Comparison Husqvarna GT48DXLS Compared to John Deere
/ Husqvarna GT48DXLS Compared to John Deere #101
Teachu2, like you I really needed a locking diff or a 4wd mower. Safety was my biggest motivator, going down hills out of control and being able to go up hills on some days while other days I would loose traction and slide back down. I have a CUT and side by side so this was only going to be used for mowing. I was seriously looking at the Husky R322T 4wd mower. With it's price range came a whole new set of options. Until then I really hadn't thought about the X570. That's what lead me to look around in the used market. I can't say I was looking specifically at the GT48DXLS at first, Husqvarna has several models with locking diffs but only a couple that also have the fabricated deck (Something I wanted). The YT line seamed kind of lower end with it's smaller wheels which left only the GT48DXLS (at least that's what the dealer I talked to said). The only one he had was sold so I could look it over but not even try it and didn't think he was going to get another. I might have waited another year but the dealer wasn't sure if Husky was going to have it in their lineup next year (another reason why I started looking at other options). I notice Husqvarna no longer lists the GT48DXLS on their website. In the past when I got to spending over $5k to just mow I shelved the idea. Had I not found a used X500 with low hours I probably would have waited until next year.
We went with the Husqvarna R322T AWD, we actually have two R322T machine's.
My wife helps me with the mowing, and we only use the R322Ts for mowing.
Much of our property has slopes and the R322T has worked out much better than our previous
2 wd Wheel Horse riding mowers.
The AWD is a huge advantage on slopes.
Another plus is the front mount deck, it flips up easily to clean out built-up grass clippings or changing blades.
Articulating steering for tight and easy maneuvering around objects is another benefit.
We both love our R322Ts and will never go back to traditional riding mowers, with mid mount mowing decks.
/ Husqvarna GT48DXLS Compared to John Deere #102
Deleted because of Double post
/ Husqvarna GT48DXLS Compared to John Deere #103
Those look pretty slick! Never saw/heard of it until now. Too bad they don't make a larger/heavier unit. Great concept, but seems to have some reliability/quality issues per the Husqvarna website reviews.
/ Husqvarna GT48DXLS Compared to John Deere #104
I am in the exploratory mode and don't need it today, but will prob pull the trigger ( on something) this spring, if I get enough work down on the place to need it...more stump removal and the biggie, ROCK pick up and I have TONS of rocks on the ground.
Several things drive my requirements: 1) hills, 2) anything but flat ground and 3) stumps/rocks.
Whether or not the GT48 is my solution or not is still up in the air. But in my year long research it has strong positive reviews, and has 2 features I feel I need: 1) Fabbed deck, 2) locking rear axle. There may be more but at this time these are key.
In my research I found this thread and as a result joined the forum. My thinking was that somewhere in the 101 posts there would be light at the end of the tunnel that pointed to a solution to my needs. As for the prime talking point the "stronger frame", yea I guess albeit stronger frame is at best a relative term, stronger than what and how strong does it need to be to cut grass and weeds. I am also looking at the Husky R322 in 4wd and I will look at anything I can find out there that I think will do the job I need it for. Sure I think my JD is a great tractor, but I don't need another tractor or backhoe, I got now it along with a lot of other stuff I use on that JD, but my JD does not cut and I will be danged if I am going to spend almost $4k to hang a deck under it, especially since that won't work as my land that I want to mow is to heavily treed to maneuver that JD around.
I also like my Husky stuff, 3 chain saws, and a backpack blower to clear all those oak leaves that drop year round next to my house, good stuff it is.
/ Husqvarna GT48DXLS Compared to John Deere #105
.... and has 2 features I feel I need: 1) Fabbed deck ....
What is it about a fabricated deck you think you need? Historically, it's not so much an issue of whether a deck is fabricated or stamped, but what gauge metal it's made from and how it's shaped and reinforced. Both Husky and Deere have offered 7-gauge stamped decks on their pro equipment that would make their lighter fabricated decks look like tin cans. So I would not let stamped vs. fabricated be a defining issue. Pay attention to the gauge of the metal on the deck, the shaping, and the reinforcement. Stamped decks will have better airflow and less clogging (smoother shape and corners) and if you can get one that's heavy gauge and well made, it would be the best of both worlds.
/ Husqvarna GT48DXLS Compared to John Deere #106
This is, like most generalizations, generally true - but the fabbed deck on my GT48 is exceptional in airflow and lack of clogging. The airflow contributes to excessive noise and it will throw clippings all the way across a residential road. Very sticky mud will adhere inside the deck, but it still didn't clog. I installed a mulch plug, which reduced the noise and eliminated the long discharge. I anticipate pulling the mulching plug for the first cut of the season.
