Buying Advice 3520R Reliability/Problems
/ 3520R Reliability/Problems #1
Terrapro88
Member
Trussville
1988 Yamaha Terrapro
Hi All!
I am looking at a 2013 Branson 3520R. It has under 50 hours on it and appears to be in very good condition. It would see light use, bush hogging, light loader work hauling dirt for flower and garden beds etc. on my 5 acres and some of my neighbors property on occasion.
My question is, are there any real trouble areas with this model? It only has maybe an average reliability score here on tractorbynet. However, I know that sometimes you mainly get the people that are upset that post the most reviews.
I don't really have any tractor dealers, minus a Kubota dealer about 35min away, that are within an hour to an hour and a half from me. So, I likely will have to haul any tractor a fair ways to get it serviced. I don't have a truck big enough to pull a tractor this size, so I obviously don't want to be hauling it to get it fixed more than one could reasonably expect.
So, has anyone had any experience with this model or the 20 series in general?
Thanks for the help!
/ 3520R Reliability/Problems #2
They are no better and no worse then any of the others, I own one a 8050 it's closing in on 400 hours.It has had it's problems between myself and the dealer its been taken care of.
If it hasn't had oil and hydraulic filters and fluids changed in four years it will definitely need them, short and infrequent uses are hard on fluids.
My major complaint with Branson is the "Factory" Branson USA will not respond to emails, their customer service is non-existent, my dealer is good.
If the area reps and Branson would be more open and conversant I would be more open to recommending the Branson line, also service manuals
are unavailable an IH, Case, Ford, New Holland may be expensive but they are available, Bransons must be top secret.
If you have no dealers for service i would hope that you can repair anything that comes up.
Good luck and enjoy
Thank you for the reply LouNY! I have 2 dealers about 1.5hrs from me. For some reason, I just don't have that many tractor dealers near me. Which I find odd, since I am in a fairly rural area in Alabama. I did have a Branson dealer 5 min from my house when I moved here 6 years ago. I think he was a tractor mechanic and must have just ordered if someone wanted one. He has since retired I believe.
I just don't want to get it and then end up having major problems with the clutch, engine or hydraulics etc. that could cost thousands more to fix on a very low hours machine. Especially, if it is a specific problem that is a know issue.
Thanks Again!
/ 3520R Reliability/Problems #4
50 hours is a major service on Bransons- engine oil & filter, hydraulic oil & filter, front axle oil, air filter. It's not difficult if you're used to oil changes. I have equipment to work on motorcycles, cars and light trucks. I needed my largest filter wrenches and a big drain pan. I ordered the trans fluid from Amazon, got Branson filters shipped to me by my dealer who is 3.5 hours away.
A few people have had problems with front hub seals leaking but the hubs appear to be fairly easy to remove and take to a dealer for the seal replacement. I think there is a recent part update on the seal. There's one guy on youtube who had overheating problems on a new Branson but he wasn't cleaning the radiator out frequently or well enough. When it gets dirty I remove the screen and blow it and the radiators out with an air gun, and blow off the air filter element. If I'm chipping dead stuff (makes a lot of dust) and the wind's blowing the wrong way I may need to clean the radiator after a couple hours.
The engine's a Cummins A series made by Kukje. The one in my tractor appears to be detuned or derated from the equivalent Cummins industrial engine. If that's true it'll be understressed. Some people have used Cummins parts to repair their Branson engines. The fuel injection pump is the common Bosch VE.
Your local retired Branson mechanic might be a good source of information on the local dealers.
Thank You ericm979!
I saw the guy on Youtube with the overheating. There is also a guy that says the engine blew with only 5 hours on it. In cases like that, are those just random outliers, due to user error, a mess up in the assembly process etc. or are these common problems. I have to suspect that they are not common issues. To your point about the hub seals, I think I have seen that mentioned several times. Also, it seems to me that I have seen clutch problems mentioned some with Branson tractors in general. Items like the clutch are what I am most worried about as that is a big ticket item...
Now to worry about parts coming out of South Korea during a war...
