Kubota front loader 3rd function adapters for attachments on the front?
/ Kubota front loader 3rd function adapters for attachments on the front? #1
Rutcutter
Arkansas
Kubota L5460 4wd w/LA1055 Loader/ Rear Top and Tilt
What does the Kubota 3rd function kit come with as far as adapters for the attachments..
My tractor came with these on the front,is this correct?
/ Kubota front loader 3rd function adapters for attachments on the front? #2
My dealer started to ask me what I wanted. Then cut himself off to say flat face are the industry standard & to let him know if I wanted something different. I went with the flat face (1 male, 1 female to prevent hose reversal). I'm pretty sure he meant standard as in industry standard (skid steers especially) rather than standard for Kubota tractor/loader 3rd functions.
You kind of have 3 options:
Flat face - industry standard & most likely to be comparable, clean with little to no connect & disconnect leakage
Ag style - what you have, hopefully matches what is on the back for compatibility. Usually female, but you have male (no clue if that's standard or not). Leaky when connecting/disconnecting & dirty. My least favorite, but the standard for tractors & the cheapest.
Some kind of connector under pressure fitting - I've thought about swapping to this after fighting with AG & flat face (often need to unscrew a fitting to bleed off pressure if it's warm out when hooking up).
/ Kubota front loader 3rd function adapters for attachments on the front? #3
Actually I would think your dealer added the connectors after the install. I just finished adding the 3rd function kit to my tractor and the OEM kit comes with just caps on the loader end. This is so you can add the connector type of your choice. I installed a male and a female at the front because I plug the hoses of the attachment together when i remove it from the tractor.
Al
/ Kubota front loader 3rd function adapters for attachments on the front? #4
I honestly don't know if there is a "correct" way to terminate hydraulic hose from a third function install. I had my dealer install the third function(WR Long) for my grapple and the hydraulic hose terminates with male connectors, just like yours. The ends go thru and are held by a stand-off bracket and there are rubber caps to cover the ends when not in use. Obviously, since the dealer installed the grapple - the male & female ends are going to be compatible. Will the male fittings be compatible with any other "front end" implement I might purchase that needs third function abilities........it would seem obvious but unless one actually "made" physical connection there could be incompatibility. However, this would simply mean having new female connectors put on the new implement.
So... I think yours is correct. The bigger concern is trying to determine what size, type & "shape" those two male connectors are so you can get matching female connectors for whatever you want to connect to it. I would start by asking your dealer what type, size, etc, etc those male connectors are..............
Man, I hope I made some sense and you can understand all this C-rap I just laid down..............
/ Kubota front loader 3rd function adapters for attachments on the front? #5
I went with flat-faced skid steer style. They're available as "connect under pressure" which as Fallon mentioned above would save some hassle. Flat face couplers are nearly leak-free when disconnecting.
/ Kubota front loader 3rd function adapters for attachments on the front? #6
I don't think there is such a thing as "correct" QR fittings. You can use whatever type you like. Most dealers seem to stay with flat face since they are easy to clean and don't spill much oil when connected.
I had a W&R Long 3rd function valve added to my MX5800 and the dealer used flat face couplers. The OEM Kubota valve on my L6060 also uses flat face. I made a set of flat face to ag adapters to work with my older implements.
This is what came on my grapple..
/ Kubota front loader 3rd function adapters for attachments on the front? #8
I had the third function set up installed on my B2650 last month and no quick couplers were installed on the end of the hoses since my new grapple was not in yet. The male threaded fittings were just capped. Once the grapple came in I bought a set of couplers so everything matched.
On a side note...I do not like this third function set up on my B12650 as it is activated by solenoids and you cannot "feather" the function to make the action smooth and slow. The function is determined by the speed of the engine/hydraulic pump. I have to throttle the engine down to idle so the grapple does not slam shut. This would not be a problem but when I pick up limbs in our orchard I may open and close the grapple hundreds of times and having to slow the engine down so many times is a lot of extra steps. On my larger Non Kubota tractors I can have the engines running relatively fast and feather the third function as fast or slow as necessary and keep engine speed the same.
/ Kubota front loader 3rd function adapters for attachments on the front? #9
Those look like they could be "connect under pressure". If you can predict which side of the circuit retains or builds more residual pressure, but the male connector on that side. For some reason the males work better.
/ Kubota front loader 3rd function adapters for attachments on the front? #10
...Ag style - ...Leaky when connecting/disconnecting & dirty...
Glad to learn that it's not just mine leaking... I have a single set of Flat Face connectors, sitting on a shelf, they're nicer than the Ag type. :2cents:
/ Kubota front loader 3rd function adapters for attachments on the front? #11
You can pretty much take care of the speed problem by using a flow restrictor.
Get one with an 030 orifice and go from there. That or get an adjustable needle valve. Either one should take care of your problem. ;)
/ Kubota front loader 3rd function adapters for attachments on the front? #12
So I am not an expert but here's some info I believe to be correct:
No, two male ag quick couplers(what you have) is not the norm in my experience. Most people have multiple attachments for each tractor. So each implement would need 2 female QCs. Female QCs are 3 to 8 times the cost of a male one. Just not economical.
