Backhoe BH92 Backhoe Full Storage Height Clearance on a L6060
/ BH92 Backhoe Full Storage Height Clearance on a L6060 #1
utvol2003
Blountville, TN
Kubota/ L6060
I would like to know what the overall height of a BH92 Backhoe is on an L6060 with 14.6-26-R1 Titans? I am building a barn and would like to have plenty of clearance for storage and while driving under sheds. I have been waiting for delivery of the tractor for over 6 weeks and looks like it will be a couple more weeks and the barn is on its way up and I had not considered the backhoe. I initially thought 10ft would be enough, now not so much. Thanks for the help!!
/ BH92 Backhoe Full Storage Height Clearance on a L6060 #2
I have a BH92 on an L5740 with 17.5L-24 R4's, and formerly on an MX5100. In the normal transport position the hoe does not quite fit thru a 9ft overhead door -- if I remember correctly the interference was just a couple of inches. It easily clears a 10 ft door. I don't know how the height on these machines compares to the L6060, but I imagine it is very close. If you want more info we could compare the height of the mount points from the ground.
Edit: Although I "thought" I remembered a slight interference with our 9 foot door, the Kubota spec for transport height is 100.1 inches, so maybe I'm mistaken. In any case you will have no problem with 10 foot clearance.
/ BH92 Backhoe Full Storage Height Clearance on a L6060 #3
Although I don't have a measurement for an L6060, the BH92 on my similarly sized MX5800 easily clears a 10' door. I estimate it clears by 18" so tire size isn't an issue. I also have an L6060 on order. I'll post again if I have a problem.
Thanks for your help.
/ BH92 Backhoe Full Storage Height Clearance on a L6060 #5
Hey, old thread, but I'm getting an L6060 with BH92 and need to build storage. Could you please confirm how high a door opening you would recommend? Thank you very much.
/ BH92 Backhoe Full Storage Height Clearance on a L6060 #6
Am in the same situation--wondering how high a door opening you would recommend? Thank you very much.
/ BH92 Backhoe Full Storage Height Clearance on a L6060 #7
If you can, why just not install a 12' door?
I have never heard anyone state that they wish they had installed a shorter door!
/ BH92 Backhoe Full Storage Height Clearance on a L6060 #8
On my L3940 it easy clears 10 ft door. Storming now do I won’t go measure.
/ BH92 Backhoe Full Storage Height Clearance on a L6060 #9
Well, I can tell you on an MX4800 its 1 inch taller than a 8 ft door. I've hit it several times. I can't believe a 6060 would be much taller.
2009 Volkswagen Jetta Sedan (A59231)
2009 Volkswagen...
2012 ALTERFER  CAT GENERATOR (A60736)
2012 ALTERFER CAT...
John Deere 6110M (A60462)
John Deere 6110M...
2016 Ford Explorer AWD SUV (A59231)
2016 Ford Explorer...
RIPPER ATTACHMENT FOR MINI EXCAVATOR (A58214)
RIPPER ATTACHMENT...
2019 Bobcat MT85 (A60462)
2019 Bobcat MT85...