I see you list your tractor as a 3725H. I would really like to have the 25 series, but to much $$$ for me at the moment. Especially, considering I only have 5 acres to maintain.
Do the 2013 models have the DPF filter or did that not start until a couple years later?
/ 3520R Reliability/Problems #7
I have a 2016 3520R that I am very happy with. I have used it to bush hog and disc over 12 acres with no problem. It pulls the 6 foot bush hog and the 20 blade disc without any problem. I also have a Woods BH7500 backhoe I have used to dig up stumps and digging a trench for a water line with no problem.
I changed the fluids and filters at 50 hours as required, it was much like performing an oil change on my truck, very easy!
It now has over 72 hours on it with no issues. I'm not sure when Branson started using the DPF filter, I haven't had any problems with it at all. Don't let it sit and idle for long periods of time and keep the RPMs up around 2000 and you shouldn't have any issues.
The 3520R is a real work horse!!
/ 3520R Reliability/Problems #8
I have a 2017 Branson F36Rn, which is the EU version of the 3515R apart from not having the DPF and does have a mid mounted ROPS. It has now 28 hours, mostly of mowing some heavy brush with a 52" mower. So far I'm really happy with it. It runs really fresh and smooth. After 28 hours, the engine oil still looks clear as new.
I have a video of it mowing some light brush. It was actually it's first job. Running a bit slow as I was trying the tractor for the first time. Also I usually go backwards through higher brush.
I will make a skid plate and some sort of bumper for it.
/ 3520R Reliability/Problems #9
Dpf started in 2014 and up went the price with it thank you EPA for deciding how to spend our money.
/ 3520R Reliability/Problems #10
I've had a 4720 for two years now and really like the little tractor. The only problems I have had is fan shroud, dpf stopped up and the front wheel seals have a very small oil leak which I will take care of if it gets any worse. The fan shroud was because of fan being to large and chewing on the shroud but was taken care of under warranty with the help of Mr Bitz and Big Reds the dealer I purchased it from. These tractors don't rely on any type of computer and are simple to work on. I myself think most of the problems people have with these compact tractors is people think their capable of more than their made for. It's not a bulldozer. Might get away with using it for one for a while but sooner or later it will catch up with you. As far as the over heating problem and blown engine with the guy on YouTube he was bushhoging in some kind of enclosed structure and it was extreme dusty conditions (watch the video and you won't believe it) and over heated it. It's like any other tractor or machine with a radiator it gets stopped up with dirt and dust and you will have to clean it. I think they are no worse or any better that any other brand out there. What they are better at is the price. Mine was over 10 thousand cheaper then the orange or green ones that are no more than a mile from me. Take care of it and it will take care of you. My only regrets is I wish I bought the biggest one made by Branson and had a self leveling loader.
/ 3520R Reliability/Problems #11
You mention a few things worth repeating.
These compact utility tractors are not bulldozers and trying to use them as one is a common mistake made by newer tractor owners.
That said whether you are measuring by price or by horsepower, the Branson is the heaviest tractor by a wide margin that you can buy.
The John Deere 3038E (36 horsepower) weighs 2175 lbs. The entire tractor is made by Yanmar.
The Kubota B3350SU (33 horsepower) weighs 1874 lbs.
My 3520H (35 horsepower) weighs 4053 lbs.
That's a pretty huge difference when you're trying to get work done. The adage is to buy the most tractor your money can buy and they're talking about weight (tractor=traction and ballast) not horsepower.
The work I do on my property simply couldn't be done with the smaller and more expensive green and orange machines.
/ 3520R Reliability/Problems #12
Not a fair comparison at all. You can not compare a b series Kobota.
Try compairing a kubota grand L 32hp. My L3240 cab (32hp) weights about 4100lbs and (rop model) is about 3500lbs i think. Its like comparing a ford f150 to a f250 saying they both have the same engine. Just saying you have to compare apples with apples.
/ 3520R Reliability/Problems #13
So I have to compare it with a Kubota that's even more expensive than the first one I compared it to? Both are considerably more expensive than the same equipped Branson, btw.
edit: The model in the larger L series (3901) which is closest to my 35 HP Branson (37.5 HP) similarly equipped (minus my Rim Guard and Finish Mower) is over $10K more than my tractor.
