ericm979
Super Member
I lost drive to my Woodmaxx chipper today because the shear bolt went missing. I think it fell out; there was only small stuff in the chipper at that moment and the chipper spun down rather than stopping. I turned it by hand to check that it wasn't jammed.
Re-reading the manual I see that the shear bolt end of the PTO shaft is supposed to go on the tractor. For some reason I've been doing it the other way all along. Does it matter? This PTO shaft doesn't come apart when the shear bolt is missing, it just spins.
Would it be a good idea to loctite the shear bolt's nut? It's a nylock nut but those don't always hold.
Last the unthreaded part of the spare shear bolt from Woodmaxx measures .306 inches, which doesn't match the 5/16 the manual says and would be 7.7mm. Any idea what size I should use?
