rScotty
Super Member
- Joined
- Apr 21, 2001
- Messages
- 9,908
- Location
- Rural mountains - Colorado
- Tractor
- Kubota M59, JD530, JD310SG. Restoring Yanmar YM165D
Hard to believe, but it's been almost ten years and 1000 hours since my we bought the M59. It's been an amazing machine.
But not quite perfect.... it does work well, but in my opinion it has always burnt a little too much fuel and certainly makes way too much black smoke. I've thought about that for years, and I'm now considering disabling the EGR valve for better combustion. Has anyone done that? Any Advice?
The M59 uses Kubota's standard 150 cu. in. 4 cylinder, turbocharged, indirect injection engine (the V2403-M-TE3) vintage 2007. The shop manual implies that EGR valve is an add-on emission solution to an engine that has been around for awhile. The shop manual has an entire new section devoted to the EGR system.
Through the years I've changed several things to make this machine work better for us, but have just sort of ignored the thick black smoke that it makes when starting or revving up, just like I've ignored the rather low fuel mileage. That was easy enough since I didn't know what to do other than think about it awhile. Of course diesels do smoke, but this seemed excessive. Easy to ignore when the rest of the machine works so well.
And I figured that fuel consumption and black smoke might simply be the 7000 foot altitude here. Up here there's less available oxygen in the air - and at first I thought that I'm not going to be able to do much about that....and then one day while enjoying some loader work while listening to the EGR hammer & rattle away....and dodging the smoke plume..... it occured to me that maybe I could do something. After all, the engine has a perfectly good turbo - maybe that turbo is being crippled by the EGR valve. So I got out the shop manual and began to study up. It looks easy enough to do. The EGR valve is driven open by boost pressure from the turbo. Just plug it up?
So that's what I'm thinking.....what do you guys think?
rScotty
rScotty
