Buying a used L3430 GST changing transmission fluiid
/ Buying a used L3430 GST changing transmission fluiid #1
perryg114
Member
Huntsville, AL
Kubota B7800, Mahindra 3016
I am in the process of buying a used Kubot L3430 with around 2100 hrs on it. The owner says he never changed the transmission fluid in it. The manual says to change every 400 hrs and I am wondering if it needs to be changed. This is about a $200 process to do. It takes 11gal of Super UDT. Which is about $200 worth. Does it need changing every 400 hrs and is there something I can use that is cheaper and just as good?
He changes the oil at around 100 hrs but I don't think he has done much else. So what else should I be concerned about. I figured I would change the coolant and maybe the front axle fluid.
Perry
/ Buying a used L3430 GST changing transmission fluiid #2
I would be concerned with purchasing a tractor that had "that" kind of maintenance.Could be a huge problem.That tractor is about a 2004(I had a L3130 purchased new in 2004);hours are high for the year also.
If you purchase it;change "all" filters and fluids and hope for the best.I use Kubota branded filters and fluids only.Expensive ,yes but cheaper than a transmission fix.
/ Buying a used L3430 GST changing transmission fluiid #3
I concur to some degree. He's gone 4-5 times over the factory recomendations. What else has he neglected or abused on that machine? Did he even change the hydraulic filters? If not there is probably accelerated wear in that that transmission & hydraulic system from increased particulate matter in the fluid. Did he grease the zerks every 10 hours or at all? If not all the moving parts are going to be worn & sloppy.
Neglecting the coolant will cause corrosion issues & cavitation pitting on the cylinders.
I wouldn't rule the machine out, but demand a substantial discount due to the abuse & neglect.
Super UDT2 is expensive, but worth it. I've never owned a GST, but hear they shift rough with anything else. Only used SUDT2 in my HSTs, hear there is lots of whining & other noise when anything else is used in a HST.
He wants $10k for it with a bush hog, hay spike, disk, and front end loader. I figured it was worth the risk. He used if for cutting hay mostly. I will make sure everything works before I pay him.
Perry
/ Buying a used L3430 GST changing transmission fluiid #5
You are in a warmer part of the country so you will have no problem using any good generic Trans/Hydro oil in a GST tractor. If you have a Tractor Supply, Atwoods or other farm supply near you they carry several lines of Good Universal oils. I have used Traveller Premium Universal Tractor Trans/Hydraulic Fluid from Tractor Supply for many years, under $30 for a 5 gallon pail...
Get a Kubota filter and change out your fluids. KennyV
/ Buying a used L3430 GST changing transmission fluiid #6
I wouldn't worry about it. If it drives fine, can pickup the 3pt with a load, and makes no weird noises, you are probably OK. Last resort is to double-check the operating pressures.
Generally hydraulic fluid isn't suddenly going to go bad. Where it gets problematic is when the fluid gets low enough to cause cavitation to the pump. At this point it is usually beyond the point of just filling it up and not having issues.
There are farmers around here that will go way beyond the "recommended" trans/hydraulic fluid swap, or like in your case, never changed it and of course never have problems. I've helped on plenty of farms, and lots of guys just wait until the machine needs some service then they deal with it.
If it were my machine, since I read the manual, and a tractor isn't something I can afford to replace or work on due to user error, I stick to the expert guide on fluid swaps, that is conveniently listed in the owners manual -- even if it seems unnecessary or wasteful.
/ Buying a used L3430 GST changing transmission fluiid #7
I use Kubota Super UDT2 exclusively in my Grand L tractor. However, "Super" is optional. Buy the tractor, READ THE MANUALS. Fish after reading the manuals.
Don't start fishing on tractorbynet.com from a tractor knowledge base of zero. This is the web.
Some of what you read is worthwhile but you get mostly postulations from those WITHOUT EXPERIENCE.
/ Buying a used L3430 GST changing transmission fluiid #8
To me 10k seems pretty steep for a 34hp tractor with 2k hrs on it and nearly zero maintenance. Does it have a cab? You should know the market better than us but I would pass on that. To many unknowns and 10k could make a lot of payments on something brand new with a warranty.
Brett
/ Buying a used L3430 GST changing transmission fluiid #9
Kubota no longer makes the 'Grand L' L3430.
Kubota current model is heavy-chassis 'Grand L' 3560, evolved from L3430. Price new with FEL $27,500 before sales tax.
I own one.
/ Buying a used L3430 GST changing transmission fluiid #10
I own one.
