V2203 Interchangeability
/ V2203 Interchangeability #1
moto135
St Marys, pa
Cub Cadet 8454, Cub Cadet 1782
Hello everyone, I've been lurking on the site for a while, there is a lot of great info on here. I signed up because I just purchased this:
Its a Cub Cadet 8454 with 600 hours that I paid $2500 for. It ran when I bought it but had one heck of a knock that I assumed to be crank related. And sure enough when I got it into the garage and pulled the oil pan the crankshaft has a crack going through a counter weight and journal. So obviously its going to need a new crankshaft and this is where my question comes. As I understand it and the reason for posting in the Kioti forum is that this is the same tractor as the DK45. Now I've read a couple places that the daedong 4a220 is a carbon copy of the kubota V2203. I've found specs for both crankshaft bearing diameters and everything matches there, but is there any other differences that would cause the kubota crankshaft not to work in the daedong engine? I want to use the kubota part because I can get a good used one for $300 vs $1500 for a new deadong piece. Any Info would be greatly appreciated. Thanks!
/ V2203 Interchangeability #2
As your aware the V2203 is a Kubota engine designation with two very different engine castings. The DI - direct injection block is a totally different block from the indirect injected engine.
The V2203 DI is the much sought after engine and getting real hard to find, the IDI engines Tier 4 have replaced the older Kubota engines.
I purchased a Kubota V2203 DI from a damaged reefer, the DI engine is the most sought after and getting hard to find, plenty of IDI tier 4' s out there Carrier Transicold uses Kubota. Damaged reefers end up in truck wrecking yards, if its just one part you need find a refrigeration shop that works on reefers.
Thermo King uses the Isuzu engine.
The bottom picture are injectors used on the Indirect injection V2203, top is direct injection.
/ V2203 Interchangeability #3
One mystery solved, your tractors engine uses an indirect injection system. I would search for a shop that works on reefer units the mechanic will have a good assortment of good used parts.
Rusty - Thanks for the great info, I never even thought to look at reefers for parts. I'd like to find a repair shop to see if I can compare crankshafts, however the nearest shop I found on my quick google search was 5 hours away. I'll have to do some asking around locally though to see if anyone works on them
/ V2203 Interchangeability #5
The V2203 is also a popular engine used in portable welders and generators.
/ V2203 Interchangeability #6
Rusty think you have your DI and IDI backwards in your first post. The older mechanical injected non tier 4 engines are indirect injection meaning that the diesel is injected into a small side chamber in the head that helps it ignite quicker and also has the glow plug. The newer DI engines the fuel is injected directly into the combustion chamber in a multi event spray that is possible with the electronic injectors. Not sure if this will help clear things up but as long as you get an older engine with mechanical injection pump it may work with your Cub.
/ V2203 Interchangeability #7
I knew that Kioti built tractors for Kubota and then eventually copied the designs. I have a very early DK55. My understanding is that the DK55 is a turbo charge version of the DK50. It is a turbo 2.2 liter. If the engine in the DKs are knockoffs of the Kubota, would the Kubota 2203 bolt into the chassis and connect to the transmission?
/ V2203 Interchangeability #8
Take a look at this short thread about the 2203 and engine similarities. Certainly leaves on a cliff hanger though.
http://www.mytractorforum.com/17-kubota-forum/539577-kubota-vs-daedong.html
Kubota and Daedong only had a short stint together along with ford sometime back in the 60's 70's (someone may be able to clarify this) A few lawsuits have tumbled around since then.
These days the Kioti Kubota relation would be through Daedong Metals Co Ltd. Their foundry in Korea. According their website, they currently do business with Kubota, Hyundai, LS Mtron, Hydrotech, Doosan, Kawasaki, and some others. They produce and sell cylinder heads and blocks, flywheels, clutch housings, middle cases, transmission cases, hydraulic cylinders, valve blocks, pump cases, MCVs, and shaft and valve casings for a number of different industries.
Major Customers | Daedong Metals Co., Ltd.
I would say if some heavy parts on a Kubota seem identical to what you see on a kioti, its because Kubota bought the parts from Daedong.
One of the reasons Daedong/Kioti is capable of producing quality at the price they do. They own their own, very large foundry.
/ V2203 Interchangeability #9
Doing some internet research, I found a number of sources that states they had a partnership in the 1980's.
"Both companies use a distinctive orange paint and have very similar styling. In the early 1980s the two companies collaborated to produce the “Kubota 02″ product line. Daedong provided the transmission and the steel for the body. Kubota provided everything else. After the collaboration, Kubota accused Daedong of stealing engineering secrets. The conflict culminated in 2002 when Kubota filed a lawsuit against Daedong."
