Pole building item. Is this a thing?
   / Pole building item. Is this a thing? #1
POC
Gold Member
Southern Indiana
Mahindra 3215 4x4
I'm wanting to add a machine shed lean-to on the back of my building. Do they made some kind of trim that will run up the wall of the building above the shed roof that will keep water from running down the wall and between it and the roof of the machine shed?
   / Pole building item. Is this a thing? #2
Steel building?
If so, you will need to cut a nice straight line in the existing steel wall, and slide flashing up under the steel..
Flashing should go up under the existing steel at the cut by at least 8".
Use a high quality silicone sealer as well
   / Pole building item. Is this a thing? #3
To answer your question, yes, they make a flashing called end wall flashing for metal roof. As fried said above, if you aren't going to the eaves you will need to cut the siding. You could always have some custom flashing made.
2010 MULTIQUIP 25KW GENERATOR (A55745)
2010 MULTIQUIP...
2017 Peterbilt 348 Hood 7000 Grapple Truck (A55973)
2017 Peterbilt 348...
Wagon Wheel Rocking Chairs (A55758)
Wagon Wheel...
2017 Freightliner Bucket Truck (A55973)
2017 Freightliner...
2007 Amkus Rescue System (A56857)
2007 Amkus Rescue...
2015 Freightliner Derrick Digger Truck (A55973)
2015 Freightliner...
