5093E cab A.C. question
/ 5093E cab A.C. question #1
1Lawman
Joaquin, TX
2012 John Deere 5093E
My 2012 5093E is in the shop for the third time to have the expansion valve replaced..Any ideas what may be causing them to fail?
/ 5093E cab A.C. question #2
My 1st guess would be inferior quality parts built in a foreign country.
/ 5093E cab A.C. question #3
Have they put a new dryer on? Or any other parts besides the expansion valve?
/ 5093E cab A.C. question #4
Shouldn't be going through expansion valves like that. I've never had that happen. Something else is going on. Hope they figure it out.
Tractor is back...I guess I just expect too much..Temp here yesterday was 93..Air vent temp was 57..John Deere tells dealer that generally speaking if vent temp is at least 30 degrees below ambient air temperature that is all they require of dealers..This tractor pulls more air through the outside vents than the inside vents so I guess that's about all it's gonna do but on a 100 degree sunny day that cab is like an oven and air vent temp of 70 is not gonna keep me from sweating..I guess that's why I see so many tractors with tinted windows.. Pretty disappointing for a $50,000.00 tractor..
/ 5093E cab A.C. question #11
does your Deere have a recirc mode?
occasionally I will use my tractor in the recirculation mode to get it cool down some,
then switch back for fresh air and at times I can open my rear window a crack and it will actually
cool better then being all closed up.
/ 5093E cab A.C. question #12
How much to tint the windows?
No....it has a "Purge" mode which is the highest speed but it still uses outside air..
2004 Ford F-550 Single Cab Flatbed Truck, VIN # 1FDAF56P94EC72605 (A65563)
2004 Ford F-550...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
(INOP) 2013 MACK ELITE LEU633 GARBAGE TRUCK (A62130)
(INOP) 2013 MACK...
2013 Felling 25' x 102 Tag Trailer (A62613)
2013 Felling 25' x...
16in. Skid Steer Track (A65640)
16in. Skid Steer...
New/Unused landhonor 5 Gallon Vacuum Cleaner (A65583)
New/Unused...
