Powering riding mower
/ Powering riding mower #1
parvodog
Tyler, TX
JD 4300
Okay, so the engine on my Cub Cadet 1554 seized, and I'm wondering if I can use a horizontal shaft engine powering a pump, with a hydraulic motor powering the rear hydrostatic axle.
It won't have the mowing deck on it. My wife will only be using it with a small garden cart to haul some tools.
Thanks,
Tim
/ Powering riding mower #2
Do you already have the pump and motor? What are the details on it as far as engine horsepower, pump and motor displacement?
Anything is possible but it is a complex approach that would likely yield disappointing results. I'd look for a vertical shaft engine off a lawnmower with a dead transmission or see how much work your engine needs to fix.
/ Powering riding mower #3
Really think it would be easier and cheaper to fix the seized engine or get a replacement. A brand new replacement should run about $1700. from Equipatron.com.
Setting up a hydraulic drive system with tank, valve, hoses, oil cooler, pump, pump mounting, hydraulic motor and couplings can get to be expensive. Sorry just not practical in my book.
/ Powering riding mower #5
I'd fix the original engine before installing an intek. Even if it cost the same or a little more.
/ Powering riding mower #7
You don't need the same or similar engine if all you'll be doing is putting around pulling a cart. All you need to do is drive the rear transaxle. A little 5hp vertical shaft would probably do it. I bought a 6.75 vertical B&S to repower my walk behind trimmer for less than $100 to my door. And it had electric start! You might have to drill a couple of holes for mounting but what's it matter? (Or maybe not--Many verticals have the same foot print.)
/ Powering riding mower #8
I agree but in checking I did not see one with electric start below the $500 dollar level. Where did you find yours?
Thank you for all the replies.
I already have a 13hp horizontal shaft engine with a 14gpm pump. I've never rebuilt a small engine, and am fine keeping it that way.
So, if I can power this thing with a 5.5hp Predator from HF for $99, that's the route I'll go.
Thanks again!
Tim
/ Powering riding mower #10
IMO 5.5hp would be pretty gutless through a hydro transmission in a tractor that heavy unless your land is completely flat and you plan on towing feathers. Your call though.
/ Powering riding mower #11
The hydros only use a few horsepower. All the rest in a lawn tractor is for spinning blades to cut grass. He's not doing that and probably not going to race it. :rolleyes:
/ Powering riding mower #12
With a top speed of 5.2 mph it should handle a 400 lb. cart just fine. Figure wife mower and cart total 1100 lbs. that equates to 200 lbs./hp. using this 5.5hp engine. That is a reasonable weight / hp.
/ Powering riding mower #13
I bought my 6.75 last year. I don't recall who I bought it from but the same engines were all over eBay, Amazon and pretty much all the re-power sellers like Jacks Small Engines, etc. Even Surplus Center had them. Their version was a few bucks cheaper but didn't include freight. Mine has a green Weed-Eater sticker on the top and came in a plain brown box (not a Briggs box). I would guess they were over-stock or discontinued engines. BUT... They were brand new with an alternator and starter. Look around. They're out there. Or similar deals.
Mine is still running great.
EDIT
Here's an 8.75 for $144 with starter at SC. I don't know where you guys are finding the $500 engines but look harder. :)
8.75 Torque Briggs & Stratton Engine ES/RS | Vertical Shaft Engines | Gas & Diesel Engines | Engines | www.surpluscenter.com
/ Powering riding mower #14
I suppose. However it's very easy to find 10-20 HP vertical shaft mowers with rotted out decks or bad transmissions. At least around here. Post pics of you build OP!
/ Powering riding mower #15
A mower engine needs the weight of the blade to act as a flywheel, without it they are hard to start and vibrate a lot.
For tractor use (pulley instead of a blade) you want a "heavy flywheel" engine. One common source for these is pressure washers, I have picked up a couple from a small engine guy with bad pumps for $20 to $40 apiece for similar projects. I picked up the whole washer, that way I could drill holes in the mounting plate of the pressure washer to match the larger riding mower bolt holes.
/ Powering riding mower #16
View attachment 515025View attachment 515026
What are you talking about the weight of the blade??? Ive never heard of such nonsense and when you start and drive a mower around without the blades engaged they work just fine. If they needed heavy flywheels on them im sure it would have been figured out after 50+ years.....
/ Powering riding mower #18
I've only started one push mower without a blade, but it ran perfectly. I'm really doubting they redesigned the whole motor just to put on a push mower.
/ Powering riding mower #19
Some of the newer push mowers with the blade clutch will run the same but a lot of the older push mowers wouldn't run worth crap without the blade or some type of extra fly wheel weight. And no the just put heavier flywheels on the same motor for other duties.
/ Powering riding mower #20
I would agree with this ^^^
And would note that when shopping for an engine that I often see some with heavy fly wheels listed. Some motors with light fly wheels depend on the mass of the mower blade to run smoothly and that has been true for the last 50 years or so that I know of.
2012 INTERNATIONAL 4300 4X2 S/A 18FT NON CDL BOX TRUCK (A59912)
2012 INTERNATIONAL...
(5) 2" X 20' STEEL PIPE (A64281)
(5) 2" X 20' STEEL...
2025 BS43 44in. Hydraulic Boxbroom Sweeper Mini Skid Steer Attachment (A61572)
2025 BS43 44in...
Caterpillar Tech Manuals (A63117)
Caterpillar Tech...
Landhonor Mini Skid Steer Rock Grapple (A62679)
Landhonor Mini...
YALE VERACITOR 50VX STRAIGHT MAST FORKLIFT (A63276)
YALE VERACITOR...
