Kubota front loader 3rd function adapters for attachments on the front?
/ Kubota front loader 3rd function adapters for attachments on the front?
Those look like they could be "connect under pressure". If you can predict which side of the circuit retains or builds more residual pressure, but the male connector on that side. For some reason the males work better.
Should I just go and grab a set of 1/2" male and female of these? Where is the best place to get them? Sorry for all the noob questions! lol at myself!
/ Kubota front loader 3rd function adapters for attachments on the front? #22
I use 2 double acting sleeve female connectors on the FEL side ... push-on/pull-off type. Here They are spendy but it's only a one time purchase. Then you can use the cheap AG males on your implements and color code with Red/Blue electrical tape.
For the residual pressure problem, I turn the tractor off before unhooking the implement and relieve the FEL pressure first then turn the KEY to the ON position only and relieve the pressure in the 3rd function system before unhooking. I do the same thing before hooking up and it has worked great.
/ Kubota front loader 3rd function adapters for attachments on the front? #23
I would go with the Flat Face skid steer type if you have or are going to use attachments that have them, and/or if you aren't too cost sensitive. Otherwise one of the ag style discussed above. Discount Hydraulics has good specs/info and decent pricing.
Got to use my grapple for the 1st time today and I really like it,got a lot clearing done in a short amount of time.. Guys not sure why my pictures are showing up sideways,what am I doing wrong?
