Lk3054 tractor splitting questions
/ Lk3054 tractor splitting questions
Well talked to the dealer today and they said only way to replace those thrust washers is to tear the engine down and pull the crank and set in new thrust washers..... Not what I was hoping to hear
/ Lk3054 tractor splitting questions #23
If you have the time, you certainly can accomplish the task. Honestly, you already have the tractor split, which I would consider the hardest part. I would buy no parts just yet, and take the engine apart. Find everything it needs, as their may be a few other parts beyond crank/connecting rod bearings and a gasket kit. If you have the time and the coin for parts, this could be a great experience, though maybe not one you intended on having right now.
Have you determined yet if you're going to tackle this yourself?
Yes im going to do it all my self im a compressor mechanic in the oil field by trade so this shouldn't be to bad of a task alot smaller of a crank and bearings then im used to haha this is my first time splitting a tractor and dealing with this type of setuo
Only real concern is price of repair vs the worth of the tractor. if there's any crank damage I think I'll be sitting on on big pile of scrap
/ Lk3054 tractor splitting questions #26
I work in the oil field as well, I'm offshore right now actually. We just went through a 24,000 hour overhaul on one of our 8 wartsila W26 V16 engines.
Heres a photo of all the A bank pistons set aside.
Well, as a fellow oilfield worker, I need to send you a PM, I've got something you may find handy for this project.
/ Lk3054 tractor splitting questions #27
Johnwayne07, any verdicts on your engine?
Hey guys I tore the engine down to find all three of the main cases were trashed both sets of thrust washers had fallen out good news was the crank was fine. Put all new seals and bearings in the engine. Just waiting for the clutch to come in took forever to get a answer on the clutch. Found out the clutch was junk and not repairable so had to order a whole new clutch witch will hope fully be here by Saturday. This whole project has turned into one new part at a time seems like every time I look at something or break into something im ordering a new part and word to the wise never ever buy a throw out bearing thru Kioti I got absolutely taken when I got my bill I noticed they charged me 135$!!! For a throw out bearing my clutch builder told me he could get it for 40$!!!!
/ Lk3054 tractor splitting questions #29
Always a can of worms when opening an old motor. Once I find a month to set aside for a rebuild, I tend to enjoy it much more from the beginning assuming i will find many things to replace. Hard part is the money and cleaning.
Sounds like you are almost ready, Best of luck! :thumbsup: Let us know how it goes!
/ Lk3054 tractor splitting questions #30
I suppose that is the one stop short of the worst-case-scenario you were dreading. Bad luck to find the Mains needed replacing as well. At lest you know you have a near-new bottom end after this.
I'd return the TO Bearing to the dealer and let your clutch guy supply the $40 item while you still have in the packet, if you can.
Well guys I got her all back together and running yesterday have about 2 hrs on it and so far so good I may take my injectors in to get tested just as a peice of mind... But after this whole ordeal im thinking it's time for a Kubota the parts issues I ran into with Kioti was a nitemare!
/ Lk3054 tractor splitting questions #32
'Well' done! (Pun intended) :)
I like the look of your service truck in the background. We have nothing that big on our roads really.
We have to have big trucks with on board air, cranes and enough tools to swap out these engines, but man those big engines are a less pain in the ***** then this tractor was hahaha
/ Lk3054 tractor splitting questions #34
I can believe that! :drink:
2018 JOHN DEERE 650K LGP CRAWLER DOZER (A65053)
2018 JOHN DEERE...
2011 FORD F-150 (A65643)
2011 FORD F-150...
LOT OF SCRAP IRON AROUND CEDAR TREE (A63291)
LOT OF SCRAP IRON...
Landhonor Quick Attach Seeder (A66285)
Landhonor Quick...
2016 Volkswagen Jetta Sedan (A61569)
2016 Volkswagen...
2022 EZ-GO ELITE...
