HD10 retirement. Whats next????
/ HD10 retirement. Whats next???? #1
ArlyA
Super Star Member
Houghton MI (the Lake Superior snow belt) USA
Outlander1000 6x6, Ego lawn mower and shopping for tractor
As stated in the title, our HD10 is coming up on its retirement so we ponder what machine to replace it with. The Defender has required modifications and had some minor grief for working hard. Its level of power had been no better than OK and we've had it occasionally pegged to the floor. The service from the dealership reasonable as well.. At this point, we would get another and its review address is pasted below. Is there another machine we should consider??
http://www.tractorbynet.com/forums/atvs-utility-vehicles/355357-can-am-2016-defender-hd10.html
/ HD10 retirement. Whats next???? #2
As stated in the title, our HD10 is coming up on its retirement so we pondered what machine to replace it with. The Defender has required modifications and had some minor grief for working hard. Its level of power had been no better than OK and we've had it occasionally pegged to the floor. The service from the dealership reasonable as well.. At this point, we would get another and its review address is pasted below. Is there another machine we should consider??
Why not a Tucker Snocat or similar ?
A new Prinoth or Pisten Bully that would be appropriate for our trails is in the 140K price range. I have operated all those machines and a Tucker. If we did that, we'd still need a UTV for summer trail work. We can purchase a UTV and equip it for winter used for around 30K. What would you do?
/ HD10 retirement. Whats next???? #4
A friend grooms for a club here in Vermont. They bought a well cared for used Tucker for about 50 grand. Still going strong after 5 years. The tucker or similar are designed for the work and will last thousands of hours. He felt it was a good investment that was cheaper long term. They struggled with other options before the Tucker that just didn't last or perform like they wanted.
What would I do? I guess I'd sit down and run the numbers on long term costs for each option. Not many UTV options for the work you need it to do that will hold up to the hours you do. Im interested to see how the new one performs. Good luck!
/ HD10 retirement. Whats next???? #5
Kubota dealers are indicating that a new gas version of the RTV-X will be introduced this fall. It purportedly has a much higher top speed, 50mph vs. 25mph and much more HP than the 25HP diesel version. Not uncommon to see RTVs with thousands of hours of very hard use.
I was about to pull the trigger on a HD10 but when I learned that Kubota may be releasing this new UTV, I decided to wait. The Kubota cabs are very well designed and this new machine equipped with tracks, will allow me to run it 4 seasons for work and play.
We don't do high hours on UTVs, since its not our primary tow machine. The only tucker small enough to fit on our trails seems to be no longer in production. A Pisten Bully 100 is to wide and heavy for our bridges even a PB Paana might be to much. Nonetheless, you can purchase older used Tuckers, PBs and Prinoths for dirt cheap and the problem is, they like to break. You can wait for weeks for a $5000 rebuilt pump or motor to show up, and who's grooming during the wait?? Old used machines are great for other folks to keep running, were as I'd prefer to be out grooming new snow down, not wrenching :duh:.
symphony, I'm not sure what constitutes "very hard use" to you?? The problem with machines that use a hydrostatic transmission is there high power loss and low top end when used with pods. I'm sure for many users, a hydrostatic transmission is wonderful idea but for snow working machines like us, they don't. We need great HP to run through snow AND enough top speed for use with pods, they just don't cut it.. Hydrostatic transmission's run at very high power losses. Does this new RTV have a CVT transmission??
Tried that, been there. This was taken at the manufacture, after a test run
I beg to differ. We've used atv's and UTV's for the past 10+ years with reasonably good results. Not perfect, but still pretty good. As stated in my original post, we are beginning to look for our next UTV. In my original post, maybe I should have stated were looking for another UTV?
/ HD10 retirement. Whats next???? #12
Speaking as you're not getting much interest, I might as well chime in.
You might want to check out the Textron Stampede. Textron primarily makes military products, but has recently scooped up Arctic Cat and Bad Boy Buggies. They have also owned EZ-GO for years.
According to the brag sheet, it seems the Stampede is a little narrower than the Defender, but with a longer wheelbase. It puts out 80hp and 60 lbft of torque, and apparently pulls like a mule in low gear.
Also, Polaris has recently come out with a new Ranger 1000, and I believe they are making a version with an integrated HVAC cab.
-Luke
/ HD10 retirement. Whats next???? #13
Have you looked into the Polaris Brutus? It can be had with a diesel which I imagine being torquey would be prime for running with tracks pulling a load in the snow at slow speeds.
We retired a IQ wide track about two years ago and still recall the $1000 per year its maintenance cost. In its third year with us, it needed its wiring harness replaced after the engine would quit and the display showed some goofy electrical code. This repair ran about 1300 and the service manager told us "ya we see this happen with this make". Polaris may have got over there poor parts contracting but the memory is still to fresh in my small mind.... So no, we've not looked at the Brutus.
78in Heavy Duty Hydraulic Grapple Rake Skid Steer Attachment (A64553)
78in Heavy Duty...
2017 Gravely ZT-X 52in Zero Turn Commercial Mower (A64194)
2017 Gravely ZT-X...
2017 JLG G5- 18A TELEHANDLER (A59914)
2017 JLG G5- 18A...
SCAG TIGER MOWER (A64557)
SCAG TIGER MOWER...
2021 Ford Transit 350 HD Reefer Box Van (A64194)
2021 Ford Transit...
2015 Chevrolet Impala Sedan (A64557)
2015 Chevrolet...
