TimberHole
- Joined
- Jul 17, 2017
- Messages
- 524
- Location
- Missouri
- Tractor
- JD9504WD w/ 75 Loader, JD345, Bobcat S150
I have a friend that just bought a JD 1050 with an engine problem. The tractor will idle but when the throttle is advanced to about 1200 rpm's it rattles, blows lots of black smoke and quits. The 1050 is a turbocharged tractor.
Things done to date:
1) Injectors checked by qualified shop and they checked good.
2) Disconnected the intake at the manifold to verify there isn't an air restriction.
3) Verified the return lines are open.
4) Verified the thermostart system isn't leaking extra fuel into the manifold.
5) Verified the compression is good (Over 400).
6) Intend to run the engine on an alternate fuel source but not done yet.
I think we are down to the injection pump or the turbocharger. I think it would be a good idea to verify the injector pump timing but we don't have any reason to think it's wrong. The pump doesn't look like it's been messed with.
Is disconnecting the air intake at the intake manifold a valid test? Will a turbocharged diesel run correctly with the turbo removed? I think this is a valid test but I do not completely understand the relationship between the fuel flow and the air intake, especially considering this is a turbocharged engine.
Does anyone have any thoughts on this problem? We are trying to be systematic but neither one of us has any real experience with the turbocharger.