/ Husqvarna GT48DXLS Compared to John Deere #107
Generally speaking, like gauge for like gauge the fabbed will be stronger vs the stamped one, generally speaking and in the case of fabbed vs stamped my bet is the fabbed on a mower is far stronger, but that is an assumption on my part. Stamped is cheaper and the easy way to better aerodynamics, fabbed requires design to achieve the same results.
Generally speaking.
My place is an old cattle ranch in the hill country of Tex. Well they don't call it Hill Country for no reason...basically the hill country is a layer of top soil about 1-4 in thick on top of a piece of limestone. Rare is flat and if if you see pasture it was man made and I don't have flat or pasture. Let cattle roam on it and the ground is unlevel, rough and IMO a stamped or thin gauge deck will get destroyed in short time. This not finish mowing, right not I mow with a Billy Goat ROUGH CUT and have been clearly, smoothing out with it. Drawback is it weighs 355 lbs, 2 wheels, and cuts a 26 in swath. TRUST me this is BRUTAL work in 100 F temps, even with the good breeze I had blowing yesterday. Been at this for almost 6 years and thinking by next year I might be able to mow a few acres around the ranch house, but even with all the work I have put in, its still a rough mow and its not and never will be some grassy lawn that I cruise over with a cold one in my hand and smoking a cigar.
Besides, I am in my 70's and my wife keeps worrying I am gonna drop dead behind my Billy Goat or on my John Deere..which is fine by me, I am an old soldier and was prepared to die with my boots on to begin with.
/ Husqvarna GT48DXLS Compared to John Deere #108
Generally speaking.
I would agree with you to a point, but look at those well-known heavy duty stamped decks (i.e., Deere 7-iron or similar) and there would be no concern on my part. Some of the stamped decks I see on compact tractors and pro z-turn mowers are clearly made to be bombproof. They've done their homework and gone to heavier metal and good reinforcement to make them strong.
I think where stamped becomes a risk is on cheaper box-store mowers, where they are manufacturing to a price point and have short warranties. Those decks are not made to last. There is no way to make that price point with a fabbed deck regardless of the gauge of the metal, and the only way they make it with a stamped deck is with thin metal.
The other concern will be rust, if clumping and moisture are problems. Thicker metal is better for that (all else equal, like metal quality, paint quality, etc), and of course smoother shapes and less cluttered structures are better too. When I have had decks rust out, stamped or fabbed, it's always been in some area or corner that collected clippings and wasn't easily cleaned (or even visible) on a routine basis. Upon examination it was obvious, but if it was, why did they design them that way? It probably means they didn't think about that part or even study that. Filling/rounding corners or fairing in brackets would have eliminated the problem.
The mowing you describe I probably wouldn't mow with either lawn tractor discussed in this thread. Neither is tough enough, and even if they were they'd beat you to death at any reasonable speed. I'd be looking at a suitable mowing implement for your 2620, assuming it can make the turns and fit in all the spaces you need to mow. I have a Honda push mower for around my house, the X380 for my septic field and yard, and then everything else requires bush hog or sickle mower on a larger tractor. No one machine can do it all well.
/ Husqvarna GT48DXLS Compared to John Deere #109
All valid, that said:
In spite of cutting down trees like a beaver for the past 5+ years I am covered by them albeit I am now down (finally) to mostly oaks, the cedar mostly gone. Here in S Tx you just don't cut oak if you want to keep a high value on your property. We got HIT HARD by oak disease, my place was missed, but just down the road the guy with a 100 acres has FEW left. So my JD, by adding a deck ($3700) would be near worthless as it just cannot maneuver, Bush Hog would be throwing money away.
I only need to mow maybe 4 times a year max. With the Billy Goat I do 2 full mows (of the acreage I want to mow) a year and several supplemental mows in areas that get and retain more moisture, like the low area that is the run off for the pond and down below the dam.
You can see the challenges, low hours, and frequency of use, but still a need, challenging rough terrain and a mix of native grasses and other vegetation (nuisance). Plus trying to keep down that dam Poison Oak.Ivy, I swear I could round bale the stuff and no matter how bad the drought is it grows green and healthy!
