BX22 Light issue
/ BX22 Light issue #1
Snappy BX
Upstate NY
BX22 (sold) B2920
Just acquired a BX22, working on getting back in shape. Installed new headlamp, winker and directional switch (all missing). Headlamps and tail lights work, have power to center terminal for directional (three prong connector), no light at rear. two wires left, go to winker switch (I think, two terminals), no current on either. There is a four prong plug, that I'm not sure where it goes. Blinker module has a plug in it, all fuses test good.
Can anyone help ?
Thanks in advance.
Adam
/ BX22 Light issue
650 views, does anyone have an idea how to resolve my issue ?
/ BX22 Light issue
Thanks for the reply Radioman, have ordered a WSM, awaiting its delivery,
/ BX22 Light issue #5
switch (all missing). [/QUOTE said:
Although I have not had the problem, I'd heard that many BX's have had issues with the electrical switches as they do not seem to be waterproof. So it doesn't surprise me that your's are missing. If your tractor is going to sit outside, I'd suggest you go with aftermarket switches. My BX is a 2003, and it's switches allow water in.
Hope this helps.
Ron
/ BX22 Light issue #6
Hope this helps.
Ron
They are not dust proof either. I started having lighting issues and found the switches packed with dirt. My BX is stored inside so water hasn't been an issue.
Check your email.
/ BX22 Light issue
Thanks for the help, had a bad connection at the 30 amp slow blow, all resolved. You guys rock.
/ BX22 Light issue #8
Check your email.
I had to replace all my switches 2 years ago. Packed up with dirt.
I blame it on the engine fan sucking everything in.
/ BX22 Light issue #9
I just took mine apart and cleaned them up. Pretty easy to do.
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A61307)
2019 Krause...
2011 DRAGON 130BBL VAC TRAILER (A58214)
2011 DRAGON 130BBL...
MORBARK WOOD HOG 3400 XT HORIZONTAL GRINDER (A60429)
MORBARK WOOD HOG...
SET OF (10) ACE CATTLE PANELS W/CONNECTION JOINTS (A60736)
SET OF (10) ACE...
2005 Peterbilt 387 with Wet Kit (A61307)
2005 Peterbilt 387...
ALLMAND LIGHT TOWER (A60736)
ALLMAND LIGHT...
