Plowing 2 acres with L2501
/ Plowing 2 acres with L2501 #1
Dog Gone It
TN.
L2501 (4wd)
Im thinking about buying a L2501 Hydrostatic 4wd.
Among other applications such as bushhogging, grading driveway, box blade work, I would also be plowing a 2 acre piece of ground at least twice a year.
I would be using a single bottom plow with R-1 tires.
Anyone see why the hydro trans wouldnt handle this single bottom plowing job just fine ?
/ Plowing 2 acres with L2501 #2
It works for me... and I have R4 tires and not sure about real HP. I think you have a larger engine but rated lower HP.
Thanks for the info.
L2501 is just under 25hp gross.
Also are you plowing in 2 or 4wd ?
Do have experience with both R-4 and R-1's tracking differently in the furrow ?
I cant help but think that traction might be substantially different due to the almost 4 inch wider track of the R-4 not connecting with the clean harder surface (roughly 8 to 10 inch wide) below that is created from my 14 inch single bottom.
/ Plowing 2 acres with L2501 #4
You will be fine, if you select a plow that will fit the limited area around a L2501 Three Point Hitch.
I used a 12" Ford Series 101 two bottom plow behind a Kubota B3300SU/HST with 4-WD. Power and traction with R4/industrial tires filled only with air was not the issue. The Ford Series 101 is a full sized two bottom plow designed for the Ford 8N/9N tractors from 1938. Plow was a tight fit behind the B3300SU/HST and I bent some bodywork metal on the B3300SU. I think there is a tad more room around the Three Point Hitch of a L2501 than around my B3300SU rear but caution in old plow selection is advised.
I use the same plow behind my Kubota L3560/HST where there is PLENTY of room.
HST transfers max tractor power to tractor wheels as tractor begins to move, which is when both plow inertia and beginning of plow suck seeks to ****** tractor forward motion, so HST is well suited to moldboard plowing small plots.
MORE: http://www.tractorbynet.com/forums/attachments/276736-ford-series-101-plow-2-a.html?highlight=
I used a Ford Series 101 two bottom plow behind a Kubota B3300SU/HST with 4-WD. Power and traction with R4/industrial tires filled only with air was not the issue. The Ford Series 101 is a full sized two bottom plow designed for the Ford 8N/9N tractors from 1938. Plow was a tight fit behind the B3300SU/HST and I bent some bodywork metal on the B3300SU. I think there is a tad more room around the Three Point Hitch of a L2501 than around my B3300SU rear but caution in old plow selection is advised.
Im glad to hear there are no issues with the transfer of power from the hyd trans. That was my main concern. Thanks
I keep climbing the fence between R-1's and R-4's.
I know that R-1's have proven better traction but after reading your description of what R-4 unloaded tires can do Im second guessing myself.
/ Plowing 2 acres with L2501 #6
Among other applications I will plow a 2 acre piece of ground at least twice a year.
That will be a lot of rough riding.
Consider moldboard plowing once every five years and the use of some type of conservation plow, such as a Field Cultivator, for twice annual soil preparation. Dirt Dog (brand) APP / Field Cultivators are produced with three tines and up......
LINK: http://www.tractorbynet.com/forums/attachments/339095-dirt-dog-all-purpose-plow.html?highlight=
/ Plowing 2 acres with L2501 #7
I think MUD should determine R1/R4 decision. R1s are fair in mud, R4s are not. On the other hand, most residential tractor owners have the option of NOT working in mud. Farmers sometimes must work in mud.
Second determination should by how much over-the-road use your tractor will have. R1s vibrate on hard surfaces and wear relatively rapidly relative to R4s on hard surfaces in HST/HIGH at full throttle over-the-road speeds.
With 25-horsepower engine in a medium-weight chassis I believe it unlikely you will experience tire spin issues with R4/industrial tires.
Had you 37.5-horsepower of L3901 in same medium-weight chassis tire spin with R4s could be an issue.
My Kubota L3560 'Grand L', like your potential L2501, has low horsepower relative to its heavy chassis.
I think MUD should determine R1/R4 decision. R1s are fair in mud, R4s are not. On the other hand, most residential tractor owners have the option of NOT working in mud. Farmers often must work.
Thanks.
As residential I would be mostly dry and Good point.