Also according to TractorData, the Kubota L3901 weight 2590-2778 pounds, still way less than the 4053 pounds of the Branson.
TractorData.com Kubota L391 tractor information
To get to a Kubota the heft of the 35 HP Branson 3520H, you would need to get the Kubota L6060 which is 62 HP and costs more than twice as much as the Branson.
TractorData.com Kubota L6:cool: tractor information
/ 3520R Reliability/Problems #14
Fyi. When I receive a load of Branson Tractors and I look at the bill of lading the weights of the tractors are listed as heavier than any specifications out on the internet or tractor data. I had a JD 3032E I took on trade and I'm thinking my 2400 Branson which is 24 Hp could have lifted that JD off the ground it looked so light and cheap. But hey it's green so it sold within a week. I'm just saying that other manufacturers are actually weighing their tractors with full fluids and an average operator of 185 lbs on them.
/ 3520R Reliability/Problems #15
Guess you could say that's ten thousand reasons to consider a Branson. Well at least that's the reason when I bought new I looked at quite a few different kinds and 10 grand is still in my pocket.
/ 3520R Reliability/Problems #16
I don't have a truck big enough to pull a tractor this size, so I obviously don't want to be hauling it.......
LOL, I used to pull my International Harvester 2404 (with an IH 2000 loader!) everywhere with my Ford Ranger :D
/ 3520R Reliability/Problems #17
That's a pretty huge difference when you're trying to get work done. The adage is to buy the most tractor your money can buy and they're talking about weight (tractor=traction and ballast) not horsepower..
100% Spot-On info! :thumbsup:
My Branson 3510i is wickedly overpowered with no additional weight.
I am guessing that with a BL10 Loader is has to be very, very close to 4,000lbs when I bought it.
I soon found out I either needed to use a LOT less power, or add more weight.
More weight has proven to be the best solution.
/ 3520R Reliability/Problems #18
I recently purchased a 3520H with a BH76 backhoe. I used it for the first time to spread 40 yards of hog fuel over an access road I'm building and it worked great. The steel construction of the chassis is really impressive along with the steel fenders and hood. It wouldn't surprise me Branson becomes a legendary brand like Kubota in the future with a price that rises accordingly. Also, future models may have more electronic gadgetry so I'd recommend getting a Branson tractor now if you really want the heavy build quality and mechanical systems.
/ 3520R Reliability/Problems #19
Excellent point about the robust/heavy construction. I looked at a nice used 2014 3520H today, and it's built like a battleship, compared to most competitors, especially Deere. I checked out a Mahindra and it struck me as cheaply finished, which I had heard some other posters say. Although a bit lighter than Branson, I am impressed with LS tractors, which IMO have the best fit and finish of CUTs I've seen. I just found out that a west MI Kubota franchise has purchased property adjacent to the Tractor Supply store north of Holland, and they'll start breaking ground in the early spring. This would be less than 10 minutes from my house, and by far the closest tractor dealer of any brand. I have been looking at the L2501, as well as the Branson 3015 and LS XG3025, and based on features, price, and loader and 3-point lift power and robustness, the Kubota is lagging behind. But with the news of the close dealer, along with an almost rabid fan base that guarantees strong resale value, I'm bringing the K back into the mix. I really do hope that Branson "gets its due" in the future and becomes known as the new tough guy on the block that takes big market share from Kubota, Deere, and the other big names, who rely heavily on their logos and past reputations and use that "perceived value" to charge more money for less tractor content.
UNUSED IRGC80 Battery Powered Golf cart (A55272)
UNUSED IRGC80...
IRET13 ELECTRIC TRICYCLE (A58214)
IRET13 ELECTRIC...
2014 FREIGHTLINER SPRINTER 2500 4X2 CARGO VAN (A59906)
2014 FREIGHTLINER...
LIGHT TOWER (A56857)
207280 (A52708)
207280 (A52708)
2010 International 7400 Service Truck with Crane, VIN # 1HTWGAAR6AJ276531 (A61165)
2010 International...
