Case 580C Flip Rear wheels Rims for Snow/ice chains?
   / Case 580C Flip Rear wheels Rims for Snow/ice chains? #1
p0opstlnksal0t
Eliot, Maine
in the market
Can the Rim be flipped and bolted back into the wheel to gain a few inches of clearance for snow chains?
   / Case 580C Flip Rear wheels Rims for Snow/ice chains? #2
   / Case 580C Flip Rear wheels Rims for Snow/ice chains? #4
I think you are probably right. Leave the tires on the same sides - just flip the wheel centers. Looks like you will gain a few inches. Now that's if the center CAN be flipped and rebolted. If your rear tires are filled with fluid - be VERY careful - they will be very heavy. I don't see any bolts between the wheel centers and the outer rims. Unless they are bolted - its a lost cause. Example - if the center is welded to the outer rims - its a "no deal".
   / Case 580C Flip Rear wheels Rims for Snow/ice chains? #5
Those are welded pressed steel wheels. They are already set to max. width.
Rear wheel spacers may be my only option here then.
Can anyone refer me to someone online who makes wheel spacers?
   / Case 580C Flip Rear wheels Rims for Snow/ice chains? #8
There is a fellow named Elmer Haug. His number is (785) 587-3248. He operates a tractor repair and salvage in Centralia Kansas and kind of specializes in case. I do not know for sure if he does the industrial stuff or not. He may have something or maybe able to point you in the right direction. Just Google Elmer' s Repair and give him a call.
1992 DFI PULL SPREADER (A57192)
1992 DFI PULL...
2007 Saturn Sky Convertible Coupe (A54815)
2007 Saturn Sky...
2017 Ford F-250 Service Truck (A56858)
2017 Ford F-250...
202474 (A54757)
202474 (A54757)
2014 F-150 STX (A56435)
2014 F-150 STX...
2003 International 7400 T/A Heil 12 CuYd Dump Truck (A55853)
2003 International...
