hose orientation with two 90's
/ hose orientation with two 90's #1
ugabulldog
GA
'04 MF 451 diesel shuttle shift w/ MF 1040 loader
I am about to order some hoses and fittings from discount hydraulic hose.com. These will have 90 degree fittings on both ends and will run from my rear remotes to loader where I will mount on L bracket facing forward. Since both sets of couplers will be facing forward, should I orient at 0 degrees, fittings aligned? Thanks
/ hose orientation with two 90's #2
I would suggest taking a piece of air hose or garden and run this like you intend to run the hydraulic line. This will provide a visual of how the ends should be oriented.
/ hose orientation with two 90's #3
I would fix a 90* to either end of the machine and go with a straight fitting. I've tried to make a real orderly looking "plumbing" with pressed on 90's & 45's, but if it's not perfect the hose won't lay right (where you want it) and come repair or replacement time. a simple straight end is easy to grab locally. Don't forget to have a swivel in at least one end if using NPT. I've become real fond of JIC fittings lately.
That makes a lot of sense, should of thought about that. Do you mean one of these on one or both ends? The hose male would go into the female and the male end of fitting would go on the female end of coupler?
NPTF Male Pipe x NPSM Female Pipe Swivel Elbow
/ hose orientation with two 90's #5
I like Rustyiron recommendation but I would get 90 or 45 degree fittings with swivel ends on them rather than the hose. Hose with fix straight fittings are often cheap compare to any other design or at least what I have found.
/ hose orientation with two 90's #7
Well, something will eventually happen to the hose, if a 90* at each end does not make things too long, I'd lean towards just using a straight hose with the fittings on the fixed ends (machine). The drawback is there are more connections that each are a potential leak. If you use pipe x jic fittings (90's) then you can just use a jic x jic on your hose and no swivels will be needed.
Is this like the 90 adaptor you are referring to? 2501-08-08 | 1/2" JIC Male x 1/2" NPTF Male Pipe 90°
Would the 90 orientation be adjusted by how much I tighten it? Thanks Rusty
/ hose orientation with two 90's #9
That's it, and yes to the orientation. Usually you can get it right (direction) but if you think your pushing your luck with "just another half turn", put some more tape on the threads. Just keep it away from the end of the fitting, you don't want that teflon tape floating around in you hyd. system.
/ hose orientation with two 90's #10
I'm going to make a guess that you're making a set of long hoses to run a 3rd function from your rear remote - therefore you're going to have some sort of Quick Disconnect on each end - and typically they all have NPT Female threads.
I'm with Rustyiron here - use JIC Male to NPT Male 90 deg elbows and put them into the QD's and L Bracket. Then put straight JIC Female ends on your hoses. Then you have zero alignment / twisting issues because of the hose routing.
If you can give a bit more detail on what you're trying to do and/or share pictures; I'm sure some of the guys here can get you squared away right down to the part number.
Yes, that is my plan, with 1/2" ag couplers on rear remotes and 1/2" HT flat face at loader. thanks.
/ hose orientation with two 90's #13
So are all JIC straight hose fittings considered "swivel"? Like this: (I don't see anything else listed on their website) FJX-06-08 | 3/8" Hose x 1/2" JIC Female Swivel
Yes - by it's design the JIC female end always has a "swivel" built into it (I promise it will make much more sense once you have them in hand).
So I would use these on both hose ends with the 1/2 JIC to 1/2 NPTF non-swivel 90 like this: FJX-06-08 | 3/8" Hose x 1/2" JIC Female Swivel ?
Link went back to the same hose end instead of the adapter but I knew what you meant and yes you can use that just fine.
Also you can use 3/8" fittings since you're using 3/8" hose and then just change size in the adapter itself like this.
2501-06-08 | 3/8" JIC Male x 1/2" NPTF Male Pipe 90
At that point I'm getting really picky and it's probably a matter of penny's either way cost wise (I'm just OCD like that) so which ever makes more sense to you - it will work the same either way.
Here's a link to the new revised write-up I did on our 3rd function project - if you look at page 15 in the right hand picture, That is pretty much the same thing except I'm going from JIC to Metric in the loader valve instead of NPT.
http://www.tractorbynet.com/forums/customization/358086-kioti-ck-35-3rd-function-3.html#post4820298
Yes that is the 90 I meant, Thank You!!
/ hose orientation with two 90's #15
Hi,
We've been quiet around here for a while, but are trying to get active again. Hope we were able to help you out - if not give us a call and I'm happy to help walk you through it.
-Blake
800-535-1302 x205
/ hose orientation with two 90's #16
I have worked for several OEMs and they always specify at least one end with a straight fitting unless absolutely necessary. As others have mentioned - unless they are made perfect the hose won't lay right. We also avoid pipe thread wherever possible. Very difficult to guarantee these to be leak free plus the hassle of using thread sealant.
One thing that wasn't mentioned was restriction. If this is on a low flow application like a FEL not a big deal, and often packaging matters more, but with high flow applications a 90° on a hose has much lower restriction than most 90° fittings which just have two intersecting drilled passages.
ISZ
2004 FOREST RIVER CHEROKEE LITE CAMPER (A62130)
2004 FOREST RIVER...
2023 New Holland CR10.90 Combine - 330 Engine Hours - 251 Separator Hours (A63118)
2023 New Holland...
20 Yard Roll Off Dumpster (A61165)
20 Yard Roll Off...
Dad's Garage Decorative Metal Sign (A61569)
Dad's Garage...
(INOP) 1991 INTERNATIONAL 4900 6X4 DUMP TRUCK (A62130)
(INOP) 1991...
2006 John Deere 325 Skid Steer (A63116)
2006 John Deere...