As previously mentioned, a male and female ag QCs is probably the most common setup on tractors. (FYI there are several types of "ag" QCs. The most common is 1/2" of the ISO #5675 spec. Essentially, all the manufacturer make a line of QCs to this spec. However, Pioneer was the first so these are frequently called "Pioneer connectors.")
I actually run two female QCs on my tractor's 3rd fxn. bulkhead. This is for several reasons I won't go into now, not the least of which is cost. I only have have to buy cheap male QCs for all my attachments. I just color-code my lines with colored electricians tape to ensure I always hook the lines up the same way.
Read up on flat face QCs before you go that way. They are easier to clean but way way more expensive and have residual pressure issues when trying to connect (preventing it).
/ Kubota front loader 3rd function adapters for attachments on the front? #13
Beyond the low cost (and they are inexpensive, especially they way you do it with females on the fixed end) what is it you like about them for 3rd function? If using with grapple or anything else with branches, I'd be concerned about the possibility of accidental disconnect. Not a problem for something like a snowplow though. Sort of in between might be either of the ISO7241 couplers, which are positive locking, leak about the same as Pioneer ag style, and cost less than FF couplers.
/ Kubota front loader 3rd function adapters for attachments on the front? #14
I actually really want "breakaway" functionality and the only way to do that is with female QCs mounted to the tractor.
Most likely through operator error, the attachment can come off the SSQA or the hoses get yanked on (i.e. forgetting to lock down my SSQA levers or hoses that are too short or get tangled on something). I really want the QC to uncouple rather than damaging my lines. Much easier to simply re-couple a QC rather than to replace an entire hydraulic line.
Maybe everyone else is perfect and can guarantee they'll never forget to lock down their SSQA and dump their grapple off the tractor onto the brush pile but I am not :confused3:. My 900# grapple hanging by 2 hydraulic lines will not end well.
Disconnecting the breakaway QDs requires a fair amount of force. So far, I have not had an accidental disconnect.
:2cents:
/ Kubota front loader 3rd function adapters for attachments on the front? #15
/ Kubota front loader 3rd function adapters for attachments on the front? #16
Front of a skid loader, I think flat face is the industry standard, and 1/2"
For tractors, There really is no standard for the front. Just whatever people chose to use for various reasons.
I like one male + one female for hose reversal issues. But if you have ALOT of attachments, then using two female on the tractor and all males on the attachments for cost reasons is sound advise. They can always be color coded with the caps.
If you have alot of SS attachments, or paln on using alot of them, go with the Skid loader standard. But 1/2" couplers are overkill for most of what we have up front on our lower flow machines. Especially when they are ~$50 a set and even more if you get connect-under-pressure ones.
I chose to use 7241-b series couplers because thats what I have always used on my meyer truck plows. And want the ability to hook to any one of my plows. And in 1/4" body size, its plenty big enough for the flow, the couplers can be found about anywhere local in a pinch, and they are ~$10 a set
/ Kubota front loader 3rd function adapters for attachments on the front? #17
Download this and print it out to see what size and style they are:
https://www.discounthydraulichose.com/v/vspfiles/downloadables/qd_sizechart.pdf
I think the dealers just install whatever they can get to put there. I'm pretty sure mine are the ISO series A, it's been a while since I figured it out. They put two males on there for cost, a female connector costs a lot more. Whenever I actually get something to use the 3rd function with I plan to get two female connectors and swap one of the male fittings to keep them from getting mixed up. On my valve it is also set up with both males on the valve and both females on the hoses, so I'm going to swap one of those around also so I don't get them mixed up when taking the loader off.
/ Kubota front loader 3rd function adapters for attachments on the front? #18
:2cents:
OK, that's sound reasoning! It would be easy to say "Who would fail to latch their SSQA?" but I did it with a bucket. I was thinking I'd get the latches when I swung by our house, but then I realized I had everything I needed and went on up the road. Got to the neighbors, set down the FEL, and bucket fell off. Duh.
/ Kubota front loader 3rd function adapters for attachments on the front? #19
Depends what you're doing. 1/4" seems fine for intermittent use like grapple or snow plow, but for an auger 1/2" is pretty much required. I think the 1/4" couplers are good only up to about 4 gpm.
/ Kubota front loader 3rd function adapters for attachments on the front? #20
Correct. And certainly a consideration. But most dont run a continuous demand hydraulic attachment on the front of a tractor. And even so, unless you have a large tractor with 10+GPM, there is no point in jumping to 1/2" everything. 3/8 is more than sufficient.
Mahindra 4550-4L Tractor with Front Loader - 49 HP, 4WD, Heavy-Duty Utility (A63118)
Mahindra 4550-4L...
2023 John Deere Z960M Zero Turn (A63116)
2023 John Deere...
2020 Peterbilt 567 Quint Dump (A62613)
2020 Peterbilt 567...
2020 Takeuchi TL8R2 Track Loader with 72in Tooth Bucket (A63118)
2020 Takeuchi...
2025 Stump/ Trench Bucket Mini Skid Steer Attachment (A56857)
2025 Stump/ Trench...
2007 CHEVROLET 3500 DUALLY 4X4 DIESEL TRUCK (A59575)
2007 CHEVROLET...
