Rear Finish Mower JD 272 Gearbox Repair or Replace?
/ JD 272 Gearbox Repair or Replace? #1
RSCook
Renton, Wa
John Deere 955
I have an older JD 272 Grooming mower that appears to be leaking gear lube into the belt area. My mower's gearbox is manufactured by Curtis. I don't believe Curtis replacements are any longer available. I was looking at a 272 listed on eBay that has a gearbox made by Comer in Italy. If replacing the seal on the vertical shaft of my Curtis is not doable for any reason, would a Comer gearbox be a viable replacement for my old gearbox? And are the Comer gearboxes good?
/ JD 272 Gearbox Repair or Replace? #2
The seal(s) for your Curtis should be obtainable from any good local 'Bearing & Seal' distributor.
The Comer boxes are standard equipment these days and used by many manufacturers of mowers/implements. Nothing wrong with them.
:wrench:
(p.s. try and get your duplicated thread deleted.)
/ JD 272 Gearbox Repair or Replace? #3
You could do corn grease in the gear box...
/ JD 272 Gearbox Repair or Replace? #4
I replaced the oil in my flail mower gearbox with pourable grease when it started leaking. Paid $100 for the mower & new seals were going to be $70... Lots of people with rotary cutter a do it I hear.
I'm sure grease lubes slightly less well than oil, but not much. I'm also pretty sure the gearbox on my flail will still be going fine when I retire or scrap the flail here in a good few years.
John Deere corn head grease seems to be the popular solution.
2015 Ford Transit 350 4x4 Sewer Viewer Van (A61573)
2015 Ford Transit...
2012 ISUZU NPR CREWCAB 16FT BOX TRUCK (A59905)
2012 ISUZU NPR...
PALLET OF (9) HYD OIL PUMPS FOR DUMP TRAILERS (A64280)
PALLET OF (9) HYD...
2001 Sterling Single Axle Dump Truck (A62613)
2001 Sterling...
INSPECTION (A65563)
INSPECTION (A65563)
2011 Ford E-350 Passenger Van (A61573)
2011 Ford E-350...
