Fired Road contractor. Build it myself?
   / Fired Road contractor. Build it myself? #281
...new electric deer fence. 7 feet tall 7 strands hot...
Did you use the tape or just wire strands? What has worked for me is a two fence approach, 3 feet apart with 1.5" tape and I only energize the outer tape. The inside fence is at 4' off the ground and the outer is only 3' tall. Early in the season, I drip "Deer-Off" on the outside tape... the deer (I hope) remember the smell and jolt, so they stay away when they see the white tape.
   / Fired Road contractor. Build it myself? #282
In March I put a 31 foot camper up at the top of the road. In April I applied for my building permit. It was just approved Tuesday. I have spent the wait time builder NG a new electric deer fence. 7 feet tall 7 strands hot. And then I started working on an old hunting shack that was rotten. Stripped it down to its bones and added to both sides to make it a storage shed. My excavator has been broken down and I have been waiting on a mechanic to make the trip up here. The know they are busy but I swear you could rely on a hookers promise more than these guys. It gets old having to call people up over and over to see when they are going to show up.
Good to hear of some progress, but that was a long time for a building permit.
Because a large part of this fence will eventually get moved I just did 10 foot poles. 3 feet in the ground with 7 strands of hot steel wire. Previously we had a lazy 3 strand fence that successfully kept them out of the orchard so the 7 foot should do the trick. We are two years away from a harvest so I expect things to change when we have apples. IMG_6790.JPG
   / Fired Road contractor. Build it myself? #284
Nice looking fence.
How high is the top wire?
   / Fired Road contractor. Build it myself? #285
...kept them out of the orchard ...
Ah, missed that part... good choice, then... I would still try and make it more visible to them. If they are running, they will not see it also, you don't have to energize above 6-7 feet since to make contact, they will be flying in the air and will not completing the circuit.
   / Fired Road contractor. Build it myself? #286
...My excavator has been broken down and I have been waiting on a mechanic to make the trip up here. The know they are busy but I swear you could rely on a hookers promise more than these guys. It gets old having to call people up over and over to see when they are going to show up.
I learned that same lesson with my dozer. Before buying, I found several mechanics who said they would come out if something happened, but when something happened, they never showed up. Eventually it turned into a couple of months of calling and waiting, asking around for other mechanics, then calling and waiting some more. Eventually I just decided to figure out how to do it myself. So far, since then, I've bought a lot more really big wrenches and sockets, and managed to figure it out.
What's wrong with your excavator?
I have it running again. But like you said, I did the repair. It hasn't been charging the batteries properly. I just replaced the alternator in January. I am chasing down fuses, etc. In the mean time I have been putting a charger on it each night when I use it, to bring the batteries back up. ?Havn't heard from either of the mechanics I called.
I hadn't even considered that. Thanks.
   / Fired Road contractor. Build it myself? #289
One of the wiring plans I have seen for fences suggests alternating hot and ground wires, even without good dirt contact they can still give a good zap...
   / Fired Road contractor. Build it myself? #290
A little lighter
2005 PETERBILT 379 TRI AXLE  DUMP TRUCK (A56129)
2005 PETERBILT 379...
2025 Auger Skid Steer Attachment (A53421)
2025 Auger Skid...
2016 Ford F-450 Ext. Cab 4x4 10ft Flatbed Truck (A55852)
2016 Ford F-450...
2008 Komatsu PC228 (A47477)
2008 Komatsu PC228...
UNUSED Heavy Duty Ratchet Strap Set (A53117)
UNUSED Heavy Duty...
2017 CASE IH 580 QUADTRAC ARTICULATING TRACTOR (A52705)
2017 CASE IH 580...
