Those grease zerks on top of the front axle bevel gear housing.
   / Those grease zerks on top of the front axle bevel gear housing. #1
StuartDK45SE
Angleton, Texas
Kioti DK45SE
I've got a DK45SE. I have read something about servicing these somewhere but I can't remember what I read. I can pump several shots into each one and no grease ever comes out anywhere. I don't want to just keep pumping as a grease gun can exert tremendous pressures.
Thanks
   / Those grease zerks on top of the front axle bevel gear housing. #2
I pump on mine until is see the rubber O-ring begin to bulge. Usually 3-4 pumps. Over time, any excess will ooze out past the O-rings and I will have to wipe it up with a shop rag.
   / Those grease zerks on top of the front axle bevel gear housing. #3
Good question. I have a DKse as well. From what I gather in this diagram, that grease zerk services the void between the upper bearing and upper seal. It keeps the upper bearing lubricated, as that bearing sits above the oil level in the axle. This grease also helps keep the seal from drying out. The grease eventually runs down into the axle oil, so be sure not to overdo it, couple shots every time.
   / Those grease zerks on top of the front axle bevel gear housing. #4
Exactly, just like the inboard center pivot zerk. Couple of good pumps and stop.
   / Those grease zerks on top of the front axle bevel gear housing. #5
As an added note for newbies to greasing (who might read this- like many hobby farmers) it's helpful to understand how grease zerks can often be in-operative, or uncooperative might be another way to say that? Hardened grease is the common culprit. Cleaning the zerk or replacement is the solution. On a lucky day the grease gun will force the grease in as desired.
Good thread info above.
2004 TRAILKING 101" X 53' STEP DECK TRAILER (A50459)
2004 TRAILKING...
1973 CATERPILLAR 988 LOADER (A51222)
1973 CATERPILLAR...
Mini Forks (A50322)
Mini Forks (A50322)
12in Digging Tooth Bucket Excavator Attachment (A50322)
12in Digging Tooth...
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
2020 Takeuchi TL10V2 (A47384)
2020 Takeuchi...
