max 24 wont start
/ max 24 wont start #1
MadMax24
League City Texas
2015 Mahindra Max 24
Hello everyone , new member here
Got a 2015 max24 with 25 hrs on it , wont start , blew black smoke at first , fuel smelled like thinner so i changed the filter and drained the tank , filled with fresh diesel, spins over good but no start ?
Fuel stop solenoid ? or Glow plug problem ?
/ max 24 wont start #2
Was it running at all before changing the filter & fuel?
Did you bleed the fuel system after changing filter & fuel?
When cranking the engine over do you see any white smoke exiting the exhaust?
Can you test (Do you know how to test) power to the GP's with a Multi-meter or Test lamp?
/ max 24 wont start
Wasnt running before , it would spin over and belch black smoke, I can test the glow plugs when i get home from work, if there ok should i crack the injector lines and spin it over until it burps fuel ?
No white smoke .
Thanks Spanner
/ max 24 wont start #4
Yes test GP's.
Black smoke kind-of implies fuel solenoid is allowing fuel through but it wouldn't hurt to bleed the injection pipes anyway.
Can you apply a jumper battery to enhance the cranking speed also?
/ max 24 wont start
Yes test GP's.
I was thinking fuel solenoid , seems they had a problem with in the past ?
Will do the burp test on injector lines tomorrow . Fluke meter read good on glow plugs.
i can hear the solenoid click for a second when key is turned on ?
I'm an old fart , this is my first tractor , but the little diesel looks simple , I restore old cars on off time , gas motors are a breeze to me , probably overcomplicating it ?
Thanks Spanner
/ max 24 wont start #6
Mitsubishi built machines don't require bleeding air from the lines.
/ max 24 wont start
Just read that in the owners manual , some type of self purge system on these little Mitsubishi engines.
I'll look at it again tomorrow , hanging sheetrock today from Hurricane Harvey damage .
I'm leaning towards fuel solenoid , will pull and test it .
Thanks Pilgrim
/ max 24 wont start #8
Thanks Pilgrim
Electric lift pump? Self-bleeding to the IP. ?
If you're getting 'black' smoke surely that's burnt fuel? White smoke is unburnt fuel, Either way it's fuel. So why do you suspect the solenoid?
/ max 24 wont start
sorry about the late response , working nights now .
The only thing left in the fuel system is fuel stop solenoid and a small gold colored canister I assume to be a purge canister ?
My thinking was the stop solenoid opens wide open for start then cuts back half way to run position ? messed with it a little bit yesterday between mowing grass and hanging sheetrock , would puff a little white smoke and the fuel solenoid would get hot to the touch , Am I all wrong here ?
/ max 24 wont start #10
No, You're on the right track I think. Hot is not good.
You have Glow-Plugs so your solenoid is just Open/Closed. 1/0. On/Off. Run/Stop.
You may have either 2 or 3 wire connection. If 3, one is an earth/ground. The other two - There are two coils inside: High current for 'Pull' to pull it Open. Low current for 'Hold' to hold it open after it has Pulled against the 'Close' spring.
I don't know about gold canisters.
/ max 24 wont start
i'll shoot you a pic of the canister this weekend, these dogwatches wear me out .
I think its the purge canister because its tee'd into the vapor return line from fuel filter housing back to the fuel tank ?
It's got two wires on it , will throw the fluke on it this weekend , all the fuses are good in entire fuse block and both 50 amp fuses test good.
Fuel solenoid has a white and blue wire with 11.2 volts at terminal.
Fuel routing is from tank -filter-thru canister-to pump - to injectors .
Glow plug is bus or rail type with one hot wire on end, tested 11.5 volts at each glow plug terminal.
Holler at you this weekend on my days off .
Thanks Spanner
/ max 24 wont start #12
Hmmm. How many volts directly across your battery terminals?
Which wire of fuel solenoid has the 11.2v and when? (Key Off/On/Start/?)
We know your GP's have a single wire but where does it come from (double checking here) and when does the 11.5v appear ( key same as above ) ??
/ max 24 wont start
Finally got a day off
If you need a good laugh read this , turns out the gold canister is the booster pump to prime the main fuel pump , cracked the injector lines , no fuel, cracked the main fuel pump outlet lines, no fuel , booster pump discharge line ,no fuel , got fuel to booster and booster sounds like its working on tractor and bench but will not pump, lines to it is not clogged , dealer wants $140 ordered one on ebay for $8.99 seems there a popular item ?
did I tell you this is my first diesel ?
Thanks Spanner
/ max 24 wont start #14
Your experience will help others in the future so all is not wasted.
If. in the future "you" are reading this please thank "MadMax24" for his effort.
:cool:
/ max 24 wont start
:cool:
Snail mail dropped off the ebay pump last night ,took about 5 minutes to hook up , Tractor runs great
Dealer wanted $149 for pump , the ebay pumps are $8 bucks each , same pump , also for info ,Jegs sells a better pump for $23 under Autobest name brand for $23 , hope this helps someone in future ?
Thanks Spanner and every one that chimed in
/ max 24 wont start #17
I have a Max24 with a different 'failure to start' issue. I used it 2 days ago, with no issues. Today, the starter will not engage. Good power to all other systems, lights, turn signals and glow plugs. I checked the fuse block and found no fuses blown. I thought possibly it might be an out of adjustment clutch linkage so I tightened the linkage about 2 full turns but, still nothing. I checked the seat safety switch which seems to be working. I even jumped them out to make sure and still no power to the starter. I'm stumped.
UPDATE:
I found a youtube video that showed not only the 2 safety switches that I was aware of but, 3 others. It is here:
It was quite informative.
Lo and behold, apparently, I bumped one of the PTO levers when dismounting........ after checking them, boom, ignition.....
Live and learn........
2016 Etnyre Falcon Live Bottom Trailer (A62613)
2016 Etnyre Falcon...
MURRAY PUSH MOWER (A58214)
MURRAY PUSH MOWER...
2025 Hydraulic Trencher Skid Steer Attachment (A61567)
2025 Hydraulic...
2012 INTERNATIONAL PROSTAR+ (A58214)
2012 INTERNATIONAL...
Year: 2014 Make: Chevrolet Model: Silverado Vehicle Type: Pickup Truck Mileage: Plate: Body Type: 4 (A55852)
Year: 2014 Make...
4022CFL (A59228)
4022CFL (A59228)
