3-Point Hitch Mahindra 2538 owners
/ Mahindra 2538 owners #2
<<<<<<< uses a big ol' fits all wrench, its standard and metric in one tool ;)
/ Mahindra 2538 owners #3
I dont use the lock nut on mine. I just hand tighten the turn buckle and then put the cotter pin in the threaded rod.
/ Mahindra 2538 owners #4
Go mowing through heavy brush, grass or thickets, you will wish you used that lock nut. I used to do the same thing until I lost check chains or check rods, they are pricey!!!! That pin can come right out and vibration does the rest.... before ya know it...... they are gone
/ Mahindra 2538 owners #5
True, like most tractor parts they are high. Most of my use has been with a box scrape and not much with a bush hog yet. I'll use them next time, may start the search for some of the extendable links instead of the pats easy change I was looking at.
/ Mahindra 2538 owners #6
I have a 2540 (shuttle) and find that the stabilizer comes loose frequently when I use a stump grinder (there can be extreme vibration!) I think the next step is top'n'tilt cylinders, and maybe I'll locktite the other stabilizer.
