ROPS Folding
/ ROPS Folding #11
Can you post a picture? The last L2501 I looked at had the same pins for the ROPS as my B2620.
/ ROPS Folding
My B2650 arrived yesterday and they are only pins holding the hinge. That makes my job easier.
/ ROPS Folding #13
Simple pins are as functional as the OEM threaded ones if you can put up with the rattle.
I have used "O" rings on the pin, to take up the slop.
If you have to push the pin a little, to get the retaining clip on, it will be tight enough that it won't rattle.
/ ROPS Folding #14
Any ideas as to why Kubota doesn't choose to standardize on either pins or bolts across models?
Steve
/ ROPS Folding #15
Not to rub it in, but I'm so glad my Bx2660 ROPS doesn't fold and clears my garage door by an inch. I know it's always up and doing its job. And the tree branches in the way get removed soon after they are in the way.
/ ROPS Folding #16
I just ground the threads down on my 'bolts' and use the same cotter pin. No need to buy something new.
/ ROPS Folding #19
I'm always concerned I will forget to fold down the ROPS and tear up the garage and ROPS. I leave it folded down if I am doing some routine task on flat ground.
HYDRAULIC THUMB FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
2012 International WorkStar 7400 Service Truck with Crane, VIN # 1HTWGAAR2CJ453403 (A61165)
2012 International...
2015 Goose Neck Cattle Trailer (A53317)
2015 Goose Neck...
2024 Load Trailer 20ft T/A Flatbed Equipment Trailer (A56859)
2024 Load Trailer...
500BBL SKIDDED FRAC TANK (A60736)
500BBL SKIDDED...
CAT 930M (A58214)
CAT 930M (A58214)
