Anyone come up with a way to reduce mirror vibration?
   / Anyone come up with a way to reduce mirror vibration? #1
jodebg
New Hartford, CT
Kubota B-2650
Checking to see if anyone has come up with a way to reduce side view mirror vibration?
   / Anyone come up with a way to reduce mirror vibration? #2
You may already know, some types of bug shields on the front will cause this vibration. I put one on one of my trucks and the mirror became useless. I took it off, and no more problem
   / Anyone come up with a way to reduce mirror vibration? #3
This on your tractor?
Where mounted presently?
Generally a mirror needs to be attached to something solid like a roll bar or FEL post.
On a fender or on the engine hood expect vibration.
   / Anyone come up with a way to reduce mirror vibration? #4
A layer or two of rubber where it's mounted will dampen the vibration effect.
The first picture better demonstrates what I did; a gasket cut from a rubber floor mat = zero vibration on my mirror. (despite the green paint-job & JD logo, this is a 'jury rig' mirror)
   / Anyone come up with a way to reduce mirror vibration? #5
Sure, but why do you want to see what's in the ditch behind you:confused: ;)
   / Anyone come up with a way to reduce mirror vibration? #7
You need to change the resonant frequency to something that doesn't match a oft-used engine speed. Sometimes a little weight attached to the mirror is all it takes. I've shot foam into the cavity behind the mirror and that has helped.
   / Anyone come up with a way to reduce mirror vibration? #8
Might add that the longer the supporting arm is the more likely vibration will occur.
The arm length vs the RPM could possibly result in harmonic vibration as well.
   / Anyone come up with a way to reduce mirror vibration? #10
Back in the 1970's when I was running my '59 Harley one of the shops had a poster on how to reduce mirror vibration.
Mount the mirror on the garage wall.
2019 Deere 550K (A53317)
2019 Deere 550K...
Unused 2025 CFG Industrial MX12RX Mini Excavator (A59228)
Unused 2025 CFG...
3410 (A47477)
3410 (A47477)
100amp Battery Charger (A57454)
100amp Battery...
(2) Poulan Chainsaws (A57454)
(2) Poulan...
3 Point Hitch Hay Spear (A57454)
3 Point Hitch Hay...