I'd keep looking than. I have learned my lesson buying used things that were deals. I was constantly fixing things or worrying about it breaking down at the worst time. I order everything brand new and while the upfront cost is higher, my productivity is more, down time is nearly non existent and repairs are on the dealers dime. Sometimes it costs more to spend less
At the very least, is keep looking for a different tractor
Brett
/ Buying a used L3430 GST changing transmission fluiid #11
This is good advice. I can speak from experience I would recommend the Super UDT, it makes a difference. But what do I know, I've only spent half of my career starting in July of 1987 working in Kubota dealerships, and the other half repairing Kubota and other brands of equipment. 😊
Well having to get a loan on a car to buy the tractor. Can't afford $25k for a new one. I don't mind fixing things up. I can do all the work myself. My little B7800 is not big enough for 44 acres and I would have to ferry it back and forth to the property. You can get a used one with even more hours on it than this one with no front end loader.
Perry
/ Buying a used L3430 GST changing transmission fluiid #13
On the GLXX30 series GSTs Super UDT does make a difference in the shifting performance and lockup of the clutch packs. And should be kept as clean and moisture free as possible, it does make a difference.
David
/ Buying a used L3430 GST changing transmission fluiid #14
I'll second what diesel85 is saying. It sounds like a great deal dollarwise. You've seen the machine; does it look to be in decent condition or does it look rough?
Personally I think that oil change recommendations are way too conservative. I've done a lot of machine repairs, and I've yet to see substantial wear due to old oil. From not enough oil, yes....but just from old oil....I haven't seen a problem.
You can get a good 303 rated transhydraulic fluid at the farm store for a reasonable price. Get filters too. Use the type 303 as a flushing oil, run it for 20 hours, and then go with new filters (yes, AGAIN!), drain the flush and refill with whatever transhydraulic oil you want to stay with.
Good Luck & stop worrying so much.
rScotty
It looks used but not that bad. The loader does not look like it was used much. It needs some TLC but appears to be sound. I will drive it and play with all the gadgets. I will probably take the bush hog off it once I verify that it works. I want to look at that PTO shaft. I will also look for oil leaks and other problems that are not easily fixed. It probably needs about $1000 of maintenance. New front tires, all the fluids changed and few parts here and there. He drives it like an old man, nice and slow.
Perry
/ Buying a used L3430 GST changing transmission fluiid #16
On the transmission there is a front, rear and 2 drains one on each side of the reduction gear cases. Just be prepared when the fluid comes out and have a good sized tub for it, got a 15gallon wash tub just for draining.
Also check the front axle, it will use Super UDT or 80-90w gear oil. Fill plug on top check plug on side of axle housing. Got one bevel gear seal leaking on mine that needs replacing so not uncommon.
David
I need to think the tub thing through. I have been using bus trays from Sam's club for oil changes but I think they only hold a few gallons. I would be surprised if they held more than 5 gal. Then you can't lift it.
Perry
/ Buying a used L3430 GST changing transmission fluiid #18
Do not remove all drain plugs at once. Open the highest one first. Drain and empty catch pan into another container(s). Proceed to the next lower one and repeat.
I start with 3 empty 5 gallon pails for the used fluid and follow the above to keep the fluid removal under control.
May want to consider new seals under the plugs.
Are the original hydraulic filter(s) still on it? They would be painted gray... might be interesting to cut them open to see what they reveal.
/ Buying a used L3430 GST changing transmission fluiid #19
The Kubota oil is a plus for powershift tractors and hydro's! There are different oils available but they do not give the same performance!
/ Buying a used L3430 GST changing transmission fluiid #20
I would stick with Super UDT. GST transmissions have small orifices in them require a certain oil viscosity. 4 out of 5 GST's (rough guess based on experience) will not have an issue with some other oils. However, that last tractor will not "like" some other oils. This can cause rough or delayed shifting. I have seen several units that customers put "hy-tran" fluid in and then complained of a rough shift. Replacing the fluid with Kubota fixed the issue immediately. If you do not want to spend the money on Kubota oil, I understand. But at least be aware that if you experience a rough shift condition after the oil change, I would suggest changing the oil to Kubota Super UDT before you turn your dealer loose trying to find the "problem."
Kubota M4700 (A60462)
2023 CATERPILLAR 262D3 SKID STEER (A65053)
2023 CATERPILLAR...
2018 CATERPILLAR 326FL EXCAVATOR (A65053)
2018 CATERPILLAR...
2003 CASE 70XT SKID STEER (A65053)
2003 CASE 70XT...
2002 FREIGHTLINER COLUMBIA DAY CAB (A62613)
2002 FREIGHTLINER...
Steiner 450 (A64126)