No road travel.
Once again you knocked me off the fence to the R-4 side. lol
I Just now was thinking that a loaded R-4 tire would be heavier than a R-1 loaded as well.
Also are you saying that the R-4 are a smoother ride than the R-1's ?
/ Plowing 2 acres with L2501 #9
R4/industrial tires are a much smoother ride over hard surfaces.
Over soft surfaces, where R1 "bars" bite into soft soil, there is less difference.
R4s are marginally heavier than R1s loaded.
R1s yield a slightly wider tire spread than R4s, only for consideration working hillsides.
I am "way out there" in seeking to avoid soil compaction. I have never owned a tractor with liquid filled tires. That means I must carry counterbalance on the Three Point Hitch for any but lightest FEL work.
When pulling Three Point Hitch implements I minimally compact soil/lawns with air filled tires.
I never experience mud where i live in Florida, with perfect draining, porous, sandy-loam soil. This may sound lovely, but I have to irrigate six months of the year.
/ Plowing 2 acres with L2501 #10
I know that R-1's have proven better traction but after reading your description of what R-4 unloaded tires can do I'm second guessing myself.
Measure twice; cut once.
Anticipation is 50% of satisfaction.
Agreed.
I can say that if I do decide on R1's that I will try to go with the more expensive radial rather than bias.
Thanks
/ Plowing 2 acres with L2501 #12
If money is not too much of a concern, switch your consideration from a L2501 to the smallest Kubota Grand L, the L3560.
Why be just happy on a Kubota L2501 when you can be ecstatic on a Kubota Grand L?
/ Plowing 2 acres with L2501 #13
I had an L2500 4wd gear shift that I used run a single bottom plow with and it did it with ease. I kind of had buyers remorse after getting the plow because it could easily handle a double bottom like an older style Dearborn plow that was used behind the old Ford Ns with ease. Turning dirt with a single bottom plow takes a long time.
I originally had R3 tires but later transitioned to R1 ags and it literally doubled the performance of the tractor especially when pulling the 6.5 double gang disc. With the turfs I would occassionally get stuck and have to lift the disc and drive out (never buried the tractor) but with the ags lack of traction in 4wd became a non-issue. I had the rears loaded and the bar marks on the lawn would only usually last about a day. It's not that heavy of tractor. I've used R1, R3 and R4 in small scale farming and R1 one beats the other two hands down when rolling dirt. So much that a lot of times I don't even run the tractor in 4wd because it's not needed. With R3/R4 it's not an option, If you are running a disc or a plow your going to need it in 4wd.
/ Plowing 2 acres with L2501 #14
You'll be fine just take your time hogging and plowing.
/ Plowing 2 acres with L2501 #15
4 wheel drive only, for sure...
For these L's, I think they have been talked about before on here. R-1's set out to it's widest settings is equal to what the outside measurements are for R-4 tires.
/ Plowing 2 acres with L2501 #16
I (and many others) have plowed with 2wd old tractors with 20-25 hp. My farmall 200 has 20hp at the drawbar and will handle a 2bottom, although it weigh a bit more.
Thanks for all the great help and replies.
/ Plowing 2 acres with L2501 #18
Never had R4's so cant comment on that. But couldnt imagine plowing that much ground with a single 1-bottom.
As cheap as used plows are, consider a 2-12 or 2-14 plow. My old L3400 with R1's pulled one with ease. I cant imagine r4's making that much difference in conditions that are right for plowing (dont plow a swamp).
/ Plowing 2 acres with L2501 #19
You stated you are going to plow this field twice a year. Has it ever been plowed before? If it has not been plowed, I suggest hiring some HP for the first turning to break it up. You may well be able to run more than a single bottom plow after that as the ground will probably be much more workable.
Is the plan to turn in the spring then plant your annual crop then turn under in the fall?
/ Plowing 2 acres with L2501 #20
Any first plowing will be the most difficult;after that it should be fairly easy.New areas;I would bush-hog then spray with Round-up and bottom plow.Two acres is really not that big;a simple single bottom will do it and be easier to set-up.Yes it will take some time but doable.
You shouldn't have to plow deep after the first time;we use a field cultivator on broken ground.We also have a roto-tiller and use that when needed.We work 10+ acres per year.
