John Deere 1050 - Elbow Fitting ID Needed for JD Model 8 Backhoe
/ John Deere 1050 - Elbow Fitting ID Needed for JD Model 8 Backhoe #1
Eric67ct
Bethany, CT
1983 John Deere 212, 1988 John Deere 1050
I have a John Deere 1050 with a Model 8 backhoe. I went on the JD parts web and looked up the following part that is stripped (previous owner cross-threaded it). I looked online for the part and found it, but have no way to identify if this is the correct part. Here's the part # info followed by the actual elbow. Can you tell me if this is the correct part to order?
Item: Elbow Fitting
Part Number: AM123132 (SUB FOR AN31756)
IMG_20170724_183947099.jpgIMG_20170724_184050755.jpgIMG_20170724_184109687.jpgIMG_20170724_184129563.jpg
Thanks,
Eric
/ John Deere 1050 - Elbow Fitting ID Needed for JD Model 8 Backhoe #2
look closely, should have the Deere part number stamped on it somewhere, they mark most everything
Unfortunately, I checked every millimeter of the elbow and with the exception of 3 diamonds on the flat end of the elbow, there is no part number. There has to be an actual photo somewhere that I can match the part to...I just don't know why it's so hard to photograph a part that seems pretty common on a hydraulic system.
/ John Deere 1050 - Elbow Fitting ID Needed for JD Model 8 Backhoe #4
JD don't make the hydraulic fittings such as elbows etc. so they are only ever marked with the makers name (occasionally - if at all).
The parts pics don't show on my computer for that Backhoe but the part number is listed. Seems quite common... Shouldn't be too expensive to buy one. If it's not correct the dealer should take it back if you don't damage the packaging.
:wrench:
Brent 420 Grain Cart (A61307)
Brent 420 Grain...
2018 FREIGHTLINER CASCADIA 125 6X4 T/A SLEEPER TRUCK TRACTOR (A59908)
2018 FREIGHTLINER...
PENDING SELLER CONFIRMATIONS (A59908)
PENDING SELLER...
2016 AutoHauler CX11HCSD T/A Car Hauler Trailer (A56858)
2016 AutoHauler...
2018 FORD F-150 (A60736)
2018 FORD F-150...
2025 Pabreak Auger Bits and Plate Skid Steer Attachment (A61567)
2025 Pabreak Auger...
