Rock Auger for a Compact JD
/ Rock Auger for a Compact JD #1
nathan8804
I would like feedback from anyone that has or seen someone using a rock auger for a JD compact tractor. I have a compact 4010 with a land pride pd10 post hole digger. I would like to know if one can attach a rock auger to a standard post hole digger? And if so would my 4010 drill a hole to install t-post. I have clay were I do have soil the rest is just soild limestone covered with 2" of dirt. My current auger does make a small hole with the tip of the auger but does not bit down into the rock. I know I also need to install a down pressure kit. thanks /forums/images/graemlins/smile.gif
/ Rock Auger for a Compact JD #2
I have been looking at PHD and one of the local guys suggested that, with our hard ground, I look at one that attaches to the bucket. It's a few more dollars and does not require a down pressure kit. You might look into that as an alternative.
http://www.gearmore.com/Dan8200.pdf
Mark
/ Rock Auger for a Compact JD #3
If you're attempting to drill into limestone, you may need to rent a jackhammer and compresser. The good news is you shouldn't need to drill very deeply into the rock.
/ Rock Auger for a Compact JD #4
I have a Yanmar 1610D which is not a large tractor. I run a heavy duty post hole digger with a Pengo aggressor auger. I can drill through clay and rock pretty easily. Shale and solid rock are the only things that I cant drill through easily. If I had a carbide step bit I think it would go through the shale more easily. It gets centered on the tripple tip and you have to keep rocking the post hole digger back and forth. A rock head would certainly go through rock and solid concrete.
2006 TROXELL 150 BBL ALUMINUM VACUUM TRAILER (A67714)
2006 TROXELL 150...
PORTA POTTY (A68842)
500 BBL FRAC TANK (A67714)
500 BBL FRAC TANK...
2006 W-W TRAILER 20' T/A ENCLOSED TRAILER (A67714)
2006 W-W TRAILER...
2017 CATERPILLAR 316FL EXCAVATOR (A65056)
2017 CATERPILLAR...
2014 Ford Transit Connect Van (A61573)
2014 Ford Transit...
