breaking up hard/very rocky soil
   / breaking up hard/very rocky soil #1
Nolove
South Carolina
Ford n8
IMG_1165.JPGthis spring i plan on turning an old field into pastor. its an over grown area that is very rocky from small to 40-50lb rocks my question is what would be the best way to break up the ground i have a disc but don't want to destroy it should i plow it then disc? just looking for some ideas
thanks
   / breaking up hard/very rocky soil #3
Something like this would work. It is basically a box blade without the box and only cost me about $350 new.
   / breaking up hard/very rocky soil #4
I pull it with my LS P7010 but I keep it in 2 WD so when it hangs a big rock, it will slip the tires rather than break something. So far I have roller out some big rocks without damage to the plow.
i was thinking about something like what you got
   / breaking up hard/very rocky soil #6
   / breaking up hard/very rocky soil #7
this spring i plan on turning an old field into pastor. its an over grown area that is very rocky from small to 40-50lb rocks my question is what would be the best way to break up the ground i have a disk but don't want to destroy it should i plow it then disk? just looking for some ideas
thanks
I'd get an old spring tooth cultivator and get on the ground in the spring ASAP when things are soft. If you can find one, the old Dearborn or Pittsburg cultivators from the 1950's are excellent for this. I used them in Maine for ripping similar ground full of rocks and never had a problem. You will have rocks to pick up.
Another way that worked for me was to use a rototiller set on shallow and just skim the ground. The rocks stayed put, the ground levelled up a lot and enough dirt was created to get seed started. Take it a little easy and it's OK on a tiller. I did it for years with no probs. In thinking about it, this would be my first choice because it's the least invasive.
   / breaking up hard/very rocky soil #8
This spring i plan on turning an old field into pasture. Its an over grown area that is very rocky, from small to 40-50lb rocks. What would be the best way to break up the ground? I have a disk but don't want to destroy it. Should i plow it, then disk? Just looking for some ideas.
What size is this piece of ground?
If you have a plow which has been successful plowing the same ground behind your FORD 8N, plow first.
A Disc Harrow which is sized to a FORD 8N is simply going to roll over hard, unplowed ground.
If plowing is not an option, a single-shank Subsoiler is tough and many are sized to your Ford 8N.
Working the soil when it is moist will be much, much easier on your equipment than working the same soil dry.
its about 20 acres i now have a massey ferguson 2615 4x4
my plan was to plow it up then disc then rent a rock rake ( not landscape rake ) to windrow everything then use a skid steer to load the rocks into a dump trailer
I'm just trying to see if there is a better idea to break up the ground.... I've done a few other areas by just discing it up but those where not as rocky as the area I'm about to do and my disc has taken a beating I'm not looking to make the area into a golfing green it would be used for cows and hay the photo is an older pic of the area
thank you
   / breaking up hard/very rocky soil #10
Update your T-B-N profile, substituting MF 2615 for the Ford 8N. I hate it when authors start by feeding us bad info.
MF 2615 SPECS: TractorData.com Massey Ferguson 2615 tractor information
Assuming your MF 2615 has a loader, consider an Ultra Fork attachment for your bucket, to scoop up a good bit of those rocks while allowing dirt to fall through.
Multi-Spear Ultra Fork
Note Ultra Forks are available in 24" and 34" length.
Spacing between tines is five inches.
After you remove five inch rocks I expect you could wire on cyclone fence or stock fence and screen for smaller rocks.
I have a Bucket Spade from Bucket Solutions. Their bucket attachment mechanism is absolutely rigid and will not harm your bucket.
2019 POLARIS RANGER XP PROSTAR 900 HD DOHC UTV (A51406)
2019 POLARIS...
Heavy-Duty Gooseneck Hay Trailer - Built for Large Bale Hauling (A52128)
Heavy-Duty...
2005 Sterling Single Axle Dump (A47384)
2005 Sterling...
Schuler 220 BF Feed Wagon (A50514)
Schuler 220 BF...
BUSH WACKER ST-180 ELITE BATWING ROTARY MOWER (A51406)
BUSH WACKER ST-180...
