Loader Front end loader maintenance
/ Front end loader maintenance #1
Danger18
Calhoun, GA
2015 LS XR4046HC
After searching the LS parts manual for the LL4102, I cannot find a part number or spec for the grease zerks that are used on the FEL. I've broken 3 trying to get my grease gun off. I've tried loosening the fitting on the gun.
/ Front end loader maintenance #2
First you need to attempt to determine if Zerks are metric or inch threads. On my Kubota Grand L, assembled in Japan, the chassis Zerks are uniformly metric. The Kubota loader, manufactured in Georgia, has inch threads, so far as I can determine. You may or may not find yourself in my situation.
Tractor Supply Co. and Agri Supply both stock metric and inch threaded Zerks, in single size packs and mixed assortments. eBay is another source for Zerks, especially odd sizes and configurations. Zerks are cheap.
Buy yourself a grease gun coupler. Users think couplers are overpriced but are happy they spent the funds and would buy again. Easy on, easy OFF. Coupler decreased my FEL greasing time by at least one third, while it improved grease distribution.
LINK: Amazon.com: LockNLube Grease Gun Coupler - Zerk Grease Coupler Fitting Tip - Easy Lock-on, Clip-off - Stays on - Grease goes in, not on the machine: Automotive
/ Front end loader maintenance #4
I'd buy you lunch if you were closer; I didn't know this was a thing! Overpriced?! Only if you had never fought with every zerk fitting on a chassis when performing periodic maintenance. Thanks a lot!
/ Front end loader maintenance #5
I broke one off as well. Replaced it with an m10 I think.
I guess it's time to invest in a LocknLube
/ Front end loader maintenance #6
Ya over priced but so much better than fighting grease gun
/ Front end loader maintenance #7
I've got Lock n Lube couplers on pneumatic grease gun and manual grease gun. The grease fittings on my LL4102 loader are recessed and the Lock n Lube diameter is too large to fit into the recess. I use a manual gun with standard coupling for the FEL.
/ Front end loader maintenance #8
I have a Lock n Lube too. I found only a couple fitting recesses to be too tight.
I relieved the recesses a little with a grinder bit on my Dremel. Lock n Lube fits all now.
2022 CATERPILLAR 299D3 XE SKID STEER (A64279)
2022 CATERPILLAR...
John Deere 4040 Tractor (A64047)
John Deere 4040...
2012 Isuzu NPR HD w 5.2L 4HK1-TC Turbo Diesel (A63689)
2012 Isuzu NPR HD...
2016 International DuraStar 4300 Dump Truck (A61573)
2016 International...
2021 PETERBILT 388 6X4 T/A SLEEPER TRUCK TRACTOR (A59911)
2021 PETERBILT 388...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