If Daedong manufactured the transmissions, they would have the Kubota bolt pattern.
/ V2203 Interchangeability #10
I did a 1.7 liter to 2.2 liter Kubota conversion in a Kubota L2850 tractor and since it had a DI engine sought out a V2203DI engine from a refer to do the conversion which i have a lengthy thread over on orangetractortalk about it. I am confused about some of the talk here mainly jimglassfords post above. I recently bought a Bobcat CT450 essentially a Kioti DK50 and the engine looks identical to a Kubota but from the specs i look up shows the Daedong in my tractor to be a 2.4 litre and the V2203 is a 2.2 litre.
/ V2203 Interchangeability #11
The Kioti DK50 had a 2.4L, But the Kioti DK45 had a 2.2L. There was a DK35, 40, 45, and 50, each with corresponding horsepower, but same transmission/tractor.
I would love to see a list of exactly what Daedong Metal provides for Kubota, because from what I've been able to gather at this point, is that Kubota is more Daedong than Daedong is Kubota.
/ V2203 Interchangeability #12
I made an error in my comment about the engine in the DK50. I looked at the Tractordata web site and the DK55 is a 2.2 turbo, the DK50 is a 2.0 turbo and the DK45 is the 2.2 non-turbo engine.
/ V2203 Interchangeability #13
I have a 2009 Bobcat CT450B which is a Kioti DK50SE and has a 2.4 l engine. DK50 was built through 2005 and the DK50SE started in 2007 and has the 2.4l.
The alphabet soup can get confusing with all the variables. No problem jim!
/ V2203 Interchangeability #14
yes this, I should be more careful when mentioning the DK or DKse tractors as well.
Hey guys, sorry I've been absent from the thread I started. I haven't had a lot of time to work on the tractor, I'm building a house and thought the tractor would be a good project for my down time haha.
But I got the tractor split and the crank out.
The crank below the broken one is from a kubota v2203, and everything seems to measure pretty close to the same.
I have a week off of work and the wife said I don't have to work on the house over the holiday, so I plan on starting to reassemble the tractor. I'll keep everyone posted on how it works out.
/ V2203 Interchangeability #16
good stuff, I'll get some popcorn.
So, of course I haven't been working on the tractor project as much as I wanted to, but I have made some progress. The crank is back in the block, rods connected to crank and front cover back on the block. A couple of things I have noticed as I am reassembling with Kubota parts and gaskets:
- At least with the gasket kit I purchased none of the O-rings seem to be the same size
- the front cover gasket is off a little bit in one area
- the head gasket has a copper ring where there is an alignment bushing while the stock one does not have it. The copper ring doesn't fit over the alignment bushing
- The crank has an extra ring pushed on to the flywheel side that makes the OD larger, this wouldn't work with the Kioti seal but the Kubota seal is larger for this extra ring
Everything else seems to be working though, all the crank and rod bearings were the right size and fit together as it should
/ V2203 Interchangeability #18
I ran into the same issue with the front cover gasket and O-rings too when I ordered the gasket kit for A v2203 rather than a v1702 since I used the 1702 front cover on the 2203 block I had to order a gasket kit for the 1702. Wound up needing bits and pieces from each gasket kit and still needed to get several individually.
For anyone interested, I finished up putting the tractor together and I can officially say that the kubota v2203 crankshaft and bearings work perfectly in the 4a220 daedong engine. I would stay away from the gaskets and seals for the v2203 though because there are enough little differences to make them not work very well. For my first time working on a tractor, I think everything went pretty smoothly and I got to learn a lot like a 1.5" sink tailpiece extension works well for a spout on your hydraulic oil bucket lol.
It took longer than I wanted it to, but I guess you'll have that when you're in the middle of building a house too. I think I made out pretty well too, I have a running tractor with only 600 hours for a little over $3000 total invested.
/ V2203 Interchangeability #20
Awesome stuff, thanks for taking the time to share this project. Really glad it worked out well.:thumbsup:
2016 INTERNATIONAL PROSTAR+122 6X4 ROAD TRACTOR (A64280)
2016 INTERNATIONAL...
2021 Sol Grand Design BK390 Camper (A62613)
2021 Sol Grand...
Land Hero Mini Skid Loader (A66408)
Land Hero Mini...
2023 Case 75c FarmAll Tractor (A62679)
2023 Case 75c...
2007 FREIGHTLINER CL112 6X4 T/A MID ROOF SLEEPER TRUCK TRACTOR (A59914)
2007 FREIGHTLINER...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
