Mahindra 1538 Shuttle 6 Month Review
/ Mahindra 1538 Shuttle 6 Month Review #1
Caseyh
Member
Sadieville, ky
None
I purchased my 1538 Shuttle in February 2017 after three years of hem hawing around and researching. I got tons of good information on this site and wanted to give an update on how my first 6 months have gone.
I live on 30 acres in North Central Kentucky and my property is about 50% hilly/rocky field and 50% hilly/rocky woods. I don't have livestock or a big farming operation but I need to keep my property from getting out of control and perform general maintenance of gravel driveways and cleaning up downed trees and limbs etc...
The tractor is a Mahindra 1538 shuttle shift with FEL and industrial tires with the rears loaded with beat juice.
As of last night I have 69.3 hours on the tractor and have used it to do the following:
-plowed a neighbors food plot (roughly 1 acre) with a ford two bottom plow
-used a 6 ft disc on the same food plot to break it up
-used a 6 ft rototiller to till up my small garden (30'X50')
-used my betstco 6 ft flail mower to mow my fields and yard as well as cut trails through the woods and mow some of my neighbors property as well
-dug firepits with the FEL, smoothed out driveways, pulled dead trees out of the woods etc...
So far I have not had a single issue with the tractor, the ECU was flashed prior to taking delivery and I was told it had the most up to date code at the time and I have experienced no cooling issues or odd behaviors that some on here have seen.
I performed the first oil change at 50 hours and I replaced the filter at that time as well. I was glad to see magnetic drain plugs on the tractor and found a little bit of break in "dust" on them but it was very light. I'm interested to see how it looks at the next oil change.
I have been pretty meticulous about greasing the tractor and mower frequently and keeping the air cleaner and radiator cleaned out because the majority of my time on it has been spent mowing and it gets a lot of dust and grass remnants pulled into the engine bay.
The tractor has surprised me with its stability on hills, I was very nervous and cautious at first, and still am to a degree, but have gained a level of comfort. This thing is also very capable off road, I've taken it everywhere that I've taken my four wheeler and it has done fine. Crossing creeks and climbing a muddy 18" tall bank on the exit is not an issue at all. I've even done it in two wheel drive with no problem, it will crawl up and down rutted out rocky farm roads like an absolute champ and is still small enough to get into tight spots in the woods. A four wheeler trail is basically wide enough for this tractor to follow, maybe not quite but it doesn't require much more than that.
I've mowed grass down that's taller than the hood of the tractor in 3rd gear low range climbing fairly steep grades with the throttle at about 1800 rpm and it doesn't miss a bit, no bogging down and no need to bump the throttle and I'm using a 6 ft flail mower. I was concerned about the PTO power (30hp) for 6 ft implements but so far it has not been an issue. Since it's right on the edge of the recommended 5hp per ft I wasn't really sure what to expect but have been pleased.
The little plastic toolbox that comes with it is weak and I replaced it with an ammo can that I mounted to the bracket that holds the slow moving vehicle sign since I never really take it on the road. I also wish the fuel tank was in a different spot because it makes filling it a pain with a full gas can on your shoulder to reach the filler neck up on the hood. Other than that I would recommend this tractor to anyone looking for one.
Let me know if you want to know anything more specific and I'll answer anything I can.
That fuel filler looks like a great idea. I'll need to keep an eye out for one of those.
/ Mahindra 1538 Shuttle 6 Month Review #4
Amazon! But the local shops carry them as well- just haven't seen them at the big box stores yet
/ Mahindra 1538 Shuttle 6 Month Review #5
TSC has them.
/ Mahindra 1538 Shuttle 6 Month Review #6
I have the same tractor. To ease getting fuel into the high filler I use a long EZ Pour spout on a 5gal can. To begin fueling I rest the can on the FEL mount and hood then put the spout into the tank and tip the can over, after a while the can is much lighter to lift and finish emptying into the tank. You can find the spouts at TSC. Be sure to get the one with the extension, so it's double the normal length. You can also find these on the web, Wal-mart and other places. EZ-Pour Hi-Flo Water Replacement Spout at Tractor Supply Co.
/ Mahindra 1538 Shuttle 6 Month Review #7
Heck, I just use one gallon containers. Never spilled a drop. Yes, it is a bit of a pain but using a siphon pump to fill the little jugs from a big one makes it a little less so. The tractor tank isn't that big. Don't think I've ever needed more than 4 gallons to fill it up. But, I never risk running it dry either. Plus, keeping it fuller tends to cut down on condensation.
I did have an idea once to build some sort of platform for a 5 gallon (or larger) container that would allow for easy use of a siphon pump but decided it was too much trouble. Well, at least, I haven't done it yet. I suppose the "real" equipment operators out there have elevated 100+ gallon tanks along with a hose/nozzle for gravity flow or a pump. But, fuel consumption hasn't gotten to that point for me yet. It would be nice to drive up to one and say, "Fill 'er up", though.
That EZ-Pour spout looks like an EPA finagle - Gotta love that "water spout" dodge. I saw two guys at a Home Depot one day going on and on about those goofy EPA mandated abortions - Told them I was lucky enough to have 5 or 6 of the old-school spouts that fit the new containers - Thankfully. I saw a woman trying to put gas in her car using one of the "new, safety" spouts and she spilled more gas than she managed to get in the tank! Ain't the EPA great? No wonder Trump wants to cut their funding.
I like the idea of the push button release instead of having to hold the can the entire time you fill the tank. I drain a five gallon can basically every time I fill up so I'm standing there for a couple of minutes but it feels longer. It's not a huge deal to me but I believe the 2538 had the fuel tank under the floor otherwise I probably wouldn't have even though of it.
What's the highest hour count you know of so far on one of these models?
/ Mahindra 1538 Shuttle 6 Month Review #9
When I bought my Mahindra, I complained about the EPA/OSHA "slow fill" cans, so they gave me a good old-fashioned safety can-in the proper yellow color-with a plastic funnel that goes around the spout. A couple of minutes for five gallons. (My tank is just behind the ROPS, and quite high, but I can hold the can long enough to dump it with no issues.)
/ Mahindra 1538 Shuttle 6 Month Review #10
That's when I picked up the EZ Pour spouts. Those EPA spouts create more spillage than they prevent. Yet another gubberment thing run completely amok.
Caterpillar 320 (A60462)
Caterpillar 320...
2024 Bintelli ActivEV Pulse Electric Cart (A59231)
2024 Bintelli...
2021 Billy Goat F902H Walk-Behind Debris Blower (A59228)
2021 Billy Goat...
CATERPILLAR 924F WHEEL LOADER (A59823)
CATERPILLAR 924F...
2007 John Deere 644J Articulated Wheel Loader (A59228)
2007 John Deere...
2017 Versatille 260 (A60462)
2017 Versatille...
