Buying Advice Kubota BX23S third function valve
/ Kubota BX23S third function valve #1
Jamie327
Central NJ
Deere 445
Hi all.
I dropped by my dealer to sign the final paperwork and inspect my new BX23S that's being delivered on Tuesday, and something about the third function valve they installed doesn't look right. It doesn't match the pictures in the brochure, nor does it look like what others have posted on this forum. It also looks kinda cheap the way it's installed with wires exposed above and below the loom on the control as well as the very exposed valve and zip-tied hydraulic lines. I'm guessing they're trying to pull one over on me but I want to make sure before I go accusing anyone of anything. Any help is appreciated!
/ Kubota BX23S third function valve #2
To start with, it is a WR Long kit, nothing wrong with that, but is that what you were expecting? As far as the exposed wires, the installer just got careless, have them get the wires covered with the loom. Is the control grip shown in the brochure, how about the valve? Is that what's on the tractor?
Go from there. Good luck.
Well, good question. It's not what I was expecting, for sure; I was expecting an OEM Kubota option.
Pics of from the brochure for reference:
Screen Shot 2017-10-27 at 6.52.43 PM.pngScreen Shot 2017-10-27 at 6.52.33 PM.png
The question I have is whether the one I ended up with has any advantages vs. OEM or not. I mean, the OEM "diverter" version definitely seems to be better thought out as it integrates into the loader and its hydraulics vs. a separate set of hoses to have to connect and disconnect with the loader, however I don't know if functionally the WR kit is better.
/ Kubota BX23S third function valve #4
From what I'm reading "buttons" the Kubota 3rd function is not a diverter, but a true 3rd function. I know that's what is on the L models and larger. I don't think that Kubota uses a diverter system on any of the tractors, but I don't know that for a fact.
If indeed it is a true 3rd function, then it operates the same as the WR Long system. So then you need to decide if the OEM system's fit and finish is what you would prefer or just stay with the WR Long system.
Good luck.
Good luck.
Thanks, Brian. What got me thinking it was a diverter type were the below photos in another thread. It looks like the valve taps into hydraulics on the loader, which leads me to believe only one of the functions can operate at the same time:
520679d1504467119-anyone-install-3rd-function-valve-img_6652-jpg
As well as the button looks like it may only be a push button rather than a rocker switch:
520680d1504467150-anyone-install-3rd-function-valve-img_6653-jpg
Not really decided on what I'm doing yet. Tractor is getting delivered tomorrow so we'll see how I feel about it after another look.
/ Kubota BX23S third function valve #6
I believe that you are correct, it is a diverter valve. Sort of surprised about that with all their other tractors using a true 3rd function. :confused: I personally prefer the diverters for various reasons and is what I have on both of my utility tractors.
/ Kubota BX23S third function valve #7
Yes, it's the WR Long. My dealer did the same thing with mine. I wanted the Kubota 3rd function option, but he told me the back-order time was ridiculous when I bought the tractor.
It works fine, but I can't do all 3 operations at the same time. One gives. My old grapple had the same set-up so I'm pretty much used to it anyway. I do like the thumb button on this vs the finger buttons on the old joystick with the 2370. Took a little to get used to, but it now seems more intuitive.
/ Kubota BX23S third function valve #10
I would take the 3rd function over diverter any day.
Have had the WR Long 3rd function on the L3130 for close to 10 years now and the only bad thing is I am on toggle switch number 3. The OTTO KICBEAAAAA switch looks pretty good but at $69.00 it is not cheap to replace, the RED version on Ebay is $20 plus shipping, otherwise the 3rd function on the grapple does wonders for brush work.
David
/ Kubota BX23S third function valve #12
And thanks for posting about this problem. I was considering getting one for my BX25, but now I know to research it very carefully before buying. I would've just assumed that they would put it in the best place to do it right.
/ Kubota BX23S third function valve #13
Let's see OEM factory, will be factory installed or a remove all installed and replace with OEM, will be neater and look nicer and $$$$$$$$$$;
After market, will not be factory installed, dealer installed, quality of installation will depend on installer, quality of materials will vary from vendor to vendor,
appearance will not be stock, may be close may not be less $$$.
The functioning may be as good or better then OEM, or it can be worse.
It will almost always cost less and be faster to install after market then OEM.
So how much do you want to pay?
The dealer quoted me and charged me for OEM. And when I questioned them, they said WR Long was actually cheaper, as if it was some kind of benefit to me. Which just made me want it swapped all the more.
I totally agree with you. I did my research ahead of time which is how I noticed that it didn't look right. Definitely not "OEM" like.
One thing I didn't post photos of is how they fed the actual third function valve. The hydraulic line feeding it is attached to the bucket valve under the right rear wheel well, and is sticking out inside and below the fender a lot more than I would like to see. This might have been a non-issue on the BX25 where that valve was up front, but this looks like an accident waiting to happen if something got between the tire and fender.
/ Kubota BX23S third function valve #16
Just a quick note for all, I bought the BX2816 snowblower, and tire chains (H.D. Vbar, not from Kubota). While trying to install tire chains, which are pretty much a necessity for snow removal I was stunned to find out that my 3rd function valve was as yours is, above the right rear wheel under fender. Installation of chains is pretty much a no go as if they could even be installed, they would rip the 3rd function valve out causing who knows what for damage. Beware of this problem before chaining up.
/ Kubota BX23S third function valve #17
The MFG screenshot looks like a diverted button. Hit it and use the bucket functions on the joystick (ie left/right) to actuate. What your dealer put on looks like a 3rd function to me. That said it is easy to tell. If they are tapping into the same hydraulic like for your loader, then it is a diverter.
My M62 has both a button to enable/disable the 3rd function hydraulics and a toggle switch to actuate it. I am guessing turn it off when I dont have a grapple on it to save the additional flow in those lines, but I could be wrong.
/ Kubota BX23S third function valve #18
Few, if any, Kubota 3rd function kits will be factory installed. W R Long, Ansung and CA kits will likely cost less than OEM, but the source of the kit obviously should be discussed at purchase. Care and attention to detail by the installer will make more difference on the fit and finish of the accessory than branding. I wonder what the OP’s sales contract says about the 3rd function.
/ Kubota BX23S third function valve #19
I don't know what the WR long kit cost. Dealer installed my kit (kubota) for (I believe) $1000.00.
I do like the rocker switch vs my two buttons for the operation
3 Point Hitch Attachmnet (A66734)
3 Point Hitch...
2013 FORD F-550 SUPER DUTY (A67714)
2013 FORD F-550...
Year: 2018 Make: GMC Model: Terrain Vehicle Type: Multipurpose Vehicle (MPV) Mileage: 116,222 Pla... (A66738)
Year: 2018 Make...
2018 GENERAC MOBILE PRODUCTS MLT6S (A67714)
2018 GENERAC...
2016 BIGHORN 5th WHEEL (A67714)
2016 BIGHORN 5th...
Fuel Storage Tank (A68134)
Fuel Storage Tank...
