Radio control hydraulic control?
/ Radio control hydraulic control? #1
kiwiguy
Cub Cadet 3205
Has anyone installed radio control on a manual hydraulic valve? Particularly 2 axis joystick control and use standard RC components.
I’m wondering how big a servo is needed in terms of force and precision.
I can do electronics, Arduino etc but don’t want to spend $6K on a commercial 6 valve system of course.
Thanks!
/ Radio control hydraulic control? #2
As much as you probably aren't going to like the answer, your best bet is probably going to be swapping valves for solenoids, which gets even worse if you need to maintain proportional control. A lot more heavy equipment is going to "fly by wire" using these, so the technology is available & proven (and not cheap).
Another possible option would be using linear actuators instead of servos but I'm betting they are going to be too slow to be practical for whatever you're trying to do.
So - sticking with servos; the main issue to deal with is Force vs Throw aka the basic lever principle. The longer the lever the smaller the required force and the greater the throw.
On the valve side longer is good because it means less force & bad because it means more throw
On the servo side shorter is good because it's higher force but bad because smaller throw.
I found a large scale servo rated at 33kg-cm and 60deg Range of motion (This is just a "for instance" to get us real world numbers, I'm sure there are 1/4 scale and larger servos with better capabilities).
Turnigy TGY-S8166M Servo Specifications and Reviews
60 Deg RoM makes finding the throw vs lever arm pretty easy since it's an equilateral triangle (60 + 60 + 60 = 180 so all angles are equal thus all legs are equal length)
The total length of throw will be equal to the length of the lever arm, however since you're pushing / pulling in both directions (30 Deg each way from center) then you get half the throw in each direction.
So - putting real world numbers back in:
33kg-cm means you can generate 33kg worth of force at the end of a 1 cm long lever.
A 1 cm long lever (by properties of an equilateral triangle) gives you 1 cm total throw or .5cm in either direction from center so you can push or pull 33kg for .5cm.
Making the lever arm longer will increase the throw & reduce the force. Thus a 2cm lever arm on the servo would result in 16.5kg force for 1cm in either direction from center.
You're going to have to play around to find the right lengths for both to get the desired operation, and you may even need to engineer one or more intermediate levers to get the right balance of Force vs Throw.
I think I would start by putting a very long lever on my valve and using a spring scale and ruler to measure the required force & amount of throw for every 1 inch of length on the control lever and then work my way backward to what the servo can deliver. I would also see if I could get by without full valve operation / lever throw.
Sounds like a fun project whatever it is. Best of luck.
/ Radio control hydraulic control? #3
I am building a woodsplitter with electronic control. Had to use a D05 directional control valve and subplate. That was the worst extra expense. Got all the electronics from China, and then surplus Industrial control switches.
There is a ton of cheap wireless control equipment on E-Bay from China. I was assembling the stuff to build a wireless hoist and trolley control, and found all this stuff already built on E-Bay.
I am also looking to build a SS mount hydraulic winch with wireless control. Again, I will look to E-Bay.
I found this expensive ultra high torque servo for $289 that will lift 100 lbs!
Invenscience i00600 Torxis Servo 1600 oz.in. 1.5 sec/90 deg
https://www.pololu.com/product/1390
/ Radio control hydraulic control? #5
If you are looking at adding a servo motor to drive a spring center spool will the servo motor allow the spool to return to center if power is lost? If not that function will keep moving which could be a safety hazard.
/ Radio control hydraulic control? #6
Good point.
*Most* servos are fairly easy to manipulate when not under power so as long as the linkage isn't too binding, they should return to center.
Also *most* R/C systems have a built in fail safe that return the servos to a preset position (typically center, but user customizable) when radio signal is lost.
More things to think about before you R/C up anything powerful enough to use hydraulics.
That's pretty cool - a 90 deg sweep will give you more throw as well. Just remember to change up your trig as you now have an isosceles triangle.
For every X in length on your servo arm you'll have roughly 1.4x total throw or .7x each side of center.
/ Radio control hydraulic control? #7
Might as well go all the way. :D
2012 MACK Tender Truck w/ADAMS Rear Discharge Bed Auger (A63118)
2012 MACK Tender...
CATERPILLAR 299D2 SKID STEER (A60429)
CATERPILLAR 299D2...
2017 INTERNATIONAL LF687 DAYCAB (A63569)
2017 INTERNATIONAL...
Bad Boy Stand On Mower (A64047)
Bad Boy Stand On...
(INOP) 2007 VOLVO A35D OFF ROAD DUMP TRUCK (A60429)
(INOP) 2007 VOLVO...
Takeuchi TL6R Rubber Track Skid Steer (A64047)
Takeuchi TL6R...
