   / Harbor Freight Tools that don't suck #7,731
I like the paddle switches for when working above my head. Last time I was grinding on my back under a trailer with out one, I dropped it and it landed 3 inches from my ear running like a scolded ape with the slide trigger locked on.
Yep it is a huge safety thing and what I like least on the HF cheapo grinders. Not to mention the side switch is finicky on turning on:eek:ff easily.
   / Harbor Freight Tools that don't suck #7,732
I agree, I have no interest in buying one without a paddle switch.
Aaron Z
   / Harbor Freight Tools that don't suck #7,733
Aaron Z
My welding instructor was a retired ironworker. He lost control of a grinder once on the fortieth floor of a building under construction and had to watch, horrified, as it flew out and down to the ground. Apparently nothing worse came of the incident but it sure drives home the unexpected ways that power tools can be dangerous.
   / Harbor Freight Tools that don't suck #7,734
I used an air drill recently and was impressed with its torque but even more impressed by how it stops instantly, unlike an electric drill or particularly a Skillsaw that has enough inertia to remain dangerous after you let go of the trigger.
   / Harbor Freight Tools that don't suck #7,735
I have a Black and Decker 3/4" drill from a very long time ago. It's one of the D handle drills where the handle with the trigger is about a foot long. The thing is huge and turns at about 1 revolution per hour, ok not that slow it it's real slow. I was told it was used for drilling holes for rivets on bridges. That thing takes a good minute to come to a stop and because it's geared so low if it catches either you move or the bit breaks. I hasn't been used in decades but it was my grandfathers so sooner or later I'll clean it up and hang it on the wall.
   / Harbor Freight Tools that don't suck #7,736
All my newest cordless tools drills and especially the circ saws all have instant braking. I have a lock on slide switch cordless grinder (was the only option back when I got it) but since then there been 2 paddle switch versions and the latest one with brake. That is the type I want next
   / Harbor Freight Tools that don't suck #7,738
I think I would try this one over the new HF one. Paddle switch, easy move guard and 3 year warranty for $5 more. Ratings are good too. It even comes with 2 guards, one for cutting and one for grinding.
PORTER-CABLE PC6�TPAG 7-Amp 4-1/2-Inch Angle Grinder/Cut Off Tool - Power Angle Grinders - Amazon.com
The reviews on that one look excellent, also the specs. I think it's well worth paying $5 more than the not-quite-as-good HF grinder. But I don't see electric brake listed.
   / Harbor Freight Tools that don't suck #7,739
Does the HF one have electric brake?
2016 INTERNATIONAL 4300 SBA FLAT TOP ROAD TRACTOR (A58375)
2016 INTERNATIONAL...
2015 Ford Transit Cargo Van (A54814)
2015 Ford Transit...
2010 International 4300 Truck Altec DM47TR Insulated Material Handling Digger Derrick Truck (A55973)
2010 International...
2011 Ford F-550 ETI ETCMH37IH 37ft. Insulated Material Handling Bucket Truck (A55973)
2011 Ford F-550...
TANK MANIFOLD (A58214)
Kubota BX25D (A53317)
