Do you own a wheelbarrow?
/ Do you own a wheelbarrow? #1
bdog
Elite Member
Texas
John Deere 6130M
I was just at Home Depot and noticed the display of wheelbarrows out front and got to thinking that is the one thing I don't have. I have been accumulating tools and such for over 25 years I have three shops full of virtually everything I could need and I have never had a wheelbarrow. Never really needed one but I guess it seems like such a basic thing that everyone probably has. I didn't buy one. Figured hadn't needed one in 25 years likely won't need one now.
/ Do you own a wheelbarrow? #3
I have FIVE !!!
This will likely evolve to a..... how many wheelbarrows do you have ...... thread.
/ Do you own a wheelbarrow? #4
On my second one. Just replaced the handles on it. Wife didn't want me to take the first one to the dump but it finally rusted to the point it broke into.
/ Do you own a wheelbarrow? #5
I have FIVE !!!
I lose.:mad: I have only two -- one in SC and one in NC. I made extensive use of the one in SC when mixing concrete for setting fence posts. Now neither one gets much use.
Steve
/ Do you own a wheelbarrow? #7
Yes I have 2. One is a side by side wheeled cart and the other a standard one wheeler - solid rubber tire.
Just used it yesterday to spread mulch, before that to haul cement from mixer to form. I keep a wheelbarrow full of dry firewood on the porch in the winter.
/ Do you own a wheelbarrow? #8
Two here.
/ Do you own a wheelbarrow? #10
I have the same one that I used to haul fire wood in back when I was 12 years old (32 years ago). When my dad gets something new, I get his "hand me downs". I just replaced the oak handles this spring and converted the front to a double wheel for stability. It has a couple of small holes rusted through the bottom that let the rainwater out.
/ Do you own a wheelbarrow? #11
One of the handiest tools my wife has.
Were you being sarcastic or does really have one or " want "one ? Either way it made me laugh.
/ Do you own a wheelbarrow? #12
Yes, just one that I bought when we first got married over 40 yrs ago, it's still in great shape except for the tire that needs to be replaced. However, I use the tractor bucket as a wheelbarrow anymore - it's powered and I don't have to push it up hill.
/ Do you own a wheelbarrow? #13
We have 3, 1 is a 2 wheeler!!
Picture is from an image search.
/ Do you own a wheelbarrow? #14
I have one wheelbarrow, use it mostly for mixing concrete in, and moving small loads of dirt.
/ Do you own a wheelbarrow? #16
Have had one for many years but it is now against my religion to use it. Would much rather use the loader bucket!
I've always wondered about the side hill stability of the 2-wheelers. With a top heavy full load is it a problem on a slope?
Edit: I know that may sound like a silly question but with a single wheel the barrow can be tilted to balance the load.
/ Do you own a wheelbarrow? #17
Very handy, and much better with flat proof tires.
Yep. And now that I have a two-wheeler, I will probably never go back to a one-wheeler. It's just far more stable, especially on uneven ground, and I can handle heavier loads with it. Doesn't dump to the side easily, which is occasionally a minus, but that's not enough to outweigh the pluses.
/ Do you own a wheelbarrow? #18
I have one that was given to me by a friend (some friend) but I lost the instructions and can't use it. I do have one with a no flat tire.
/ Do you own a wheelbarrow? #19
Had one before we transplanted here from AZ. It never got used once I got the JD rider with the dump trailer. Left that in AZ with father in law (he was thrilled). Almost bought one here a few years back, but came to my senses and bought another rider and dump trailer combo. Whew, that was close. And now with that combo and the Branson + FEL, I don't suppose I'll ever buy a manual wheel barrow again (at least I sure hope not).
/ Do you own a wheelbarrow? #20
I have one of the older shallow pan ones that the wood rotted away on, tub is still good. Currently using a metal handled frame that I salvaged from the scrap dumpster and replaced the thrashed tub with another that I found. The holes didn't line up but that's what welders are for.
I used to repair and build new ones for the fencing install crews, a mod I always did was to reinforce the front struts with some 1/2" square tube and add a small piece of flat bar to the edge of the axle brackets to keep them from folding backwards when loaded to 250% of their capacity.
Like most on here, I prefer the Bobcat bucket as the best method of moving stuff, space permitting.
2018 Cat D6T LGP VPAT Dozer (A62679)
2018 Cat D6T LGP...
2012 Audi Q5 3.2 Quattro Triptronic (A62679)
2012 Audi Q5 3.2...
Gas Powered Air Compressor (A66408)
Gas Powered Air...
Concrete Cut Off Saw (A66408)
Concrete Cut Off...
Hickory Lumber (A65640)
Hickory Lumber...
1999 38ft Beverage Trailer (A65563)
1999 38ft Beverage...
