Grading 2555 Died & Won't Start
/ 2555 Died & Won't Start #1
SethWilliams
Middle TN
Massey Ferguson 4243, Mahindra 2555
for several hours this afternoon, she suddenly died on me. I was running a box blade down my driveway and it cut off. I popped the hood and checked all connections to no avail. I did, however, see a puff of smoke coming from what I now know is the starter. The starter was also very hot, almost too hot to even touch.
I called my dealer and their field tech said it sounded like a starter as well. They are sending out a tech in the morning to diagnose it and will have to order a starter if that is the problem. If I try to start the tractor now, all it does is click once.
This is the first time I have used the dealer's service for anything, as my tractor only has 99.1 hours. Time to find out how good they are!
Attached are before and after photos of 4 passes with my box blade. The grass had gotten a bit grown up! It looks much better now.
/ 2555 Died & Won't Start #2
that seems odd the starter would cause it to die like that. i guess it was shorting out for some time to cause the problem. Please let us know what the result is. good luck with the repair. Hopefully will be doing the 50 hour service on mine this weekend.
/ 2555 Died & Won't Start #3
Yep they usually die suddenly when something plugs the fuel outlet of the fuel tank. Seeing the starter smoke pretty much rules that one out. I had a battery shift and short which killed my truck. I replaced the battery and it fired right up. If the starter and or solenoid shorted I hope a battery is all that is needed. Keep us posted!!!
Well, the tech came out and looked today and it doesn't look good. He jumped the tractor and it started for about 3 seconds and shut off. He pulled the starter off and hooked it up to the jumper cables and tripped it, and the starter ran fine. He checked the oil and said I actually had too much, which is odd because I put the correct amount in according to the manual.
He then tried to turn the flywheel and said it was really difficult to turn. He got a bigger bar and said the same thing. He thinks it may be a bearing issue...
I have to call Monday morning and get the dealer to come pick it up and take it to the shop. I am going to ask for a loaner tractor because their shop is backed up two weeks, and who knows how long it will be in their shop for. The tech said if they have to tear the engine apart (which they probably will) that this is the first time that they will have had to do that on a mahindra engine. I'm just glad this is all covered under warranty!!
/ 2555 Died & Won't Start #5
That's both good and bad.....several years Mahindra has had this motor out and your dealer hasn't had to take one down yet....good news for us. Hearing you and your machine will be the dealer's first is not so good for you.
Hopefully the tractor wasn't level when he checked the oil. I doubt overfilling the oil is covered under warranty.
/ 2555 Died & Won't Start #6
Wow! too bad, but there's bad news and good. Bad.....it's probably a spun bearing and Mahindra doesn't rebuild engines under warranty. Good news......Mahindra will ship to your dealer a complete new engine, I know this because the local dealer just went thru this same thing. And as of now I have 2,143.2 hrs. on mine and have not had any major issues with the engine...........yet (knocking on wood), other things, well that's a whole other subject.
/ 2555 Died & Won't Start #7
You have over 2000 hours on a 2015???????
It was on a slight incline when he checked it. He did say the oil was really clean so I should be covered there.
/ 2555 Died & Won't Start #9
... He checked the oil and said I actually had too much, which is odd because I put the correct amount in according to the manual. ...
I put in oil and begin to check the stick after I get about 3/4 of what the factory recommends, then I fill it just to full, start and run the engine, let it sit, and top it off. I've never found an engine that wasn't at least overfilled if you added exactly the amount that the factory recommends.
As implied by others, you can cause grave engine damage with too much oil, though it's unlikely if you only put in the factory recommended amount.
Good idea. I'm fairly new to doing my own maintenance so I will definitely take that advice. The field tech didn't act like it was that overfilled and that it wasn't a big deal. I will let you guys know what the dealer says tomorrow!
Yep..........I work it 8 - 12 hrs. a day 6-7 days a week from the time it stops raining till it starts raining again!
What kind of maintenance schedule do you follow? What kind of work are you doing 8-12 hours a day? I'm guessing it has to do with dirt, hence the name.
I talked to the dealer this morning and they were checking on the schedule and going to get back to me. They did say transportation isn't covered under warranty, which I thought was the case. I haven't heard anything yet but there are several variables so I expect to hear something in the next couple days.
The dealer brought me a 3550 HST today and picked up my 2555. The 3550 is a much different tractor than my 2555 shuttle, so it's going to take some getting used to. I do really like where the loader control is compared to my tractor.
I'm hoping that my problem is something like a bare wire or fuse, but I'm not hopeful. I will post an update when I hear from the dealer.
/ 2555 Died & Won't Start #15
You will probably beg him to leave the 3550 and keep the 2555...... [[[ :) ]]]
/ 2555 Died & Won't Start #16
Re: 2555 Died & Won't Start
Maintenance.......well I change the oil about every 500-600 hrs. (RedLine 15W/40 synthetic only) along with the 500 hr. oil filter. Blow out the air filter at least once a week & change it about every 6 months and grease it about every 3-4 days (synthetic also).
Now as for the work............not dirt work, 98% of it is High Weed mowing; 2% 'tilling. Presently working on a 280 acre mowing.
Update: I called the dealer last week and they still haven't worked on my tractor. Their service manager said that they would get to it this past week, but alas, still no word from them. I'm not complaining though, as I have the 3550 to put hours on! I do like the size of the tractor as well as the loader control, but I do not like the HST. I prefer to push on the gas pedal and the engine to rev instead of having to run the hand throttle up, but I'm not going to complain about a loaner tractor. I will hopefully update this week when I hear from the dealer.
Mountain Farm called me one day last week and told me that they had sold the 3550 that I was using and needed to pick it up that morning. I was in dress clothes since I was at work, which I was not too happy about. I sat the tractor out and they brought me a 4530 later that afternoon. I went to start it the next day and the battery was dead...this made me pretty upset. I called the dealer and they were supposed to send somebody out the next day to fix it. Well...they did not. I ended up having to jump the tractor myself - we will see if it stays charged or not. I left a message with the service manager and he never called me back. I called again this morning and spoke to the service manager who said he was busy and would call me back. Two hours later...still no call. I have tried to reach out to the owner, but alas, he isn't available either. At this point I'm considering looking at kubotas if they can't get my 2555 fixed.
I got ahold of the owner of Mountain Farm and explained what was going on. He said Mahindra has been greatly affected by Harvey and their parts hadn't shipped for several weeks. He then got the service manager to call me back and give me an update. There are a couple tractors ahead of mine that should be getting out of their shop in the next couple days, then mine is up. The problem is either the engine seized up or a clutch assembly that has blown up. I was surprised about the clutch but he said they had another tractor with similar symptoms to mine that had that issue. He also is going to get me a new battery for the 4530 that I have now so that I won't have any more issues.
The dealer replaced the battery in the 4530 loaner tractor today. The dealer called today and said that I have a bad timing gear bearing. It apparently has a grease point, but I'm not sure if I have ever greased it. I hit all of the grease points I see but I don't know if that is one that I have consistently greased or not. Needless to say, I am looking forward to getting my tractor back.
