hydraulic problem
/ hydraulic problem #1
BullCreek
I've got a JCB Midi CX tractor/backhoe back in 2009 - solid machine. I ordered a hydraulic brush mower a little over a year ago and have slaughtered many acres of blackberries and 8-10ft scotch broom with it. I just used the auxiliary hydraulic connector on the front of the loader to run it (this would be the same connector that would run the pincher on a grapple, etc. 1/2" Parker style couplings). I just bungied the lever when I was mowing. Recently, the valve has started restricting flow and pulling the tractor down if I bungie it. I changed the fittings around and if I bungie it forward instead of backwards like I had been, things still work fine, but I fear I have damaged the valve and will probably damage it going the other way if I continue. A few questions come to mind:
1. Anyone heard of something similar - those hydraulic mowers move a lot of fluid, and even with the large oil cooler my tractor has, I'm wondering if the heat/flow damaged the valve over time?
2. How hard are valves like that to replace - costs, etc? I could take it to the dealer, but I think they kind of sold JCB as fad, and are no longer too keen/knowledgable enough to work on them or mess with getting parts from England.
3. A better solution might be - on the back of the tractor, once you remove the hoe, is a 25HP hydraulic PTO motor that secures with just two bolts - you turn it on and off with a toggle switch. Frankly, I'd like to move/replumb that to the front because it is already 3/4" or equivalent metric size hoses and it is probably rated for the heat, because the flow on that PTO motor is probably similar to the flow on the mower motor (correct me if you think I'm wrong on that). I could mount the PTO motor on my existing PTO skidsteer plate by welding a bracket for it on, and be off to the races - no more having to remove the backhoe to use my tiller! Only downsides I see are:
a) to do it right, you'd probably want to bend some steel tubing and route it down the loader arms - that is how the existing auxiliary is done - who does this sort of thing?
b) the fittings on everything JCB are metric and usually weird - which might present a challenge extending the existing hoses and/or buying new hoses.
c) I might have to take the cab off to get at the hoses to turn them from running to the back of the tractor to the front although I think the hole under the floor boards may be big enough to get in their with the requisite amount of cussing and busted knuckles.
Anyone have good advice how to proceed? Option 3 will probably be more trouble - but is appealing to me because it would probably be the "right" solution and I'd never have to take the hoe off/on again.
/ hydraulic problem #2
First thing I would suggest is replacing the flat face quick disconnects. These can wear out over time causing a partial restriction which is exactly what you are describing. You also state that it works in the opposite direction which supports a failing quick disconnect.
/ hydraulic problem
You were right on the money - I had tried my grapple and it behaved the same but I never thought about it could be on the tractor side other than the valve. I unscrewed the tractor side couplers, and low and behold I found this in one of them:
I'm thinking there used to be a "c" ring that held that thing in the middle of the flow but it came off which allowed it to crash down on the coupler entrance totally blocking the flow. Let's hope my filter caught that clip. I put the couplers back on and everything seemed back to normal in either direction. Does that piece serve a purpose - will it hurt anything to leave it out?
/ hydraulic problem #4
You could also have a hose coming apart on the inside. Happens a lot with suction hoses, but it could happen in the high flow return hose.
Edit: You posted the cause while I was typing. Glad you found it.
/ hydraulic problem #5
Bullcreek
I believe that piece is what seals or blocks the flow in the quick disconnects when uncoupled so not sure that it will not leak when you disconnect them
/ hydraulic problem #6
Bullcreek
It could possibly allow that hose to drain, if that's what the part does (if it's a poppet.) In that case, if the valve is actuated without an attachment, fluid will flow freely.
And it could be a "left over" part floating around in the system; it's been known to happen. (We used to regularly remove beer and wine bottles from the doors Fiat automobiles in the 1970s, when a customer complained of a rattle.)
Pallet of Four Pivot Wheels & Tires (A62177)
Pallet of Four...
2007 Ford Crown Victoria Sedan (A61574)
2007 Ford Crown...
Miller Millermatic 212 Auto-Set MIG welder (A63689)
Miller Millermatic...
2023 Posi Track RT25 Compact Track Loader Skid Steer (A61572)
2023 Posi Track...
Athey 7-12D Force Feed Loader (A62679)
Athey 7-12D Force...
2010 Deere 318D (A60462)
2010 Deere 318D...
