Oil & Fuel Mahindra 5555 Hydraulic Suction Filter Replacement
   / Mahindra 5555 Hydraulic Suction Filter Replacement #11
Did you have to remove the hydraulic fluid when you replaced the spin on filter. I need to service mine now and also he to clean the strainer. Can you give advice?
You tractor may be different but on mine removing the filter drains almost all the oil so I waited a bit and did both since the manual says to replace the oil at the first 100 hours anyway. Changing one without changing the other is pretty stupid if you ask me.
   / Mahindra 5555 Hydraulic Suction Filter Replacement #12
Not if you get it off and get the new one on quick.... may loose a quart or two
   / Mahindra 5555 Hydraulic Suction Filter Replacement #13
The 5555 hyd filter vert. and as high as the trans case so it looses some but wont drain the tractor.
1538s are horizontal and low which will drain as long as you leave it off.. wont get it all out though
   / Mahindra 5555 Hydraulic Suction Filter Replacement #14
At the very least you'd make a mess. It's stupid to change one without the other so it's best to just do it right and change both. What is the purpose of changing the filter then changing the fluid only 50 hours later? How stupid can they be even suggesting that? Doing that would make you just as stupid as they are. BTW I don't have any tattoos either.
   / Mahindra 5555 Hydraulic Suction Filter Replacement #15
Yeah should prolly not work on a tractor if you don't wana get dirty
The new premium universal oils that are out these days can last well beyond that if machine is kept up right.... swapping the filter is just being sure your getting rid of larger contaminants... and as long as your oil looks good and clean it will be fine..
Now on the changing fluid without filter no I would not suggest that... but between two service dates (mines once a year for main components) as long as my fluid looks good im going to swap a filter and on the next go around change both....
Great Plains Nutri-Pro NT-30 Nh3 Applicator (A50514)
Great Plains...
2019 Nissan Sentra Sedan (A50324)
2019 Nissan Sentra...
2015 FREIGHTLINER CASCADIA DAYCAB (A52472)
2015 FREIGHTLINER...
2014 Brent 1596T Dual Auger Grain Cart (A50657)
2014 Brent 1596T...
1270 (A50490)
1270 (A50490)
UNUSED MOWER KING ECSSCT72 TRENCHER (A51244)
UNUSED MOWER KING...
