Category I Isn't Always Category I??
/ Category I Isn't Always Category I?? #1
CADplans
Elite Member
near Roanoke VA
584 IH 4WD
I have heard of limited CAT I, but,, otherwise, I thought CAT I was CAT I.
Not so,,
I purchased a Woods RD72 mower last weekend,, to use behind my CAT I equipped JD 4105.
I unloaded the mower, backed up the 4105, checked the PTO length,,, and then connected the mower to the tractor.
When I lifted the mower, this is what I found when I rotated the gauge wheels.
The previous owner told me one of the gauge wheels had been bent,, I think this is what caused it.
The Woods manual says if this interference occurs,, move the rear tires to eliminate the interference.
That ain't happening,,,
I decided I would move the mower back with a couple bracket extensions.
That seemed it would be easy enough,, NOT!!
I fabricated a couple extensions,, 3/4X4X10 inches.
I drilled 2 hole 6 inches apart,,
Then I bolted the extensions on,,,
The first time I lifted the mower with the extensions,, I think the gauge wheel clearance was even worse!!
Then,, I rotated the extension,, and lifted again,, better.
I rotated the extensions some more,, even better.
Finally, I found what seemed like the sweet spot.
With the mower all the way up, I have about 3 inches of clearance between the tractor tire and gauge wheel.
The mower seems to be located in a nice spot for mowing,,,
but,, I will have to wait for the Harvey rain to pass before I can give it a test.
I guess I have learned,, CAT I is not always CAT I.
LOL!!
/ Category I Isn't Always Category I?? #2
Cat 1 is Cat 1 but your tires are too big. :D
Bruce
Bruce
Actually, I kinda think that is true.
The tires they put on this tractor are enormous, compared to the rest of the tractor.
But,, I think the previous owner had a similar issue with his Kubota,,, :eek:
/ Category I Isn't Always Category I?? #4
You bugger! :) All this time you've had a 4105 and never mentioned it.
/ Category I Isn't Always Category I?? #5
My old Kubota had shorter arms on the rear lift than on a Ford 8n. Some of the Dearborn stuff ended up to close also. Your repair seems well thought out.
/ Category I Isn't Always Category I?? #6
I wonder if a quick hitch would have pushed it back far enough?
I have a quick hitch, and considered that route,,
I needed chains, etc substituted in at the top link, so my first try was the extension brackets.
Removing the brackets only involves 2 bolts,, so I may yet try that.
The other reason I did not try the quick connect first was that it looked like I needed more like 6 inches.
The quick connect would only move the mower 4 inches.
I picked the 4105 up this spring,, it is a nice tractor,, but, it is no IH 584,,,
The 4105 gets to do important tasks,, like moving the grandchildren,,,
and hauling the grandchildren's race car,,,
:D
/ Category I Isn't Always Category I?? #9
:D
Both noble tasks! :)
/ Category I Isn't Always Category I?? #10
In fairness, cat 1 just refers to a handful of hitch measurements, and pin diameters. Just enough to make sure it will physically hook up.
Beyond that, it's a crapshoot. It's up to the implement mfgs to make something useful that won't interfer with the rest of the tractor.
Looking at your lift arms, and how far behind the wheels they extend.....I'd say by my eyeball that looks about normal.
And that in this case, the implement mfg should have done better.
Alot of cheap blades and landscape rakes, especially over 6'....won't allow you to rotate the blade 180 degrees without hitting a tire either
I was not unhappy with my mower purchase,,
like you mentioned, there have been back blades that could not be rotated 180 degrees.
I was a little surprised that a company like Woods left the customer out in the "forest", in a situation like this.
I was watching YouTube videos on finish mower connecting,,
one of those videos showed the mower had extendable arms on the mower.
My JD390 flail connected nicely to the 4105, but, I was a little concerned about the weight of that mower,
this Woods mower seems to be more in the weight range of the 4105's aluminum rearend.
Oh, yea, when I was considering adding the 390 flail to the 4105, I thought about adding front gauge wheels to the flail.
I did not attempt to add the wheels,, it looked like there would be clearance issues!! :eek:
:laughing:
