Professional Welders
/ Professional Welders
Cord you are running waaaaaaaaaay too cold. Turn up the AMPS!
Here is a stainless steel weld on mild steel. See how the weld flows?
Appreciate the feedback, but you have to reread post #1. My stainless welds look a lot better than these. Contrary to the above, I've actually found stainless to be pretty easy to stick weld. I'm the guy who writes the report to the owner saying they might have a problem and it's time to hire consultant to inspect the welder's work.
/ Professional Welders #12
Cord, I was on the phone when I read your 1st post. After I posted I reread your 1st post, and seen it was not you who did the welding. Sorry about that!:eek:
/ Professional Welders #14
I hope you reported the poor work and the "welder" will get some union hall time practicing. No is no excuse for that poor of a product. There was zero pride in his work he was being fairly compensated for.
Brett
/ Professional Welders #15
Wow! Definitely to cold.. I'm amazed that he just left it that way..
Pete
/ Professional Welders #16
Well, if you dont like my welds, just say so!
Really not my welds, but I do lack the ability to make decent vertical welds. I usually end up welding and grinding and rewelding 2 or 3 times before I get it right. I would never pass a vertical welding test, but have found that by the 3rd or 4th attempt, I am making decent welds. Practice and more practice and I can get it done. I dont pick up a welding rod everyday so I will never be as good as those that do. Most of my welding projects start out looking like crap, but by the time its complete, and I have worn out a box of grinding wheels and burnt up a couple of grinders, I can make them look pretty good.
/ Professional Welders #17
To me it looks like stainless rod is used on regular steel, either way that weld would not pass where I work and the guy would not of passed through the welding school to begin with. Tight hard to get at areas.........try welding on Navy ships, lot of times with mirrors.
/ Professional Welders #18
There are a couple of forums that really look down a long nose at the amature welders out there. Personally, I try to not do this because I've been on the other side as a DIYer enough times. That said, I tend to put the pros on a pedestal and expect something approaching perfection from them. Too often I'm disappointed when they fail to reach that level. This would be an example. Made a site visit the other day and thought I'd check in to see how some structural welding was progressing. The project was to weld some stainless 3/8" plate to some 1/4" angle. The location was very tight and cramped and would suck for welding. The job was outside so the process was stick and the welds were vertical up. Tough conditions. but the welder was a certified professional hired from a union shop.
In all fairness,I've seen average people look down their noses at union welders. I worked at a Sears store near downtown Dallas in the 60s and 70s when several skyscrapers were under construction. The welders would wear their doo rags and little welding caps shopping during lunch and after work. Many sales people would hide in the stock room to avoid serving the welders. I have to agree the welders were generally pretty abrasive.
/ Professional Welders #19
Looks like the same mistake, repeated 8 times. :thumbsup:
I'll never understand, why people try the same thing that didn't work, again and again? :confused3:
But, it seems to be a popular method of failing.
/ Professional Welders #20
I should show you guys my welds. You guys would have a field day. I have now turned on the welder maybe 10 - 15 times total. I’ve managed to stick metal together to get what I need to accomplish done and functional.
I would like to take a class or get some good hands on lessons. Unfortunately when I need something done, it’s fire it up and make it happen and move on.
I’m using a Miller: generator/welder my father in law passed on. It’s a stick and a TON of fun to use. Used it yesterday and today for a bit.
Volvo ECR235CL (A53317)
Volvo ECR235CL...
Great Dane Van Trailer 1989 (A61307)
Great Dane Van...
CASE IH STEIGER 400 HD TRACTOR (A58375)
CASE IH STEIGER...
Case 1020 25ft Draper Head (A61307)
Case 1020 25ft...
JOHN DEERE 750 (A58214)
JOHN DEERE 750...
2023 Unverferth 3PT 6 - FT Perfecta Field Cultivator (A61307)
2023 Unverferth...
