Oil & Fuel JD 855 starting issues
/ JD 855 starting issues #1
JD_Sheldon
Hi, well I have had this issue for about a year. Basically the tractor would not start unless I used jumper leads and turned it for about 1 minute. It got progressively worse until it wouldn't start at all. It would crank but not start. I had a tractor mechanic have a look at he thought it was a fuel issue and we ordered a new fuel bowl (as mine was warped). It arrived and I installed it however the issue remained. I then searched the forum and found heaps of great advice and I bled the entire system about 5 times. Still the issue remained. Finally I undid the bleed screw above the mechanical pump (a fuel hose runs from it to the top let side of the pump). It started however as soon as I tightened the screw it stalled. So it starts with the screw undone and as soon as i tighten it it stalls, every time. Any ideas?
the diesel tank is full
I replaced all the fuel lines
I bled the three injectors separately and together
I bled the screws above the fuel bowl
/ JD 855 starting issues #2
My first guess was the fuel solenoid,, after all that cranking. They will overheat, and burn out.
But, then you said there is a way to get it to start.
Any chance you could post a pic like this,
someone could look at it and make sure all the hoses are going to the right location.
/ JD 855 starting issues #3
When the fuel lines were replaced, did that affect the problem better/worse?
Some JDs larger in size had a little restrictor sleeve in the return line, and had incorrect fuel pressure when the lines were replaced as the restriction wasn't obvious, and not replaced.
Not long ago had major issues with JD6420 and that was found out then, but it needed a new injection pump in the end as the FCV didn't appreciate water in the fuel for many months.
/ JD 855 starting issues #4
Just wondering how often you are you cranking this tractor? Does it vary with how long since you last ran it? I have different model 5525 and having similar issue and I have learned to use some WD 40 to aid in starting it and or the pump to prime. Mine is acting like there is a very fine leak letting air into the system as it is more of issue the longer the tractor sits between being run.
/ JD 855 starting issues #5
If opening the bleed off will it get a direct supply of fuel that the injection pump can access by suction? If that is the case there is a blockage in the regular fuel system. Solenoid!, Thermistor if it has one? Shut off switch? Loose wire connection? Fuse?
/ JD 855 starting issues #6
Mm or a blocked pickup in the tank..
I'd start at the start. Pull the pickup out of the tank and see if there's a blocked mesh filter. That will tell you what your girl has been drinking over the years.
Neighbour had fuel issues on a 6420. Amazed the 'mechanic' didn't even check the fuel filter bowls or the pickup when he came to diagnose. He didn't come back. I found his had had a long history of wet and dirty diesel when I checked them. And the restriction in the return line had never been noticed of replaced by the other 'mechanic' that replaced the rubber lines! So it wasn't getting enough diesel, and then the lack of restrictor meant it wasn't keeping it there when it got it
Does your tractor have a lift pump? Anyone know?
That is a good suggestion. I have checked the solenoid and the filter in the bottom of the fuel tank. Both are fine. Now, as for suction, when I pulled the fuel filter out I removed the entire assembly, so the metal top for want of a better term. I did notice that the connection between the fuel line from the tank to the fuel filter assembly was loose and can't be tighten (the inside part of the top where it goes into seems to have worn over time). I assume this would cause an issue on the suction side as it would be sucking air.
This was an issue before I replaced the fuel lines. I replaced the lines hoping it might fix the issue.
/ JD 855 starting issues #9
Hmm good work there. It could well be an air problem if it's loose enough to see.
You would assume that it would be letting the fuel drop right back to the tank if that's the case.
That would certainly cause issues at startup if it has to drag fuel all the way through the system to fill the injector pump, and let air bubbles into the filters and pump.
The tractor we had trouble with, had an electric lift pump with a filter before and after it, so you could leave the key on for a minute or so while it got up to pressure before starting. It would also help with bleeding the injector pump.
/ JD 855 starting issues #10
You might need to replace or repair that worn part. I suspect that's your issue.
/ JD 855 starting issues #11
If that worn connection is on the outside maybe some electrians tape would make for a temporary fix?
Ok, I still haven't resolved the issue however since last time I removed the lift pump and replaced it with a 12v electric pump as I suspected it was faulty. The good news is that I was able to bleed all the way to the injectors. There was no air in there at all. The bad news is that it still took forever to start, so in short problem not resolved.!!! I also replaced the entire filter assembly. Any other suggestions. This is really frustrating.
/ JD 855 starting issues #13
Usually "The Last Mohican" of hard starting that anyone wants to discuss is low engine compression,,
Before I looked into that,, I would drain EVERY drop of the fuel,,
out of the tank, filters, and lines,,
and refill with at least 5 gallons of fuel that is 100% fresh.
My 4105 was delivered with some strange fuel in it,,
I did exactly that, drained every drop, and refilled with fresh fuel.
The tractor became amazingly easy to start!! :thumbsup:
Good advice. About a month ago I only had about 4 litres left in the tank so I filled it up with fresh diesel. Do you think I should drain it anyway?
/ JD 855 starting issues #15
I'm new please advise how to start a new post/thread
Thanks,
Mike
/ JD 855 starting issues #17
My 855 has a sticky fuel shut off solenoid. For some reason if I push the throttle on full it doesn't seem to stick but I hold my hand ready to pull the throttle back as soon as it starts. If I try to start it at say 1/4 throttle it starts but the engine hunts. I can manually pull the solenoid rod back and it smooths but starting at full throttle has seemed to work for now. I know I will eventually have to replace the solenoid.
/ JD 855 starting issues #18
I have the same sticky fuel shut off solenoid.
I turn the key off then get off the tractor and push it to shut the tractor off.
I've never bothered to replace it...some day maybe?
However when I start it everything resets and works fine again till I need to shut it off...
Kind of a shut off issue rather than a starting issue.
2025 16in Tooth Bucket Mini Excavator Attachment (A66734)
2025 16in Tooth...
2013 POLAR TANK 8,500 GAL ALUMINUM TRAILER (A67714)
2013 POLAR TANK...
New/Unused Electric Winch (A65583)
New/Unused...
PALLET OF MEC 8000 PUMP AND V8 ENGINE BLOCK (A68842)
PALLET OF MEC 8000...
HYDRAULIC FLUID TANK (A67714)
HYDRAULIC FLUID...
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A61573)
2021 Mercedes-Benz...
