deck over trailer
/ deck over trailer #1
gravelman
NH
Kubota 2650
Hi folks, gravelman from NH Im buying a deckover trailer with a 3 foot beaver tail Do not move my tractor all that often but haul other things, thus the deckover. Is there a way to convert the 3 foot beaver tail into flat carrying capacity similar to the rest of the trailer?? Even some type of bar across the back to keep a level deck. Im sure someone has figured out a way. thanks.
/ deck over trailer #2
Why not buy one that the ramps fold up to level out the dove tail or make some that will.
/ deck over trailer #3
I agree, if you haven't bought it yet then get one that the ramps fold over and extend the deck. Some models come with mega ramps that cover the full width, filling in the center space between them.
  • 2017_Big_Tex_Trailers_14GN-20-5_Gooseneck_Flatbed_Trailer_-_MEGA_RAMPS_MKmNRA.jpg
/ deck over trailer #4
I have a 4 foot beaver tail, they make some like above that the ramps fold flat, some have a pop up beaver tail. If needed I was just going to build a ramp out of wood to make it flat. My beaver tail is wood so it’s easy to attach. In order for the ramps to fold flat you need a 5 foot beaver tail.
/ deck over trailer
ok on all of this...too late for the fold up ramps i believe but will look into it.
/ deck over trailer
i have slide out ramps so im going to have to get creative too late for the fold up
/ deck over trailer #7
/ deck over trailer
wow, i never heard of that....sounds very interesting why do i always find out after the fact
/ deck over trailer #9
Get a trailer with some fork pockets in the side of the trailer. That way you can stick the forks in the pockets, release the SSQA and back the tractor away leaving the forks stuck in the trailer for transport. Saves a lot of deck space and all you have to do is throw a strap across them or whatever to keep them from walking out during travel.
/ deck over trailer
ok, thanks for that
/ deck over trailer #11
Why do you say it's too late? Sound's like the perfect solution,just do a little welding to convert the sliding ramps to fold up ramps.
/ deck over trailer
i guess thats what i will do... im not a welder but can get some prices.. thanks
/ deck over trailer #13
If he has a 3 foot beaver tail those are going to be some short ramps.
/ deck over trailer #14
Great idea!👍
/ deck over trailer #15
OK, this may be a dumb question, but how do you get your long tractor and implements on to those folded up ramps if the tractor is already on the trailer?
/ deck over trailer #16
pull up past the ramps then back up. Thats why you don't buy the shortest trailer possible.
/ deck over trailer #17
I'm happy with my new Diamond C power tilt deck over. No ramps or fenders to deal with at all. Adds a few bucks & isn't as low profile. It replaced a way to short 16' gravity tilting deck. Was looking at a 22' gravity tilting deck but ended up with a power tilt deck over. The gravity tilt loaded a tractor better, but sucked for loading anything else. The tilt deck over ends up with a noticably steeper deck (2-3x maybe) when tilted, but I've had no issues loading tractor or impliments yet. Will have to see how it goes when it's wet. Loading anything from the sides is trivial with no side rails or fenders in the way.
/ deck over trailer #18
well-thought question. You'd be happiest when you have stake pockets so you can lock the ramps upright to the stakes when loading long wheeled vehicles. And use the fold-back ramps folded fully back when loading pallets or hay bales.
Another thing we have going on in Holland are liftable dovetails, with a very short ramp. If your vehicle has air suspension you can use the compressed air to lift the tail end with a set of airbags. It cures all disadvantages of either style.
2014 MACK PINNACLE DAYCAB (A59914)
2014 MACK PINNACLE...
KUBOTA M108S TRACTOR (A64277)
KUBOTA M108S...
BRIGGS & STRATTON STORM RESPONDER GENERATOR (A64276)
BRIGGS & STRATTON...
ROAD GEAR ALUMINUM HEADACHE RACK (A64277)
ROAD GEAR ALUMINUM...
2012 PROCCO 130BBL (A65643)
2012 PROCCO 130BBL...
2008 CM TRAILER 14' T/A ENCLOSED TRAILER (A65643)
2008 CM TRAILER...
