Resetting service indicator - Sharing how to.
/ Resetting service indicator - Sharing how to. #1
OLV1071571
Central Arkansas
Kioti RX7320P
Just wanted to share with the forum the process for resetting the service indicator. This is the process for the 3500 series so it might be different for you depending on your model.
1. Open fuse panel located under steering column left side.
2. Pull the 10a fuse from the top right of the fuse panel. Mine was labeled turn signal but the dealer said it shouldn't matter what its labeled.
3. Insert 10a fuse into the empty "reset" spot.
4. Turn the ignition to the on position but do not start the engine.
5. Wait 30 seconds and turn the switch off. (For me the service indicator did turn off)
6. Then replace the 10a fuse into its original spot
7. Start the tractor and the service indicator light (the wrench) should be off.
Hope this is helpful for the community.
/ Resetting service indicator - Sharing how to. #2
Or use a OBDII scan tool to reset it.
There you go trying to make things easy again! LOL :laughing:
832749 (A61166)
832749 (A61166)
Ford F450 Bucket Truck with Altec AT200A Boom (A56435)
Ford F450 Bucket...
Teak Wood Table Top (A61569)
Teak Wood Table...
2013 Ford F550 Bucket Truck w/ Jib (A62613)
2013 Ford F550...
Decorative Alligator Statue (A61569)
Decorative...
2021 Ford F550 4X4 Service Crane Truck (A62613)
2021 Ford F550 4X4...
