How badly did I break it?
/ How badly did I break it? #1
Danger18
Calhoun, GA
2015 LS XR4046HC
While crossing a fairly steep ravine, to see if I'd be able to cross with the bush hog attached later, I bottomed out pretty badly on my 3 point lift arms that I had left down when I dropped off the bush hog. I heard a loud report, which I shrugged off when it climbed right out. I later found that I could not raise or lower the 3 point. Called a dealer service tech and he talked me thru a few checks. I backed off the raise/lower speed knob and heard the lever move. I then found that one of the stabilizer bars was bent around 20 degrees. I straightened it in a press and put it back on. Everything worked normal again. I picked up the bush hog, climbed the ravine with no problem and then bush hogged a quarter acre. Just as I finished up the pto shaft stopped on its own while the switch was still engaged. I don't have a service manual, and can't find one online. 2015 xr4046hc. I found the pto 15 amp fuse blown. Used a multimeter to check the switch, and then the pto solenoid after taking it off. I'm assuming the dead short reading is correct to show it's good. Also checked the pto relay. I let things cool down then went out to tinker with it. I put a new fuse in and engaged the pto switch and the shaft started to turn, maybe half a rotation, and then stopped. Weird thing was it didn't blow the fuse this time. So now I'm thinking the loud bang I heard was internal breakage from when I bottomed out. That, or the solenoid can't be good. Any ideas?
/ How badly did I break it? #2
Parts manual is available at partsforlstractors.com. Might be of use.
/ How badly did I break it? #3
Check with your dealer for the service manual.....they might provide you a pdf version for free. Several other forum members have been successful with this request.
/ How badly did I break it? #4
Maybe this can help troubleshoot.
  • LSptotest.pdf
Thanks monkeyduster. Ordered the solenoid/valve assembly and a service manual this morning. Fairly certain there is no internal damage. Pleasant surprise paying 75 for the manual and not 299 listed online for other manuals.
2021 CATERPILLAR 745 OFF ROAD DUMP TRUCK (A62129)
2021 CATERPILLAR...
John Deere 568 Mega Wide Plus (A60462)
John Deere 568...
2023 Unverferth 3PT 6 - FT Perfecta Field Cultivator (A63688)
2023 Unverferth...
2022 CATERPILLAR 299D3 XE SKID STEER (A64279)
2022 CATERPILLAR...
Dvorak Model 3072A Hydraulic Ironworker S/A Towable Trailer (A59228)
Dvorak Model 3072A...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