Sure I could buy a $10k machine that does all and more, well I don't need the more and not likely to ever get $10k of value from it. Yet I know somewhere in the vast mix there is something that meets my needs that I can justify the cost. Key is justify, my Billy Goat was almost $4k and I did not bat an eye and its the only thing that I could get to clear with due to the trees I save...
/ Husqvarna GT48DXLS Compared to John Deere #110
17Oaks, Your logic seems - well- logical ...
/ Husqvarna GT48DXLS Compared to John Deere #111
17 Oaks..
Would one of those Power Tracs work for you ?
Maybe the PT-180 ?
H Class
Front mount mower deck, all wheel drive and very maneuverable.
/ Husqvarna GT48DXLS Compared to John Deere #112
LOL, its the engineer side of my brain and both a blessing and a cruse.
17 Oaks..
Maybe the PT-180 ?
H Class
WOW, did you see the weight, heck, no need to mow, just drive over grass and weeds and they are dead meat.
I lean towards JD and Husq as everything I have is either painted green or Husq orange, but willing to look at anything that fits my needs...Thanks to all for your support.
/ Husqvarna GT48DXLS Compared to John Deere #113
This thread started out as a comparison of the GT48DXLS versus the John Deere X300 series. One of the discussions centers around the quality of the frames of each mower. From my viewpoint the general quality of the frame would be based off of the amount of metal in the frame and the quality of the weld(s). Its hard to quantify the quality of the welds (not opinions) but the general weight of the mower should give some idea to the amount of metal in the frame. For John Deere I picked the X380 version since it has a 48 inch deck like the Husqvarna and has an engine and transmission closest in comparison to the GT48DXLS (22HP vs 24HP, G57 vs G66). From the John Deere web site the weight of the John Deere X380 is 651 lbs (no fuel), from a Husqvarna dealer site (Husqvarna GT48DXLS 48 inch 24 HP (Kawasaki) Garden Tractor) the GT48DXLS weighs 630 pounds. So roughly the John Deere is 20lbs heavier but that is roughly a 3.5 percent difference not that great. Is there any other way to quantify the quality of the frames (not opinions - those have already been shared :laughing: )? This was an interesting thread - facts and opinions both. I have one of these models ordered ....
/ Husqvarna GT48DXLS Compared to John Deere #114
The question is, which model ???? :confused2:
/ Husqvarna GT48DXLS Compared to John Deere #115
Not saying yet. I can cancel in the next day or so with no penalty. This discussion gave me a lot to think about - wish I had read it before placing the order. Just trying to sort out as much as I can regarding facts vs opinions. The one surprise I saw is that nobody compared the GT48DXLS to the John Deere S240. Also very curious about the weight being almost the same. X300 series supports the bucket lift but it cannot be due to the amount of metal in the tractor - they are to close in weight. It seems that the bagger is a lot more expensive for the John Deere. It also seems the pricing varies greatly from John Deere list. Can folks share what they are paying for new X350/X370/X380 John Deere mowers? I saw where they had a $500 off coupon last year - is that usually a reoccurring deal and when does that start?
/ Husqvarna GT48DXLS Compared to John Deere #116
quality of the welds (not opinions) but the general weight of the mower should give some idea to the amount of metal in the frame. So roughly the John Deere is 20lbs heavier but that is roughly a 3.5 percent difference not that great. Is there any other way to quantify the quality of the frames (not opinions - those have already been shared :laughing: )? This was an interesting thread - facts and opinions both. I have one of these models ordered ....
Just having a 20# heavier frame doesn't mean to much because one frame may have a higher tensile strength. A lighter frame might still be stronger.
Maybe the heavier one has more gussets where they matter so a heavier frame might be a plus if for that.
/ Husqvarna GT48DXLS Compared to John Deere #117
Good point Deere Dude. There is no way to really quantify the frames unless we were to get the Husqvarna and John Deere product engineers in the same room and let them share material make up/mfg process..
/ Husqvarna GT48DXLS Compared to John Deere #118
I don't think that you can make a comparison of the frames just based on overall weight, because 1) there are so many other factors involved in the weight of the machines, and 2) weight and strength don't necessarily go hand in hand (for example a tall I-beam will be a heck of a lot stiffer than a piece of round bar of the same weight because the material is spread farther from the bending axis).
Deere has a picture of their frame here:
And they list these specs:
The frame is made of heavy formed and welded steel, reinforced in critical areas for greater strength:
* The frame is formed from 12-gauge, 0.105-in. (2.66-mm) thick material for long life.
* Standard front bumper and hitch plate are formed from 9-gauge, 0.15-in. (3.8-mm) steel and complete the frame assembly.
