PTO shear bolt: tractor end or implement end?
/ PTO shear bolt: tractor end or implement end? #1
ericm979
Super Member
Southern Oregon
Branson 3725H Deere 5105
I lost drive to my Woodmaxx chipper today because the shear bolt went missing. I think it fell out; there was only small stuff in the chipper at that moment and the chipper spun down rather than stopping. I turned it by hand to check that it wasn't jammed.
Re-reading the manual I see that the shear bolt end of the PTO shaft is supposed to go on the tractor. For some reason I've been doing it the other way all along. Does it matter? This PTO shaft doesn't come apart when the shear bolt is missing, it just spins.
Would it be a good idea to loctite the shear bolt's nut? It's a nylock nut but those don't always hold.
Last the unthreaded part of the spare shear bolt from Woodmaxx measures .306 inches, which doesn't match the 5/16 the manual says and would be 7.7mm. Any idea what size I should use?
/ PTO shear bolt: tractor end or implement end? #2
Shear at the tractor end
Nylocks are "good enough" just snug the nut. Not too tight.
Stick in a 5/16 bolt of the correct grade. It's not rocket science, Bolts are bolts. Exact shear loads and forces are never certain.
/ PTO shear bolt: tractor end or implement end? #3
There's different types of hardness. Mine broke because the PTO is switch activated. Replaced it with a low grade 5/16 bolt I just throttle down, engage, and ramp up to speed.
/ PTO shear bolt: tractor end or implement end? #4
By putting the shear bolt in the distal end you are also protecting the two u-joints in the drive shaft.
I suspect the shear bolt fell out. The chipper was working on < 1" brush. It spun down slowly after the PTO let go. I'll look for the bolt. The chipper has 20 hours use. The spec is for a 5/16 grade 2, which is what I will use in the future when I run out of the spares that came with the chipper. I've chipped some big stuff and even stalled the tractor once without breaking the shear bolt so I think it's strong enough.
So far I have one tractor end with no explanation why, and one implement end with an explanation. Anyone else want to chime in?
/ PTO shear bolt: tractor end or implement end? #6
The shear bolt is the weak link so I don't think it matters if it is distal or proximal orientated.
/ PTO shear bolt: tractor end or implement end? #7
Are shear bolts just that, a standard grade 2 bolt?
/ PTO shear bolt: tractor end or implement end? #8
Shear bolts are whatever may be specified for a particular application. SAE grade 2, 5 or 8; Metric 8.8 and 10.9 are all used as shear bolts in applications I am familiar with. Some shear bolts have special relieved shanks that shear easily at a given point in the shank.
I'm thinking it doesn't matter if the shaft's constructed so it stays together when the shear bolt shears. If it comes apart you'd want the shear bolt at the tractor end so the broken shaft isn't flopping around and damaging things or people.
These shear bolts are regular 5/8 grade 2. I've seen ones for snow blowers that have grooves cut into them to make them shear easier.
/ PTO shear bolt: tractor end or implement end? #11
I have the WM8H. The shear bolt coupling end goes on the tractor pto . I labeled each coupling end of the pto shaft. One end says "pto" the other end says "chipper".
/ PTO shear bolt: tractor end or implement end? #12
Here's a tip to save a little $$. Instead of using a nyloc nut for the shear bolt, use a regular nut with a tap from a handheld sledge to give it a slight oblong. It will still thread onto the bolt but will not loosen without a wrench.
/ PTO shear bolt: tractor end or implement end? #13
Operative phrase "a little $$".
/ PTO shear bolt: tractor end or implement end? #15
Same torque transmitted by joints regardless.
/ PTO shear bolt: tractor end or implement end? #16
Same torque when all is right, but what happens when a prop shaft joint fails or a spline shaft separates? (it happens)!
Shear protection at the PTO spud can protect the TRACTOR in the event of a break away PTO shaft.
Otherwise it's drive mechanism vs twisted metal. ;-) All that, and the implement drive is protected just the same.
I'm sticking with shear protection at the tractor end! ;-)
/ PTO shear bolt: tractor end or implement end? #17
Carried to the extreme, After snugging the plane nut on the shear bolt for the garden tractor blower, I just take a wollop with the hammer to mash the protruding bolt threads.
I'm not taking that nut off anytime, and the hammer is there because I used it to drive out the shear bolt remnants. It's worked for about 20 years. But right now, I'm reworking the shear safety for the auger from a through shaft pin in double shear to a single shear bolt through a pair of coupling plates. My wife said she didn't like the present arrangement, and I said "OK, I'll make it easy to change shear bolts".
Anything to keep the gals happy! ;-)
(1) 7.2-16 TIRE W/ 6 LUG RIM (A64280)
(1) 7.2-16 TIRE W/...
2014 GENIE S-40 TELESCOPIC BOOM LIFT (A64279)
2014 GENIE S-40...
2021 CATERPILLAR 730 OFF ROAD DUMP TRUCK (A62129)
2021 CATERPILLAR...
2012 Kia Sorento SUV (A61574)
2012 Kia Sorento...
2014 Honda Accord Sedan (A61574)
2014 Honda Accord...
2022 EZ-GO ELITE...
