Price Check John Deere 710D 2wd
/ John Deere 710D 2wd #1
Fletch88
Valdosta, GA
JD 710D
Hello new to the forum! I have a 20 acre tract that I cut timber off of approx 8 years ago. I am looking at a JD 710D backhoe for cleaning up either splitting up into lots or planting fruit trees on. Back when I had it cut the prices I got to have it cleaned up and replanted were outrageous. I decided to let it sit for almost 8 years and now think it's time to do something with said property.
My question is about a JD 710D backhoe. It has been used by a local guy to clean up his 20 acres as well. In the process he said he has replaced "about" every hydraulic hose on it and just put $1300 injector pump on machine. I know this is a big backhoe and do not plan on buying equipment to haul it around. Will the fact that it is only a 2wd be ok for what I'm doing or would a smaller hoe that is 4wd be a better option. The machine in question is priced at $12,500 with 3400 hours in it. I plan on using it for 1-2 years and probaly re-selling unless I see a need to keep it.
/ John Deere 710D 2wd #2
My question is about a JD 710D backhoe. It has been used by a local guy to clean up his 20 acres as well. In the process he said he has replaced "about" every hydraulic hose on it and just put $1300 injector pump on machine. I know this is a big backhoe and do not plan on buying equipment to haul it around. Will the fact that it is only a 2wd be ok for what I'm doing or would a smaller hoe that is 4wd be a better option. The machine in question is priced at $12,500 with 3400 hours in it. I plan on using it for 1-2 years and probaly re-selling unless I see a need to keep it.[/QUOTE
http://www.tractordata.com/backhoe-loader/000/0/8/80-john-deere-710d.html
Wel I went ahead and purchased the backhoe. It will do what I need to get done on the 20 acres I have. The hydraulics seem a tad weak, but I will be doing pm's and maintenance on unit today. Hopefully not the pump.
/ John Deere 710D 2wd #4
Welcome to the 710 family, they are heavy. People talk about there tractor being a beast, they have no idea.
20 GALLON SPRAYER, 12V (A64278)
20 GALLON SPRAYER...
2015 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A64194)
2015 Peterbilt 567...
2017 Freightliner M2 106 TMA Attenuator Truck (A64194)
2017 Freightliner...
2017 Bobcat T550 Compact Track Loader Skid Steer (A61572)
2017 Bobcat T550...
2022 Mack Pinnacle T/A Wet Kit Day Cab Truck Tractor (A64556)
2022 Mack Pinnacle...
2017 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A67148)
2017 FREIGHTLINER...
