336d 4x4 not working
/ 336d 4x4 not working #1
bucktownboy
Buchanan, Michigan
Yanmar
Im looking at buying a 336d . The seller is being up front about the 4x4 not working.
I havent found much information on a common problem for the 4x4 quit working .
I was hoping for a little insight from you guys.
Bucktownboy
/ 336d 4x4 not working #2
Tell a bit more about the machine. What happens when you try to put it in 4wd? Odd noises from beneath? Do the front wheels turn freely and in opposite directions? How are the tires?
Also.....Does it have a loader? Does the powersteering work?
There are only a few things it could be. None are common, but the most likely IMHO would be that one of the two universal joints on the front driveshaft has failed. If that is it, you can just pull the shaft, seal the cover, and use it as a 2WD.
rScotty
/ 336d 4x4 not working #3
The only other relatively common problem I can think of is caused by #31 or #39 in the link below wearing out or breaking off. The symptoms of that are a floppy 4wd shifter lever that doesn't feel like it is doing anything.
4WD SHIFTER ^: Yanmar Tractor Parts
/ 336d 4x4 not working #4
Ahh..right you are. I knew there was something that I was overlooking. And engagement shift is what it was. I've not seen that pin let break, but I have heard of it happening. The problem starts if the tires are worn or wrong size and then used in 4wd on a high traction surface. Yanmars of that vintage DO NOT have a middle (3rd) differential, so high 4wd stresses can build up in the transmission with good traction in 4wd. That makes it very hard to shift OUT of 4wd. Then some unknowing operator muscles that little lever and there goes the pin. If your is hard to get OUT of 4wd sometime don't yank on the 4wd engagement lever. Instead raise the front end and let it the torsional stresses "unwind". With a loader you can even do that as you keep working.
Enjoy,
rScotty
/ 336d 4x4 not working #5
Driving zig-zag in reverse can also unload tension. I've had to do this with old Wagoneers and Willys Wagons. I think its in the Wagoneer owner's manual.
The tractor has a FEL . The seller said he removed the front axles.
Thanks for all the replies
Bucktownboy
/ 336d 4x4 not working #7
Bucktownboy
"removed the front axles..."
Yep, that will do it every time.
/ 336d 4x4 not working #9
Might be repairable at an economical price if gears are good.
Adams 5 Ton Fertilizer Spreader (A63688)
Adams 5 Ton...
RoGator and Terragator Manuals (A63117)
RoGator and...
2023 John Deere 8R 340 Tractor (A63111)
2023 John Deere 8R...
Caterpillar 12H/140H/160H Motor Graders Service and Parts Manuals (A63117)
Caterpillar...
Great Dane Van Trailer (A63689)
Great Dane Van...
2025 Fendt 943MT Vario Tractor (A63111)
2025 Fendt 943MT...
