's in Winchester, NH have been outstanding) Mahindra would not next day the part, I had to wait a week for the repair. Again NOT Gary's Fault.
/ Hydraulic leak #6
I am glad that you are having a positive experience at Gary's. I live less than 10 minutes from a business selling Mahindra tractors but chose to drive 2 hours to Gary's based on their reputation in the equipment field. My Max is a 2017 model what year is your Max? I wonder if the upgrade was already done to the 2017 models?
/ Hydraulic leak
2016, I bought it two days before Christmas, No, it was not a Christmas present to myself. I had to replace a Ford 1310 ASAP, That had a hairline stress fracture that was weeping oil. Also if you picked it up yourself you should have avoid that damned sale tax that you folks have down there. (I am a MassHolechusetts Escapee)
/ Hydraulic leak #8
What's this "You Folks" Kemosabe??? I live out in the woods where men are men, women are women and the animals aren't too particular either way........
/ Hydraulic leak
I couldn't help myself....lol
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
2003 Ford F-250 Pickup Truck (A61568)
2003 Ford F-250...
Frac Manifold S/A Trailer (A60352)
Frac Manifold S/A...
2001 Ford F-150 4x4 Pickup Truck (A59230)
2001 Ford F-150...
Caterpillar 2PD5000 5,000LB Diesel Forklift (A56857)
Caterpillar...
2025 GPS Trailer (A56857)
2025 GPS Trailer...
