10' rotary cutter blade problem...
/ 10' rotary cutter blade problem... #1
cutworm
Ripley, Tn.
JD 3010
I'm new to the forum. I have a 10' Agrevere rotary cutter that I bought used about a month ago. I think it's made by Howse. I pull it with my JD 3010 diesel. It has two stump jumpers with two swing blades each. My problem is that the blades are hitting the other stump jumper blades. Pretty sure that's why they sold it. The blades are so beat up that I ordered new blades and they are the same length so I don't see how the new blades will not produce the same problem. Anyone else ever had this issue? Looks like they overlap about 4". Are they suppose to overlap at all? Any suggestions & feedback is appreciated.
/ 10' rotary cutter blade problem... #2
Typically one blade spindle is offset forward of the the other. Otherwise, with belt drive, there is no way to avoid clash.
This is a gearbox driven rotary cutter. One gearbox in the center feeding one on each side of it. The stump jumper has a swing blade opposite of each other. My problem is that they hit the swing blades on the other stump jumper.
/ 10' rotary cutter blade problem... #4
They aren't timed properly.
They should be 90 degrees apart. IE, if you stand the cutter up vertically, one stump jumper should have the blade bolts holes horizontal, the other vertical.
Typically timing is done by taking apart one of the secondary shafts, have someone hold the blades 90 degrees out of sync from each other as I described, then re assemble to the nearest spline that matches
/ 10' rotary cutter blade problem... #5
he hit the nail square on the head . I would hope that you got a really good deal on it and when properly timed and new blades you will be smiling like a Cheshire cat.
/ 10' rotary cutter blade problem... #6
Correct. Incorrect timing - If you see what we mean? :laughing:
One pair is set at 12-6 o'clock and the other pair is set at 3-9 o'clock. 90 degrees.
Anything else will create a vibration.
:wrench:
/ 10' rotary cutter blade problem... #7
Ah, I assumed belt drive, not any timed drive system. In which case, I must say, the answer was all too obvious ...
/ 10' rotary cutter blade problem... #8
A friend bought a new 10'er and when the dealer assembled it they did not "TIME" it properly.
He was experienced/smart enough to see the problem and correct it before using it.
/ 10' rotary cutter blade problem... #9
Ok, don't want to argue with anyone, just have an observation...
IF...and I do mean IF...
The stump jumpers on this particular brush hog are round and not oblong, and the blades are hitting the other stump jumper, then I believe he could have a larger problem other than timing of the blades.
Now if the blades are mounted on oblong shaped stump jumpers, then it is just a timing issue.
Am I correct in assuming this???
Now if he had said that the blades were hitting the blades on the other stump jumper, I could see it definitely to be just a timing issue.
David from jax
My gut feeling is that it is a timing issue, I was just wondering if anyone else wondered about blade hitting the other stump jumper. Seems like that might be another thing altogether, just don't know what.
/ 10' rotary cutter blade problem... #10
One more hat in the ring. Pull a gearbox, rotate the blades to 90 and stick the shaft back in the box...lock her down.
/ 10' rotary cutter blade problem... #11
Yes a overlap of about 4" is about right on those style of cutters. Hope it's a easy fix by just being out of time, but there is also the possibility one of the outer gear boxes has been replace with the wrong ratio, do both outer boxes look the same and also look to see if the I.d. Tags are on them, if so see if they are the same ratio, if changing the timing doesn't work.
Ok, I really appreciate the feedback. Last night I raised the bush hog up and spun each stump jumper (they ARE round) and I can spin one and the other one does not spin with it. I can spin the other one and the other one will not spin with it, almost like they are not connected together at the center gearbox even though I can clearly see that they are. Although one side did spin the pto shaft everytime (I had it disconnected from the tractor) while the other side seemed to only spin the pto shaft very intermediately. I'm stumped. I'm leaning towards one gearbox may be stripped or something.
/ 10' rotary cutter blade problem... #13
Yep, sounds like a stripped gear-unless there is a shear pin.
/ 10' rotary cutter blade problem... #14
There is normally a little play. One stump jumper will move quite a bit before the other one.
IE: if you have a set of blades at 3 and 9 o'clock and one at 12 and 6.....it's not uncommon to be able to go to 11 or 1 o'clock before the other side moves.
If you can spin it round and round and the other side don't move, that's an issue. Normally I'd say a secondary shaft. They are usually coupled to the center gearbox via rubber couplers. Of one of those goes out, you'd only be driving one set of blades.
It since both sets of blades make the center gearbox turn I'm at a loss and fear gearbox damage. But check out those secondary shafts anyway
Thanks, I'm going to give each gearbox an internal look at.
/ 10' rotary cutter blade problem... #16
This is the lesser damaged side, still with power transmission from PTO through two gearboxes (Centre & Side) to the blades.
Your problem is in the other side... between Centre gearbox and the blades, somewhere.
Now, just to find the fault.
Are you confident (Mechanically) to continue further disassembly? It seems you may be..
If so - Can you post a picture of the BH for us pls? (Top-side preferably although multiple pics are better. The more the merrier!)
Before opening the gearboxes, look at the drive-shaft 'between' the Centre & Damaged side. Look at the Couplings and possible shear-pins etc.
The shaft should have some sort of cover - Plastic or solid metal?
:wrench:
/ 10' rotary cutter blade problem... #17
I might have missed read. I though both sides caused PTO shaft movement. If only one side did, then the other side isn't connected to the center box.
My money is on whatever couples the center gearbox to the outboard on that side. Usually it's a driveshaft with rubber coupler discs. I am betting one of them bit the dust
I would agree except that one side is moving the pto shaft as expected. The other side only moves the pto shaft sporadically, it actually doesn't move it more than it does move it. Is it possible for an internal shear pin to have sheared and when I move the stump jumper that it grabs once in a while to move the pto shaft? That is my thought. I will post pictures tonight after I remove the covers.
/ 10' rotary cutter blade problem... #19
It is. That's the fault we are reading it as. But more likely (hopefully) the sheared part (pin or coupling) is external to the gearbox.
So, you check the easy stuff first. Shafts are easier to check than insides of gearboxes.
You work from the outside inwards. Eliminating as you go.
We know that when the PTO shaft turns the centre gearbox turns.
When the centre gearbox turns the one side box turns. And we know that, because the blade disc turns uniformly on that side.
The other side is turning intermittently so something is catching and releasing...
Since both sides are driven by the same gears in the centre box we look outside the centre box to the driveshaft couplings and then the gearbox on the 'bad' side.
Removing the covers will expose the shaft & couplings (I hope) and aid the process of elimination to identify the location of the fault.
You may still end-up looking inside the gearbox. If gears have stripped it will be less expensive to replace the offending gearbox as a whole unit I would think.
Yes pics always help.
:wrench:
Think I found the problem...
John Deere 2032R Loader Tractor (A66285)
John Deere 2032R...
2017 TROXELL 150 BBL ALUMINUM VACUUM TRAILER (A63569)
2017 TROXELL 150...
Coleman Minibike (A65579)
Coleman Minibike...
2023 VOLVO L90H WHEEL LOADER (A65053)
2023 VOLVO L90H...
2020 Peterbilt 348 Vermeer Mega Vac VXT8 Tri Axle Vacuum Excavator Truck (A60352)
2020 Peterbilt 348...
John Deere 785 Manure Spreader (A66408)
John Deere 785...
