OP
CharlesBrush
Oldnslo, will check and get you the result.
Charles,
Question:
If you fully raise or lower the boom and hold that function so still trying to move will the curl / dump functions operate?
With the engine off and you engage float the pedal stay in the detented float position? I believe you stated it feels like it does but just trying to understand all the conditions.
I have searched for a good detailed hydraulic schematic with no success. I did find a 108 page hydraulic service document that did not have a good schematic.
Since the loader works under normal lift lower mode The items that are confusing me are:
1) When going into float the engine bogs down which indicates pump is under pressure. Going into float the pump flow should be flowing freely for the other functions like tilt.
2) When in float no other functions work. Unless this is a series circuit the lift spool should not block flow to other functions. (see item 1)
3) If pressure is being built and the boom doesn't move, what spool position would allow this?
At this time I am at a loss what could cause this failure. Everything points towards the control valve but you had it checked out? Possibly dumb question but do you know if the repair shop tested all of the functions on a test bench to confirm operation?
Bobcat does use a series valve, in that fluid returning from lift cylinders does go into the Open Center flow not back to tank like on most tractor valves.
It does sound like the lift spool is not traveling to fully engage float although the detent may be locking in place. The small float detent spool screws into a threaded end of the lift spool. If this detent is not threaded in fully and tight it could lock into detent before the lift spool travels far enough to connect both cylinder ends to return flow.