* Rear hitch plate can support two 42-lb (19-kg) Quik-Tatch weights.
* Weight bracket is built into the frame of two-wheel-steer models.
Note that the X380 shares the same frame construction as the X500 models except for the front bumper and hitch area, which are thicker 0.25-in. (6.4-mm) steel on the X500.
I could not find any specs for the Husky's frame. But if you look at the two frames it will be very obvious how they differ. Note that both tractors will seem wimpy compared to a garden tractor of 30-40 years ago.
/ Husqvarna GT48DXLS Compared to John Deere #119
I don't know how you could look at over all weight and try to apply it to one part of the tractor. For example the Deere has a plastic hood vs steel for the Husqvarna, is there a weight difference between the two? The only way that seamed to rate the frame was the post about an aftermarket company that makes a front bucket for multiple brands. They state that the frame isn't strong enough for their bucket on a number of the Husqvarna models while the X300 series they offered a loader. How that translates to how strong the frame is for those who will never put a bucket on it, I can't say. Then there's engineering. Like 17 Oaks posted a fabricated deck could be stronger than a stamped one unless the stamped one was made out of a better quality of steel. At the end of the day I think you just pick the things you like about each brand and compare it to how you plan to use it to find the best option to fit your needs.
/ Husqvarna GT48DXLS Compared to John Deere #120
For me I realized that when I started looking at Yard Tractors, Garden Tractors and "real tractors" that a Yard Tractor and a Garden Tractor (in most cases) are really only good at being a lawn tractor. I thought I wanted a Garden Tractor to use for a bucket lift, a snow blade and possibly pulling a cultivator or pull behind rototiller. I realized after reading all the forums that its just to risky using a garden tractor as a tractor. People criticize the K46 transmission yet John Deere uses them in a Garden Tractor (some of the X300 series). Why do I want to spend $2500 to $4000 on something that I have to wonder if I am tearing it up every time I use it as a garden tractor - even a John Deere?
I have looked at the X300 series John Deere and they appear to me to be more rugged than the various Husqvarna Garden Tractors although again it is hard to quantify. The John Deere is evidently more rugged, can handle a bucket lift, better warranty and some nice "use-ability" feature (like the way the deck is leveled, etc). The Husqvarna has a larger engine, better transmission and manual rear locking differential.
There are 4 Husqvarna dealers in a 45 minute radius from where I live - 3 of the 4 dealers are worthless, one has good service/show room. I have two John Deere dealers in my area and both have good reputations, nice showrooms/lots and sales people.
Just to share I have roughly 2.5 to 3 acres to mow, hilly and I will be hauling dirt in a smaller utility cart attached to the tractor for the home orchard I am setting up/maintaining.
My pricing structure seemed to be different then what I read on this forum. One of my local Husqvarna dealers offered me the GT48DXLS for $2799 and the bagger for $349 and the Husqvarna dealer seems competent. Both John Deere dealers would only come off $100 dollars off of list so I was looking at $3100 for an X350 to $4300 for an X380.
The pricing is what sunk John Deere - if I could have gotten the X380 for $4300 - 500 coupon (former promo) - $380 (another 10% off) I would have walked out with an X380. I read in the forums that some people were getting these type of discounts but not where I live. I could not swallow paying $1500 more for an X380 especially when I plan to use the GT as a Mower with light hauling capability.
As a side note John Deere needs to add locking rear differential to a lower end x300 model - it was not a must have for me but a very very nice to have.
My current Craftsmen Yard Tractor is 19 years old, made by Husqvarna and is tore all to pieces - but I abused it. Hopefully my new Husqvarna will last as long with little trouble.
So now you John Deere lovers you can through darts at my pic (imagine Mr Potato Head) and Husqvarna fan boys well I guess you can party on .... Thanks to all who post in these forums - it really helps novices like myself.
2017 Ford F-150 Ext. Cab Pickup Truck (A60352)
2017 Ford F-150...
2007 Freightliner Columbia 120 T/A Wet Cab Sleeper Cab Truck Tractor (A60352)
2007 Freightliner...
207277 (A52708)
207277 (A52708)
2001 Kubota L3300F 35HP Utility Tractor with Caroni TC710 6ft. Rotary Brush Mower Attachment (A59228)
2001 Kubota L3300F...
LMC Nitrogen Applicator (A62177)
LMC Nitrogen...
WACKER NEUSON LIGHT TOWER (A60736)
WACKER NEUSON...
